		grs-pms(at)comcast.net Guest
				 Posted: Thu Dec 27, 2007 2:01 pm    Post subject: Developed length "dl" |
				"Developed length" comes from the aircraft  engineering practice of flat pattern development.  Sheet metal parts are  trimmed and shaped "in the flat" and then formed by brakes, or over  form blocks or dies in presses.   A flat pattern must be  developed to define the shape of the flat stock which is to be  formed.  Developed length is the length of the flat stock needed to make  the part.
  The reason that developed length is not the same as  the width or length of the finished part plus the height of the flanges is that  the bends do not have sharp corners, but are radiused.  In the flat,  the dimension of the flange is less than it will be after forming because it  takes less material to go around the radius than it would to go all the way to  the corner, then make a sharp bend. The term "setback" is used to define  the material "saved" by not going all the way to the corner
  I can't speak for the way designers define  flat parts in this day and age, but 50 years ago flat patterns were developed  and drawn by hand (usually by junior engineers and draftsmen).  Extensive  handbook tables which considered material thickness, bend angle and bend radius  were used to define setback.  The drawings were then transferred  to the material from which templates and forming dies were  made.
  It was tedious, painstaking work, but there was a  certain satisfaction in doing it.
  George Swinford
  |  | - The Matronics Zenith-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		ashontz
				 Posted: Thu Jan 03, 2008 4:03 am    Post subject: Re: Developed length |
				Developed length to me means, length plus 10 mm, then make part then trim back unused length. LOL
		planecrazydld(at)yahoo.co Guest
				 Posted: Thu Jan 03, 2008 8:11 am    Post subject: Developed length "dl" |
