wild.blue(at)verizon.net Guest
Posted: Sat Feb 25, 2006 12:32 pm Post subject: hard starting |
Hey Val--
When I was a kid, a lucky friend had an Austin Healey. Fun! One day he
came by and said it had developed a misfire--what could be The Problem?
Being highly experienced know-it-alls who read all the magazines, after
driving it really fast and blipping the throttle about 10,000 times, we
concluded it needed an engine overhaul. So, we tore the engine down,
replaced rings, bearings, points, condenser, rotor, cap, seals (and the
clutch, too, I seem to recall), ground the valves, rebuilt the carburetors
etc. Everything we could think of. New battery and muffler (no doubt a
$500 Italian after-market go-fast variety), too, I think. Started her up
and guess what--it still had the misfire! Crikey! Took it down to the
local gas station where they put it on the scope and immediately found a bad
spark plug--impossible! It was equipped with brand new $500 per Golden
Lodge spark plugs my friend had installed just before the misfire
developed--that couldn't possibly be The Problem! Five minutes and two
bucks later it ran great--just like it did before he installed the $500
Golden Lodge plugs.
Don't recall, but in retrospect I suspect my friend (not me--no way!)
dropped the offending plug during installation.
OTOH, one of the primary problems we've seen with hard starting/misfiring
-52's and CJ's isn't the plugs--it's that they're mostly still equipped with
their original issue and now shot ignition harnesses. Both the Russian and
Chinese wires have comparatively short service lives because of the
materials they use(d). Over There They have calendar service life limits on
most consumables, but We just rely on Condition and ignore the TIS limits.
So, while we ignore--and exceed--the TIS limits, oil, water, fuel etc
collect in the ring, cause the wires to deteriorate (as in turn to goo) and
finally, fail.
If you're experiencing hard starting or misfires, one of the first things to
do is check the wires. If they're bad (very likely if OEM) replace them
with high quality 5mm US wire. Not surprised at all that your conversion
kit makes a big improvement, Dennis.
There is no question that auto plugs (and wire) are way cheaper than the
aviation variety. OTOH aviation plugs and wires don't look like auto stuff
and cost more for some very good reasons. Aviation plugs last a very long
time and are a relatively minor cost item. But if you drop a plug it is
ruined (cracked or broken porcelain), regardless of brand. Don't work so
well in Austin Healeys or airplanes. A harness that has turned to goo isn't
much good, either.
Do some diagnostics before you overhaul. I'll give you my buddy's phone
number if you need advice--I might even still have some magazines laying
around. A nomex flight suit and helmet might help, too. Just kidding.
Jerry Painter
Wild Blue Aviation
425-876-0865
http://mysite.verizon.net/res0cs5r/index.html
Valkyre1(at)comcast.net Guest
Posted: Sun Feb 26, 2006 7:15 am Post subject: hard starting |
Thanks Jerry-
You've given me some more things to think about on the spark plug kit installation, an entertaining story, and a good laugh. A great way to start the day. ( I suspect your "friend" is a bit more careful these days too.)
-Val
