Europa XS with ULPower 260i engine (OOPS!!!)
nuckolls.bob(at)cox.net
PostPosted: Sat Jan 12, 2008 5:51 pm    Post subject: Europa XS with ULPower 260i engine (OOPS!!!) Reply with quote
I just realized that I didn't answer "the question" about justification
for OV protection. ALL engine driven power sources fitted with regulators
have the ability to produce output voltages well in excess of the
system design voltages. RISKS from failure of the regulator are mitigated
by (1) the alternator's limited ability to deliver energy (current limit),
(2) te alternators open-circuit, runaway limits for voltage and (3) the
battery's ability to soak-up what the alternator dishes out for an interval
of time sufficient for OV protection to take notice and shut the system down.
In the case of an SD-8 driving a 18 a.h. battery, a simple OV warning light
might suffice presuming that the owner operator is willing to place him/herself
in the OV protection loop.
Most designers op for some form of automatic device as do all folks who design
systems for certified aircraft. Indeed, all of my z-figures for power
generation
feature some form of automatic OV protection combined with immediate
notification
of LOW VOLTAGE that follows.
I was concentrating on the operating characteristics of your particular
alternator/regulator combination and overlooked the fact that your original
question asked about the value of adding OV protection. There are NO
votlage regualtors for which probability of runaway failure is ZERO. Some are
very good, some are not. Without doing the MTBF/FMEA analysis on every
design to be considered, the prudent thing to do is simply include OV
protection
on every system.
This is a 3-phase machine which I presume is more robust than the 18A
alternator on a Rotax. It's probably capable of boosting bus votlage
to over 16 volts immediately followed by a steady rise to over 18 volts
in a matter of minutes. It would not be my personal choice to hope that
I would notice and react to a regulator failure for the purpose of
mitigating damage to the rest of the system . . . I would recommend
inclusion of OV protection.
To do this on the AC side of a 3-phase system would require a two-pole
relay so perhaps the best approach is leaving the relay on the DC side
so it can be a single-pole device. See figure Z-20.
At 07:49 PM 1/12/2008 -0500, you wrote:
<vaughnray(at)bvunet.net>
Thanks Bob,
I am going down to LSA show in Sebring, Florida to see the guys who make
the engine. I hope it works out well for me.
Vaughn Teegarden
PostPosted: Sun Jan 13, 2008 7:28 am    Post subject: Europa XS with ULPower 260i engine (OOPS!!!) Reply with quote
So if I included OV protection as shown in attached, I can feel good about
protecting my electronics. I noticed that in Z-20, you did not have a 5amp
alt field breaker. I have it in mine. Is it required?
Vaughn
EuropaUL260iRev1.pdf
 Filename:  EuropaUL260iRev1.pdf
 Filesize:  333.56 KB
 Downloaded:  368 Time(s)
