Fiveonepw(at)aol.com Guest
Posted: Thu Jan 05, 2006 7:20 pm Post subject: Air2air fotoz |
Howdy Listerpeople-
I've seen some mighty fine shots of RVs formating with foto ships, but I have
had, shall we say, less than spectacular results. Thought it was the camera
(1.3 Mpix Olympus), so Santa brought a Nikon 4600 (4 Mpix). Have taken some
"decent" shotz so far, but sure I can do better. Besides the usual suspects
such as glare elimination, composition, light angles etc., can anyone offer some
hints for optimizing air2air shotz with a digital camera, especially when
shooting through a not-so-optically-perfect plexi canopy? (Sam, Dan?)
Thanks for any hep!
Mark Phillips - N51PW, Columbia, TN
| - The Matronics RV-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
rv_8pilot(at)hotmail.com Guest
Posted: Thu Jan 05, 2006 7:46 pm Post subject: Air2air fotoz |
Lots of megapixels, clear vis, low angle evening or morning sunlight for
color and min shadows, decent background scenery with some contrasting
colors/patterns (white puffy clouds, green trees or land, blue ocean) and
*very* formation proficient so you can get in close and shoot a bunch of
pictures.
I'm not an expert, but have learned a few tricks after shooting quite a bit
of of video and photos. Write me off line for more details if you like.
Bryan Jones -8
www.LoneStarSquadron.com
Houston, Texas
Quote: | From: Fiveonepw(at)aol.com
Reply-To: rv-list(at)matronics.com
Subject: RV-List: Air2air fotoz
Date: Thu, 5 Jan 2006 22:20:23 EST
Howdy Listerpeople-
have
camera
some
suspects
some
Thanks for any hep!
rv7(at)b4.ca Guest
Posted: Thu Jan 05, 2006 9:50 pm Post subject: Air2air fotoz |
On 19:20:23 2006-01-05 Fiveonepw(at)aol.com wrote:
Quote: | Besides the usual suspects such as glare elimination,
composition, light angles etc., can anyone offer some hints for
You've got the basics covered. Here's some other suggestions:
1. Find a heavy hunk of steel about the size of the base of your camera.
Drill a hole through it of appropriate size, and screw it into the tripod
mount on the bottom of your camera. Put a couple of felt protective "feet"
in between the camera and the steel to protect the camera. And be careful
to not screw the bolt into the camera too far. You may need some washers.
This will increase the weight of your camera, and with the weight it's
stability.
2. Increase your shutter speed. 1/200 or 1/250 is good for getting a nice
prop sweep, but is hard to hand-hold with a point-and-shoot camera, even
with the extra weight. 1/500 will sharpen things up a bit, and still leave
*some* prop sweep visible.
3. Tell #2 to tighten it up. You want to be shooting the camera with the
zoom somewhere in the middle of it's range. The zooms on digicams don't
really get enough light at full telephoto, so you have to open the aperture
to get more light to the sensor, which robs your depth-of-field. You may
find that what looks like camera shake is just a blurry photo because the
focus isn't exact.
4. Finally, focus. The autofocus on digicams isn't the most reliable.
There are distinct "steps" in the autofocus, and it's possible to get your
subject in between two steps. At one it's out of focus, and as it moves to
the next step it gets sharp and then goes out of focus again. Having the
largest depth-of-field you can get helps with this. Taking a dozen photos
one after the other as the planes jockey for position around one another
also helps... One good photo in 12 and you're doing as well as many pro
photographers.
Here's my last air-to-air mission, coming up on two years ago:
http://b4.no-ip.org:8080/airframe/events/20040417 CYGB/thumb3.html
All photos were taken with a Nikon Coolpix 8700, with the extra battery
pack/vertical grip (the extra weight is like having the steel lump I
suggested above). The photo ship was a Piper Tri-Pacer with the rear
passenger door removed, and me tethered to the seatbelt anchor with a
climbing harness. Great fun!
-Rob Prior
gyoung(at)cs-sol.com Guest
Posted: Fri Jan 06, 2006 7:28 am Post subject: Air2air fotoz |
Rob,
Good photos, good subjects. As a Navion driver too, I thank you.
Greg Young - Houston (DWH)
RV-6 N6GY ...project Phoenix
Navion N5221K - just an XXL RV-6A
