hotwheels
Posted: Thu Feb 21, 2008 1:03 pm Post subject: Perihelion dimmers |
Has anyone used these dimmers? http://www.periheliondesign.com/egpavr.htm
* Any quirks?
* It doesn't appear to be Pulse Width Modulated (a bonus)
(data Sheet here: http://www.national.com/mpf/LM/LM317.html)
* ON/OFF switch is nice
* How do they fit in the very limited space provided for by the RV10 switch rail?
Jay
Up to elbows in fiberglass. Planning electrical to save my sanity.
n8zg(at)bellsouth.net Guest
Posted: Thu Feb 21, 2008 3:44 pm Post subject: Perihelion dimmers |
Jay -
I have two.
One driving an LED strip from Stein.
The other driving the LED map light, also from Stein.
They're slightly bigger than the typical DPDT switch - not wider, but taller
on one end.
They seem to work well.
Note that you only need a 1/4" hole.
I've been VERY happy with Eric's service.
Neal
RV-7 N8ZG
Baffles
* Any quirks?
rail?
Jay
http://forums.matronics.com/viewtopic.php?p=165449#165449
RV10 4JF
Posted: Thu Feb 21, 2008 5:45 pm Post subject: Re: Perihelion dimmers |
I have not used the Perihelion dimmers but I have made a few voltage regulators using the circuit in the data sheet. I use the LM 338 regulator which gives me 7 amps max output and 5 amps. constant current. For me, it is a pretty good regulator and reliable circuit. You should be pleased with the dimmer.
JF
