				 Posted: Wed Jan 09, 2008 1:24 pm    Post subject: Hangar condensate and my 601 |
				Hi guys,
 On checking the hangar during this latest winter thaw, I realized my
 aircraft was literally dripping on all the undersides. Actually, the
 condensate was everywhere. I wiped the plane down, but seriously doubt
 that would help. In conversation with another builder, he’d heard
 putting a plastic sheet over the concrete floor in an unheated hangar
 would help prevent humidity from rising from the dirt and concrete and
 condensing on the plane’s surfaces. I’m not a weatherman, and only have
 a vague idea of what’s actually going on. There are probably many of us
 looking for a better solution to this. Are there any good suggestions or
 practices regarding covering a plane or the floor, or both during these
 wet periods?
  |  | - The Matronics Zenith-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		Gig Giacona
				 Posted: Wed Jan 09, 2008 1:37 pm    Post subject: Re: Hangar condensate and my 601 |
				The plastic on the floor might help but if there is that much moisture in the hanger the last thing you want to do is cover the airplane.
601XL Under Construction
		John75142
				 Posted: Wed Jan 09, 2008 1:46 pm    Post subject: Hangar condensate and my 601 |
				Larry:
 I'm not sure if the plastic on the floor will work, I do know that before
 pouring concrete if you put down plastic then pour it will keep the moisture
 from wicking through your slab.
 But hey it would be a cheap experiment to see, it might work the same way.
  _________________ John Short |
		gscampoli(at)HOTMAIL.COM Guest
				 Posted: Wed Jan 09, 2008 2:26 pm    Post subject: Hangar condensate and my 601 |
				Larry,
 Usually the key factor in controlling moisture and condensation in a structure is adequate ventilation.  Can you provide a few square feet of vent opening both at the roof line and at or near grade?
 I'm no expert, but I saw this approach work for my EAA chapter hangar.
 Gerry Scampoli
 Hingham, MA
 601XL - Corvair
  	  | Quote: | 	 		   Date: Wed, 9 Jan 2008 15:23:45 -0600
  Subject: Hangar condensate and my 601
  Hi guys,
  wet periods?
 Put your friends on the big screen with Windows Vista® + Windows Live™.
 http://www.microsoft.com/windows/shop/specialoffers.mspx?ocid=TXT_TAGLM_CPC_MediaCtr_bigscreen_012008
		scottbevier
				 Posted: Wed Jan 09, 2008 3:26 pm    Post subject: Hangar condensate and my 601 |
				Larry,
 There's a simple way to determine if the source of moisture is from the
 concrete slab. Cover a 48" square area on the floor with clear plastic and
 tape the edges down. After 24 hours, check for condensate UNDER the plastic.
 I don't believe this is the reason for the wet airplane. What happens is
 after a period of cold temperatures the hanger is cold, your airplane is
 cold, everything is cold, and there's very little moisture in the air. Then
 we get an abrupt blast of warm moisture laden air from the south and the
 moisture will condense out on all surfaces that are below the dew point. I
 see this a lot here in Michigan, especially in early Spring. There's no
 practical way to prevent this but you could try running a high velocity fan
 in the hanger whenever the weather forecast indicate warm moist air is on
 the way. This may help reduce the amount of condensate on the airplane, and
 the duration it's wet, but it will not prevent it.
 Scott Bevier
 active plans builder 601XL
				 Posted: Wed Jan 09, 2008 4:28 pm    Post subject: Hangar condensate and my 601 |
				Gerald,
 You may have hit on it and it would be a problem of my own making.  Last
 spring, I used expanding insulating foam to keep the birds out of the hangar
 and managed to close everything they could get thru.  I may have to
 drill it all out to allow air to circulate and replace it with screen.
 Of course, there are a few days that will be damp regardless, but this
 is one I can do.
 Thanks again!
 Gerald Scampoli wrote:
  Larry,
  Gerry Scampoli
  Hingham, MA
  601XL - Corvair
		dredmoody(at)cox.net Guest
				 Posted: Wed Jan 09, 2008 5:32 pm    Post subject: Hangar condensate and my 601 |
				I am not sure what is common practice in your  locale but here in Louisiana, we always put heavy plastic down in the forms over  the dirt/sand before pouring concrete. My understanding is the plastic is  intended to prevent the finished concrete from "sweating" during cool, damp  weather. If that was done when your hangar's slab was poured then more plastic  over the surface isn't likely to help. In fact, the only thing that is likely to  help is probably not practical. That would be to lower the relative  humidity inside the hangar, probably by raising the temperature. If you have  another way to dehumidify the hangar that might solve the problem but  otherwise you are most likely stuck with the situation.
  Dred
  [quote]   ---
		ronlee
				 Posted: Wed Jan 09, 2008 5:56 pm    Post subject: Re: Hangar condensate and my 601 |
				c
 Covering the ground with plastic and then old carpet on top of it worked for our hanger. Before that the water would drip from the ceiling from condensation.  The planes also would sweat if conditions were right before covering the floor. Apparently very much moisture was coming up through the ground, even though it looked bone dry. No more problems now.
