Tubes or tubeless?
akucheck(at)gmail.com
PostPosted: Sat Feb 25, 2006 12:51 pm    Post subject: Tubes or tubeless? Reply with quote
While I feel stupid asking, that has never stopped me before=85how do I tell
if the mains are tube or tubeless? The service manual lists both [my bird
is a 500A] as possibilities. The stems are right-angled; I don=92t understand
how that works if they have tubes=85
Alan
PostPosted: Sat Feb 25, 2006 3:27 pm    Post subject: Tubes or tubeless? Reply with quote
Ok, had a chance to get to the plane and the mains are tubeless, nose is
tube. Is that standard/normal?
Alan
dongirod(at)bellsouth.net
PostPosted: Sat Feb 25, 2006 4:41 pm    Post subject: Tubes or tubeless? Reply with quote
Group;
I have a question. I don't believe I have ever seen it in writting, what
are the tire pressures for the nose and main tires?
Don
akucheck(at)GMAIL.COM
PostPosted: Sat Feb 25, 2006 4:54 pm    Post subject: Tubes or tubeless? Reply with quote
My book says 30 nose, 45 mains.
Alan
amg(at)nc.rr.com
PostPosted: Sat Feb 25, 2006 5:57 pm    Post subject: Tubes or tubeless? Reply with quote
Mains 45 psi Nose 30 according to my book.
Roland
Don Girod wrote:
Group;
Don
john(at)vormbaum.com
PostPosted: Sat Feb 25, 2006 7:09 pm    Post subject: Tubes or tubeless? Reply with quote
In the winter, when the air gets very cool, I tend to go a little higher in
the mains. I've noticed that soft main tires will add to your takeoff
distance drastically....much more so than taking off at gross weight will if
the tires are at the right pressure. It's amazing how much your takeoff
performance degrades when the mains are 5-10 psi too soft.
/John
moe(at)rosspistons.com
PostPosted: Mon Feb 27, 2006 6:40 am    Post subject: Tubes or tubeless? Reply with quote
Nose 30, Mains 50 on a 680F(p) at 8,000 lbs.
Moe
N680RR
680F(p)
YOURTCFG(at)aol.com
PostPosted: Mon Feb 27, 2006 8:32 pm    Post subject: Tubes or tubeless? Reply with quote
I keep my mains at 60 and nose at 45psi. Any less on the nose and the power
at run-up will squish it. jb
PostPosted: Mon Feb 27, 2006 11:17 pm    Post subject: Tubes or tubeless? Reply with quote
I love how you geared-engine guys have to throw those comments in...
