Lynn Matteson
Posted: Mon Jan 07, 2008 5:50 pm Post subject: Current events/ski story |
Just a general observation about this "movie" that's playing. It
seems as though I've seen this one before, and I think this is the
part where several of the "cast" get indignant, walk out and start a
splinter group. Sometimes they come back, apparently missing some of
the regular cast of characters, and some don't. I've got a short
memory, and can't recall just what happened when this movie played
before. But it was a good movie, and so I'll stay and watch it again.
Who knows, maybe somebody edited it while it was awaiting reruns, and
it'll be different this time around. That's why I'll be waiting and
watching, having my popcorn and soda, and enjoying the show, maybe
even booing or hissing, but as always thoroughly entertained and
enlightened.
Curious thing about splinters....sometimes a real pain, but sometimes
you just have to let them work themselves out.
I just finished reinforcing my homebuilt snow skis that I'm using on
my Kitfox IV. I had a close encounter of the first kind [to continue
the movie theme ] with a frozen snow bank the other day, and bent
the tips of my skis up. They bent just ahead of where the last
diagonal brace departs with the main side rails. I like the bend up,
but they weren't equal, so I re-bent the ski with the larger bend to
match the other, and then added a diagonal bend from the VERY tip of
the skis back to the main cluster. This current temperature of 57F
and two days of rain has knocked our previous foot of snow out
completely, so this is the perfect time for me to do the repair. The
skis flew perfectly after the bending took place, and even allowed
the skis to climb a little higher above the deep snow. I had always
felt that I needed a little more up-bend at the fronts, and now I
have it, thanks to good old Mother Nature.
Lynn Matteson
flying w/450+ hrs
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
avidfox
Posted: Mon Jan 07, 2008 7:30 pm Post subject: Current events/ski story |
"This current temperature of 57F
completely, "
Lynn,
Do you, or are you having, a humidity problem inside your hanger with the weather being what it is the last few days?
If so, any sugestion on how to stop or at least control it, other then just better air circulation?
Steve Benesh
Milford Mi.
Lynn Matteson
Posted: Mon Jan 07, 2008 8:24 pm Post subject: Current events/ski story |
I meant to say that I added a diagonal BRACE from the very tip of the
skis back to the main cluster...sorry.
Lynn
On Jan 7, 2008, at 12:27 PM, Lynn Matteson wrote:
| Quote: | equal, so I re-bent the ski with the larger bend to match the
other, and then added a diagonal bend from the VERY tip of the skis
back to the main cluster. This current temperature of 57F and two
days of rain has knocked our previous foot of snow out completely,
so this is the perfect time for me to do the repair. The skis flew
perfectly after the bending took place, and even allowed the skis
to climb a little higher above the deep snow. I had always felt
that I needed a little more up-bend at the fronts, and now I have
Lynn Matteson
flying w/450+ hrs
N369LM |
Lynn Matteson
Posted: Mon Jan 07, 2008 8:43 pm Post subject: Current events/ski story |
I just went to my hangar today, and there was moisture all over the
fabric, but none in the vicinity of the engine. I have been using a
200 watt strip heater that lays under the engine between the oil
cooler and the oil pan. This keeps the entire engine warm, and a
insulated blanket over the cowl keeps the heat within the cowl. I
think that just opening the hangar doors and leaving them open would
*maybe* keep the humidity down, but I'm not sure. I'm gonna try that
tomorrow.
I'm really tickled pink with the way this strip heater keeps the
engine warm. Lately, with the temp outside around 20-30 F., I've been
seeing oil temp of about 100, cyl head temp of about 75, and cowl
temp of about 75 before ever starting the engine, just by having this
strip heater going 24 hours. I mentioned this heater in a post on Jan
1, asking for any input from folks regarding any negative aspects
that using this heater might bring about, but got no response. Maybe
mentioning it again now will bring some answers?
Lynn Matteson
flying w/450+ hrs
On Jan 7, 2008, at 10:13 PM, 84KF wrote:
| Quote: | "This current temperature of 57F
completely, "
Lynn,
Steve Benesh
Milford Mi.
www.matronics.com/Navigator?Kitfox-List _-
www.matronics.com/contribution _-
N369LM |
Float Flyr
Posted: Mon Jan 07, 2008 8:51 pm Post subject: Current events/ski story |
You got to watch those drifts. I had a friend who flew a 180 in the back of
Labrador. One winter he landed close to Goose Bay and hit a drift that
flicked the main gear straight out to the sides and bent the be$%^&* out of
the prop. Your encounter seems to me to be constructive rather than
destructive.
Noel
III-A
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
dave
Posted: Tue Jan 08, 2008 3:16 am Post subject: Re: Current events/ski story |
Lynn for reference use,
I had a friend build a pair of skis last year out of plywood and over laid with glass at my shop. When he brought them out I said I think it has a pretty steep angle on the nose of ski but he thought it would be ok. Well he finished them and they looked great. Took him an hour to put them on and rug the cables and bungees but when he started to taxi the noses dug in. Took him 2 hours to dig the plane out and get back to hangar.