  _________________ Ron Lee
Tucson, Arizona |
		macleod(at)eagle.ca Guest
				 Posted: Wed Jan 09, 2008 7:18 pm    Post subject: Hangar condensate and my 601 |
				Larry:
 As others have noted, if the temperature of the plane skins go below the
 dew point (ie cold plane & warm moist air) then you will get condensation
 on the plane (probably inside and outside).  I am a metallurgical engineer
 and can assure you that the plane's materials can easily take this wetness
 without any ill effects.  Venting the hanger will certainly help but
 perhaps an easier solution would be to just put light bulbs in the plane
 (one in each wing root and one in the fuse).  That should be enough to
 keep the interior and the outer surfaces above the dew point.  I do this
 in my unheated garage more for piece of mind with the electronics than
 anything else.  You only need to turn them on during the kind of weather
 we have had in the past few days (sudden warming where the moist outside
 air is much warmer than the temperature inside the hanger or if there is a
 chance of fog).
 Turned colder today so I turned the lights off.
 I use 60 watt bulbs.
 601XL waiting patiently for the Rotax FWFwd
  	  | Quote: | 	 		   Are there any good suggestions or
  wet periods?
		aprazer
				 Posted: Thu Jan 10, 2008 10:49 am    Post subject: Hangar condensate and my 601 |
				Larry,
 FYI, I built a metal over pole building (hangar) without any insulation 16
 years ago. Shortly after completion, I noted moisture condensing and
 dripping onto the aircraft during the winter months. There were no leaks
 during rain storms nor under melting snow. Water has stained the wood
 purlins, etc...
 Latter, I found that I should have insulated the interior side of the metal
 roof cover at time of construction.
 Building scenario: This hangar is constructed in the high desert with lots
 of air movement due to small open areas and lack of insulation; painted
 asphalt floor and sliding doors -- no windows.
 After much discussion with contractors, building suppliers, etc., I
 discovered that (wind powered) rotating vent fans, strategically placed,
 solved the majority of the problem. Two 12 inch diameter fans takes care of
 1600 square feet.
 These vents look like pillars with rotating vents -- sticking straight up
 from the roof. Senior moment prevents me from remembering the name.
 They are popular on commercial buildings, barns, etc...
 Mack
 601XL/3300
  _________________ The poh-oh-unemployed farm boy from Idaho |
		ashontz
				 Posted: Thu Jan 10, 2008 2:08 pm    Post subject: Re: Hangar condensate and my 601 |
				I'd say it's in the air, not the floor. If it's really cold for awhile and everything in the hanger is cold and then all of a sudden it gets warm, the new warm air is going to condense on anything that's still cold. Probably best to seal any drafts in the hanger. The floor is probably not holding that much moisture, it's the warm air that gets in the hanger after a cold spell (or should I say during a warm spell) that's causing the condensation. Takes pretty extreme conditions too. About 9 years ago I got rust all over my tools in my garage, particularly large power tools that acted as a large heat sink, when the weather suddenly went from bitterly cold to like 60 degrees or so for a few days.
 You figure worse yet is all the airspace INSIDE the plane structure, like in the wings. In that case, I'd say your better off covering the entire plane to reduce the chance of air exchange on and inside the airframe.
 No different from a fuel tank that over time "gets water in the fuel." It's getting water in the fuel from cold/warm/cold cycles condensing water in the tank.
 If the concrete is a source of moisture, painting it may help, that and sealing the hanger good so air inside can't be exchanged with the ever changing humidity of the air outside. I can see some people's thinking here that you'd want the area to be ventilated well, but at the same time, that's also bringing inside the outside air as well as the temperature differential which is the cause of the condesation in the first place. Better for the building to be more neutral in how the air reacts. If things cool off slowly and warm up and the air into and out of the building exchanges at a slower reate you don't get the extremes that lead to condensation in the first place which is "take a glass of ice water outside on a hot day" syndrome ... it's gonna sweat. That same glass of water left in the fridge and then the fridge unplugged (with nothing else in it) won't sweat, it'll just slowly warm up, melt the ice and become acclimated to it's surroundings, but the condensation problem will be minimal.
  	  | larry(at)macsmachine.com wrote: | 	 		  Hi guys,
 that would help. In conversation with another builder, he?d heard
 condensing on the plane?s surfaces. I?m not a weatherman, and only have
 a vague idea of what?s actually going on. There are probably many of us
 wet periods?
 Larry McFarland 601HDS at www.macsmachine.com |
		ashontz
				 Posted: Thu Jan 10, 2008 2:19 pm    Post subject: Re: Hangar condensate and my 601 |
				I like this idea too.
  	  | macleod(at)eagle.ca wrote: | 	 		  Larry:
 chance of fog).
  wet periods?
		Tim Juhl
  Joined: 21 Mar 2006 Posts: 488 Location: "Thumb" of Michigan
				 Posted: Thu Jan 10, 2008 3:51 pm    Post subject: Re: Hangar condensate and my 601 |
				Our airport recently built two rows of T hangars with concrete floors and bifold doors.
 In the spring every hangar occupant was complaining about the condensation problem you mention.  My Champ was literally dripping and everything in the hangar was wet.  It was simply the interaction of a cold steel structure with slightly warmer moist air.  The solution was that we cut holes near the top of the adjoining walls in each hangar and on the end of the hangars installed large vent fans controlled by a humidistat.  When the humidity rose near the condensation point the fans turned on and moved the air around.
  _________________ ______________
CFII
Champ L16A flying
Zodiac XL - Jabiru 3300A
Almost done! It'll fly in spring! |
