Posted: Wed Jan 09, 2008 9:00 am Post subject: Audio panel #inputs vs #sources |
Folks,
I have three inputs that should be 'unswitched':
AOA warning
Traffic Alert
AF3400EM Engine monitor
My audio panel (PS Engineering PMA7000MS) has two unswitched inputs.
Can I tie two of the sources to one input? I think there would only be an issue if they both went off at teh same time.
Alternatively, I can put the third to a switched input and leave the switch on.
Ralph
nuckolls.bob(at)cox.net Guest
Posted: Thu Jan 10, 2008 6:12 pm Post subject: Audio panel #inputs vs #sources |
At 11:16 AM 1/9/2008 -0500, you wrote:
<recapen(at)earthlink.net>
Folks,
AOA warning
Traffic Alert
switch on.
Put 100 ohm resistors in series with EACH of the three output
before bringing them together whether switched or not. See:
http://aeroelectric.com/articles/Rev11/18Audio_R11.pdf
Posted: Fri Jan 11, 2008 5:14 am Post subject: Audio panel #inputs vs #sources |
I have heard 100ohm, 470ohm, and 510ohm. I'm guessing that either will function properly and that the 470 and 510's will decrease the volume more in addition to preventing the backfeed.
Ralph
Posted: Fri Jan 11, 2008 7:48 am Post subject: Audio panel #inputs vs #sources |
At 08:13 AM 1/11/2008 -0500, you wrote:
Ralph
Astute supposition sir.
Bob . . . ----------------------------------------)
( -Thomas Paine 1776- )
Posted: Fri Jan 11, 2008 8:30 am Post subject: Audio panel #inputs vs #sources |
Thanks - occasionally, I have an active brain cell or two.....
Posted: Mon Jan 14, 2008 4:47 pm Post subject: Audio panel #inputs vs #sources |
At 11:38 AM 1/14/2008 -0500, you wrote:
Will 1/4 watt be sufficient?
Yes or even 1/2 watt. I often use 'oversized'
components just to get mechanically more robust
devices. This is one case where electrical ratings
take a back seat being big, mean and ugly.
[quote]--
