		dan(at)rdan.com Guest
				 Posted: Wed Mar 01, 2006 12:45 am    Post subject: Quick rv7 rudder question |
				David,
   I'm on an -8 just starting the Rudder it used different spar and rib part numbers but if it's the top tip rib, on the 8 it uses AN470AD4-4
   not sure if it the same on a 7
   Dan
   -8 Rudder
 David Karlsberg <claypride(at)hotmail.com> wrote:
 So I looked for what seemed to be like forever and cannot figure out what
 type of rivet is used to connect R-912 (the counter balance rib) to R-902
 (spar) anybody have the drawings handy?
 David Karlsberg
 Rudder -7
  |  | - The Matronics RV-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		truflite(at)yahoo.com Guest
				 Posted: Wed Mar 01, 2006 6:54 am    Post subject: Quick rv7 rudder question |
				I had that same question when I built my rudder not
 that long ago.  I could not find an answer.  So, I
 went back to basics.  I knew that I needed 1.5 times
 the diameter of the rivet protruding from the shop
 side.  I therefore took some different length AN470AD4
 rivets and fit each one till I found one that looked
 to be about 1.5 times as long as the diameter.  If you
 are getting specific, you need .140 sticking out.
 Dave
 --- David Karlsberg <claypride(at)hotmail.com> wrote:
  David Karlsberg
  Rudder -7
  browse
  Subscriptions page,
  FAQ,
  Admin.
