windscreen
jhakes(at)emily.net
PostPosted: Wed Jan 16, 2008 8:38 am    Post subject: windscreen Reply with quote
I am replacing by windscreen on my Model IV. I have done this once before using the sheet of polycarbonate. Currently, Skystar only handles the preformed windscreens. If I go with the preformed windscreen, is there any problem with it fitting correctly.
If anyone has done this I would appreciate your advice.
Lynn Matteson
PostPosted: Wed Jan 16, 2008 10:32 am    Post subject: windscreen Reply with quote
I installed the LP Aeroplastics pre-formed windshield/skylight. (This
was before John and Debra took over the reins at Kitfox Aircraft,
LLC) I had no problem, as the 'screen comes (mine anyway) oversize
side-to-side, and front-to-back. Mark well, and cut with a Dremel
abrasive disc. Smooth and round ALL edges, and use the proper drill
for the screw holes....30% oversize as I recall. I used anchor nuts
to secure to the fuselage all around.
Lynn Matteson
Grass Lake, Michigan
flying w/460+ hrs
http://www.matronics.com/Navigator?Kitfox-List_-
============================================================ _-
forums.matronics.com_-
contribution_-
Lynn
Kitfox IV-Jabiru 2200
N369LM
dave
PostPosted: Wed Jan 16, 2008 11:13 am    Post subject: Re: windscreen Reply with quote
You can buy a sheet or 1/2 sheet of Lexan and use that .
pretty simple, just smooth the edges on on all edges to stop crack propagation. .060 .090 or .125 you can use.
I full sheet 4 x 8 ' will run under 100$ depending on thickness you use.
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube
cliffh(at)outdrs.net
PostPosted: Wed Jan 16, 2008 11:44 am    Post subject: windscreen Reply with quote
I installed the preformed winshield from Kitfox on my Speedster.
It fit very well, only required a small bit of triming along the door posts.
Floran Higgins
Helena, Mt.
Speedster
912 ULS
