Allegro 2000 stall warning system
hgmckay
PostPosted: Thu Jan 03, 2008 10:57 am    Post subject: Allegro 2000 stall warning system Reply with quote
All:
When I bought my Allegro 2000 QBuilt Kit in 2004 I purchased the Fantasy Air
stall warning system with the kit, but never did, haven't yet, and probably
never will received the electronic device/audible alarm module. The wing
came with the port, the tubing, and pressure switch which interfaces with
the audible electronic module. I also have, and installed the correct ASI,
that has an electrical connector and three pneumatic ports, which are used
with the system. All of the pneumatic system and the pressure switch is
plumbed and connected, and I am flying the plane. All I need is the
electronic audible module that mounts behind the panel that connects to the
system pressure switch, and ASI. Does anyone out there have one of these
electronic audible modules that they are not using, or does any one know the
manufacturer and source of the device, and how one could acquire one? Or, is
there any one out there familiar enough with the device (electronically)
such that I could have one made that would work on the Allegro? It can't be
too, too complicated. Can anyone help me, or am I just stuck with a
partially completed system?
Hugh McKay
Allegro 2000
Rotax 912UL
N661WW
