AZFlyer
Posted: Mon Jan 07, 2008 10:08 am Post subject: 601 XL, Front floor skin-Riveting |
List,
Am getting close to riveting the front floor skin with all it's various stiffeners and attachments, so my question is: Do I turn the fuselage over to do the riveting or work on my back underneath the fuse?
What have others done? Seems to me that turning it over is the easy way.
Mike
_________________ Mike Miller @ millrml@aol.com
601 XL-B, 3300, Dynon
Remember, "the second mouse gets the cheese"! |
chris Sinfield
Joined: 28 Nov 2006 Posts: 270 Location: Sydney Australia
Posted: Mon Jan 07, 2008 1:08 pm Post subject: Re: 601 XL, Front floor skin-Riveting |
I did mine as a section upside down then turned it over and joined it up to the gear channel once it was done and just did those last ones on my back
Chris
Rick.Beckman(at)atk.com Guest
Posted: Mon Jan 07, 2008 2:25 pm Post subject: 601 XL, Front floor skin-Riveting |
Hey, Mike! It's just like a big aluminum canoe at this point,
so turn it over! Get a little help so as not to bend anything. Makes
life soooo much easier.
Happy Building!!
Rick from the Eastern Jackson County
Swamps!!
dredmoody(at)cox.net Guest
Posted: Mon Jan 07, 2008 4:56 pm Post subject: 601 XL, Front floor skin-Riveting |
You should have the whole mess up on some sort of supports (saw horses?) jigged and shimmed to the prescribed level or angles before you start pulling rivets. That way you don't incorporate any twist or improper relationships of parts. I found that working on a creepr on my back works well under the plane. They aren't terribly expensive and you will use it as long as you have a plane to work on.
Dred
---- AZFlyer <millrML(at)AOL.com> wrote:
List,
Mike
Mike Miller (at) millrml(at)aol.com
601 XL, 3300, Dynon
http://forums.matronics.com/viewtopic.php?p=156556#156556
