by0ung(at)brigham.net Guest
Posted: Sat Feb 25, 2006 8:15 am Post subject: kolb prop size |
Quote: | >>>>>I'll be using a 70" Warp Drive with a 912ul. Is that a good combo
to start with.
Vic
Maine
MKIIIX<<<<<<<<<<
I have had two different props on my 912 ul.. Both were purchased from the
manufactures. (Precision and warp drive) And the recommendations were the
same from both companies. 68 x 3 blades. I don't know if my home
altitude was part of the decision process or not. the companies had the
info. I am at a field elevation of 4426 ft. I asked the gentleman at warp
drive about the regular tip and the taper tip. And he told me that at this
altitude the regular tip would work best, and at lower altitudes the taper
tip would be best. Of the two props the warp drive has been the best in my
installation. Also when ordering both props I told them that the kit
manufacture recommended 3 blade props to keep some noise down, and run
smoother. I do not know what the recommendations would have been if I
asked for a 2 blade prop.
Boyd Young
MK III Classic
Brigham City Utah.
archive
| - The Matronics Kolb-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
