darinh
Posted: Wed Dec 26, 2007 8:37 am Post subject: Capacitor in Kitfox Elec. System? |
Can someone explain the reasons for having the big capacitor in the electrical system on our kitfoxes? My diagram shows it on the discharge of the alternator...is this simply to even out peaks from the alternator or does it serve another purpose? I am running a dual alternator setup and don't expect to use the onboard alternator much at all (only if the primary dies on me) so is this capacitor really necessary? If this is an ignorant question, please forgive me as I am really a complete novice when it comes to electronics.
_________________ Darin Hawkes
Series 7
914 Turbo
Kaysville, Utah |
wingsdown(at)verizon.net Guest
Posted: Wed Dec 26, 2007 9:27 am Post subject: Capacitor in Kitfox Elec. System? |
It should suppress any electrical noise you might get. Should probably
have one on each alternator. If your not getting any noise then you
probably don't need them.
Rick
darinh
Posted: Wed Dec 26, 2007 10:08 am Post subject: Re: Capacitor in Kitfox Elec. System? |
Thanks Rick, could you just use shielded wire for the alternators to minimize noise?
Series 7
914 Turbo
Kaysville, Utah |
KITFOXZ(at)aol.com Guest
Posted: Wed Dec 26, 2007 10:18 am Post subject: Capacitor in Kitfox Elec. System? |
The capacitor in your ship's wiring diagram is a very important component. It filters or "smoothes" the output voltage pulses from your alternator before voltage spikes or "bumps" can do harm to your voltage regulator or your avionics items. It is also a component that helps to accomplish voltage stability in your voltage regulator and to your entire electrical system.
Consider comparing that capacitor to a large water tank:
In the bottom of the water tank is an open valve for drawing water (ship's power). Voltage pulses from your ship's alternator are like buckets of water being added to the water tank (capacitor). The stream of water coming out of your water tank's valve is smooth and little change in water volume or pressure is noted as each bucket of water is poured in to the top of the tank. A voltage pulse from your alternator is stored in the capacitor in much the same way that a bucket of water is stored in the water tank.
During the time that the alternator's output is zero (the time between output pulses), the capacitor supplies an even voltage to your electrical system with little droop in output voltage. During the time that the alternator's output voltage pulse is well over nominal voltage, the capacitor absorbs the spike in much the same way as the water tank that has a larger than normal bucket of water dumped in to it. The output water stream "feels" little change.
John P. Marzluf "John Z"
Columbus, Ohio
Series V Outback (still out back in the garage)
See AOL's top rated recipes and easy ways to stay in shape for winter.
darinh
Posted: Wed Dec 26, 2007 11:12 am Post subject: Re: Capacitor in Kitfox Elec. System? |
John,
This is what I understood the capacitor to do. Then the question is...should I have one of these on both alternators? And what size should the second on be (40 amp alternator output)?
Series 7
914 Turbo
Kaysville, Utah |
Posted: Wed Dec 26, 2007 11:18 am Post subject: Capacitor in Kitfox Elec. System? |
I think the type of noise you want to shield is in the circuit and not
what is generated from say weak plug wires. At least that was my
understanding. I know there are folks way smarter on the subject than me
though.
Rick
Posted: Wed Dec 26, 2007 12:22 pm Post subject: Capacitor in Kitfox Elec. System? |
In a message dated 12/26/2007 2:15:00 P.M. Eastern Standard Time, gerns25(at)netscape.net writes:
| Quote: | John,
Darin Hawkes
Series 7 (under Construction)
914 Turbo
Ogden, Utah |
Yes. Size is not critical. Two of the same would be fine. You could even share the cap. with both alternators if your configuration is to switch out the primary but failed alt. and switch in the back up one.
If your intention is to have two complete and independent power sources you will need two alternators, two filter capacitors, two regulators, two batteries, a primary and an alternate power bus, etc.
Columbus, Ohio
Posted: Wed Dec 26, 2007 2:51 pm Post subject: Capacitor in Kitfox Elec. System? |
Yes one on each. Small.
darinh
Posted: Wed Dec 26, 2007 4:01 pm Post subject: Re: Capacitor in Kitfox Elec. System? |
Thanks guys for the info. I have installed the optional alternator because the onboard one is not quite enough for what I have. So rather than simply let the onboard alternator sit unused, I have wired them on a switch and relay so in the event that my primary alternator goes, I will at least be able to operate my primary electronic items. The other alternator has the regulator built in, so I have two regulators and two alternators but only one battery.
I like John's idea of sharing the capacitor between the two as I will never have both alternators providing power at the same time.
Series 7
914 Turbo
Kaysville, Utah |