Not to run his nose in it I taxing mine repeatedly through his ruts and where he got stuck to show him that the ones that I have did in fact work better and not dig it with a shallower tip angle.
I am just pointing out how critical this was to him and hopefully as other have pointed out to "help others gain form the experience of others" with the use of this forum.
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube |
Lynn Matteson
Posted: Tue Jan 08, 2008 5:36 am Post subject: Current events/ski story |
Mine now have a 2-stage angle on the front...the recent 8° bend (I
call it the Mother Nature bend), and the original approx. 45° angle.
This allowed them to get through the snow rather well, with the 12-
inch width of the "shoe." Were his narrower than yours? Was his tip
bend short in height? How about the length from the axle pivot to the
tip? A shorter dimension here could affect his ability to climb over
the snow, I would think, especially with a steep tip angle.
Lynn Matteson
flying w/450+ hrs
On Jan 8, 2008, at 6:16 AM, dave wrote:
Rotax Dealer, Ontario Canada
Flying Videos and Kitfox Info
http://www.cfisher.com/
http://forums.matronics.com/viewtopic.php?p=156734#156734
N369LM |
avidfox
Posted: Tue Jan 08, 2008 11:25 am Post subject: Current events/ski story |
Lynn,
I've installed a number of FAA PMA approved preheaters on misc. Continental and Lycoming engines, mostly the "Tanis" systems. These consist of heat pads that are siliconed to the oil tank, or sump, and may include individual heating elements that are attached to the individual cylinders in various ways.
For some reason, I recall , probably from their advertising literature, that the main concern was not to allow f a "hot spot" to develope at the tank or sump from high,unregulated, heater pad temperture. They went on to explain how their "systems" were thermostatically" controled to prevent this, maintaining a mild, constant heat point, so as not to allow the oil to "coke", which I THINK means "burn". They aslo "warned" about the "dipstick heaters", again, they would get much to hot, at the stick itself, and break down the oil.in contact with it. A unusual change in oil colour, with traces of black soot\sludge mixed in might indicate "coking" at a hot spot.
Another concern, again paraphrased, was condesation developing in a constanaly changing enviroment inside a tank\sump\engine if a consistant ambiant temp is not maintained over a long period of time due to irregular thermostat control.
These are just things I remember hearing\reading about. I couldn't prove or disprove any of them personally.
I would think any pad\element that is not allowed to run wild is fine.
This is just second hand, old memory, heresay, but the concept is sound.
At the time, a Tannis would run about $150.00, but one could get a automotive style oil pan heater from J.C.Whitney for $15.00. Both would do the same, but only one was " FAA Approved". for installation on Certificated aircraft and naturally, Tanis wanted one to buy their products.
Steve Benesh
84KF [quote][b]
Lynn Matteson
Posted: Wed Jan 09, 2008 5:00 am Post subject: Current events/ski story |
Thanks, Steve. The "coking" was the exact concern that I had. My
element sits under the pan but over the oil cooler, and it's the
cooler, with its thinner tubes that is my concern. I've been having
this mental picture going on, since I started to use the strip
heater, of a hot spot like you mentioned. I've thought about moving
the heater to a different area so that this doesn't present a
problem, and I think that's the answer. Either that or insulate the
bottom of my heater a bit so that where the oil is the least
concentrated, so is the heat.
Lynn Matteson
flying w/450+ hrs
On Jan 8, 2008, at 1:18 PM, 84KF wrote:
| Quote: | Lynn,
sound.
Steve Benesh
84KF
N369LM |
dave
Posted: Thu Jan 10, 2008 2:50 am Post subject: Re: Current events/ski story |
Lynn,
I dug out a pic of those skis i mentioned above.
I can tell you that these skis did not work very well as the tips just dig, dove whatever with that tip too steep.
Wooden ski with tip too steep www.cfisher.com Kitfox |
829.83 KB |
547 Time(s) |
Lynn Matteson
Posted: Thu Jan 10, 2008 8:41 am Post subject: Current events/ski story |
I see what you mean....they look way too blunt to me. It looks like
they are no more than about 4" high at the tip, and too steep, like
you said. I think I made mine about 6" high at the tip, and much more
pointed. The recent encounter probably gave me another 1 1/2 to 2"
more height at the tip, and they seem to like the deeper snow now. Of
course all of our snow is totally gone now, so I'll have to wait
until more falls, or head toward the upper part of the state to find
snow.
Incidentally, the Annual Skiplane Fly-in at Pioneer Field in Oshkosh
is coming up in a couple of weeks.
Lynn Matteson
flying w/450+ hrs
N369LM |
dave
Posted: Thu Jan 10, 2008 9:04 am Post subject: Re: Current events/ski story |
Lynn,
Back on wheels as of today .
we 98% green ,well brown and water everywhere . Just in from a flight
fun fun fun
