Something else to check on your 601XL quick build kit
macleod(at)eagle.ca
PostPosted: Wed Jan 09, 2008 6:53 pm    Post subject: Something else to check on your 601XL quick build kit Reply with quote
Craig:
I had the same problem with my kit (not quick build). I replaced the
AN3-15As with AN3-16As and used thin washers to get the required thread
exposure. I am in the fortunate position of having lots of AN hardware on
hand so these substitutions are easy for me.
Mike
waiting patiently for my Rotax FWFwd
Although an AN3-16A might meet the
spec
I think these three bolts would have to be changed to AN3-17A to ensure
enough length.
craig(at)craigandjean.com
PostPosted: Wed Jan 09, 2008 8:04 pm    Post subject: Something else to check on your 601XL quick build kit Reply with quote
Thanks! I'm not surprised that the regular kits can have the same problem.
All the parts involved were made by ZAC in Missouri. But I do wonder why the
folks in Bogota built and shipped it this way.
For small orders like this the shipping from Aircraft Spruce is usually more
than the parts. I'll probably wait till I have a larger order and order -16A
and -17A. Guess I'll add some thin washers to my set of miscellaneous
hardware too. As usual the perfect bolt is an AN3-16.5 Smile
-- Craig
