cjhukill(at)cox.net Guest
Posted: Sat Dec 29, 2007 10:45 am Post subject: pitot mount |
I too had to remove material for the tube to fit into the mount, but I removed material from the inside of the mount instead of the tube. It didn't take much, but a small sanding drum on the Dremmel tool did the job. I figured the mount is fairly thick steel, and the tube is expensive, and not steel, so logic told me to grind the mount a little, and then paint on a little zinc chromate.
Chris Hukill
