macleod(at)eagle.ca Guest
Posted: Tue Dec 18, 2007 9:03 am Post subject: Electrical Connections |
List:
I want to share two related events which are giving me concern and get
your comments.
About 18 months ago on the day of the EVENT I noticed that my transponder
did not seem to be responding to the Calgary terminal radar although it
appeared to be otherwise working fine. A few days after the EVENT when I
was dismantling the plane for salvage/junking I noticed that the terminal
screw on the power supply to the transponder was loose. I thought at the
time that 1 screw out of hundreds loose was cause for concern but not
real worry.
Last night I was removing the components from the dead planes instrument
panel for installation in my new 601 and was amazed to find that about 30
percent of the screws were slightly loose and two were very loose (the
ring terminal on the wire was flopping around on the screw).
I had definitely tightened all these screws to the max during construction.
The screws on the Ray Allen switches seemed to be the most prone to
loosening.
The dead plane had 200 hours, the vibration levels on the instrument panel
were very low.
A question:
For my 601 I want to ensure that all electrical screws remain tight. I
purchased some “Starbright - Liquid Electrical Tape” which seems to have
some thread locking capability. In light of my much higher screw failure
rate is there something better for electrical connections?
Mike
601XL waiting patiently for Rotax FWFwd
psm(at)ATT.NET Guest
Posted: Tue Dec 18, 2007 9:15 am Post subject: Electrical Connections |
Hi Mike,
I wonder if you installed lock washers on all the nuts?
Paul
XL fuselage
At 08:58 AM 12/18/2007, you wrote:
| Quote: | I had definitely tightened all these screws to the max during construction.
loosening.
Jaybannist(at)cs.com Guest
Posted: Tue Dec 18, 2007 9:22 am Post subject: Electrical Connections |
Mike,
I have used lock washers on all my electrical screws and nuts. Some of the equipment came with either split ring or the "many little grabber" type washers on the screws. On the ones that appeared more vulnerable to vibration I also used blue LockTite. Since I haven't yet started rattling things, I don't know how they will perform.
Fingers crossed,
Jay in Dallas 601XL N2630J
macleod(at)eagle.ca wrote:
List:
your comments.
real worry.
loosening.
were very low.
A question:
Mike
dredmoody(at)cox.net Guest
Posted: Tue Dec 18, 2007 9:38 am Post subject: Electrical Connections |
In addition to internal tooth type lock washers, a bit of Loctite on the threads would help a lot. The clamping pressure of the screw binding on the ring terminal and the anchoring terminal should provide all the electrical continuity you need and the Loctite in the threads will prevent movement caused by the vibration inflight.
Dred
---- macleod(at)eagle.ca wrote:
List:
your comments.
real worry.
loosening.
were very low.
A question:
Mike
