engine selection
Goto page 1, 2, 3  Next
av8r2488(at)yahoo.com
PostPosted: Sat Jan 12, 2008 6:02 am    Post subject: engine selection Reply with quote
I have been following the talk on engine choices...just another thought to add....I have a series 5 outback and will have to make an engine choice soon because of wing sweep (or lack of) and would like to know your thoughts on a Jabiru 2200 vs a 0-200 cont. Heres my thinking....the jabiru weighs in at 138 and the 0-200 at 187....ready to go...how much of an even trade is this...50 pounds for 20 hp? Now I guess we can close the weight gap by going light weight starter and alternator by about 12-15 pounds..I am still researching that...I like the simplicity of a direct drive air-cooled engine..how much does the 912 series really weigh when you factor the radiator, hoses, coolant,expansion tank...ect? Does it fall somewhere in this weight range? I had a Cessna 140 for 22 years and changed the 85 hp to an 0-200 and doubled the rate of climb but only gained 2mph in cruise. Since excess hp power is merely the ability to climb faster and cruise is a function of
aerodynamics will the weight savings be traded off for horse power? Also can the wings be set at zero sweep and the battery moved to adjust the CG? Just getting started in this as I just bought the Outback and got it home a week ago....still looking it over and wondering what I have gotten myself into here.....If there are any builders who would rather respond off list feel free to contact me direct at av8r2488(at)yahoo.com Thanks for your advice and help this is a great forum.
Never miss a thing. Make Yahoo your home page.
http://www.yahoo.com/r/hs
pwmac(at)sisna.com
PostPosted: Sat Jan 12, 2008 7:53 am    Post subject: engine selection Reply with quote
Here are some numbers to ponder:
O-200, 100 Hp (at)2750, 6.3GPH, 187#
J2200, 71Hp (at)2750, 4GPH(at)??%, 132#
J3300, 107Hp (at)2750, 6.87GPH(at)75%, 178#
R912ul 81Hp (at)5800 (2386 prop),6.3GPH, 121#
(at)5500, 67.7Hp, 5.92GPH
(at)5000, 58.4Hp, 5.1GPH
R912uls 100Hp (at)5800 (2386 prop),7.1GPH, 125#
(at)5500, 79.3Hp, 6.14GPH
(at)5000, 68.4Hp, 5.3GPH
Data from the manufacturers web links. Put your own values in the
above to compare.
BTW, Jim C have you looked at the KF4 3300 in the Greeley EAA hanger?
Paul
JohnA
PostPosted: Sat Jan 12, 2008 9:55 am    Post subject: engine selection Reply with quote
I'm putting a C-85 into my when I get it. The choice is driven by the fact
that I have a C-85 on hand - newly overhauled with the O-200 STC (crank and
pistons) installed.
I'll be putting a lighter starter and an alternator on it, so that will free
up a few pounds.
I've been curious about the Jabiru engines though. They turn up quite a bit
faster than the O-200 or C-85 necessitating a smaller prop. How does this
affect efficiency/performance?
John Alexander
Currently at sea - SBX-1
ability to climb faster and cruise is a function of aerodynamics
forum.
Beer is proof that god loves us and wants us to be happy. - Ben Franklin
John Alexander
Woodland, CA
clint_bazzill(at)hotmail.
PostPosted: Sat Jan 12, 2008 10:36 am    Post subject: engine selection Reply with quote
The O-200 is going to come in at least 100 Lbs more then the 912ULS. The 2200 is a joke (I think) many reports out that says that the 2 stroke 582 out climbs the Jabiru 2200. You cannot drive a Kitfox with that little chunk of wood out front. Before you get involved with hundreds and hundreds of hours building. Do some research and fly with these different airplanes. My take is can't get better then a 912ULS.� Ivoprop.
When you have to put a 25 lb battery in the tail to balance and sweep wings. Figure
Locate the Kitfox Pilot's Guide. Part #60000.100 Look at all the aircraft weights, specifications, add 50 lbs to all their empty weights, that works out about right. Check with these pilots and fly with them.
Clint
Subject: Re: engine selection
Date: Sat, 12 Jan 2008 09:43:42 -0800
--> Kitfox-List message posted by: "John Alexander" <alexandj(at)preachain.org>
pistons) installed.
up a few pounds.
John Alexander
> --> Kitfox-List message posted by: great bear <av8r2488(at)yahoo.com>
> forum.
Beer is proof that god loves us and wants us to be happy. - Ben Frank=======================
&g==
Float Flyr
PostPosted: Sat Jan 12, 2008 12:20 pm    Post subject: engine selection Reply with quote
The only thing you haven't factored in here is the co$t of the different
engines installed and operating. The Conti, even de-certified, is going to
cost big time for parts and fuel. You may also have to design and install a
pressure cowling to cool the cylinders. Weight wise and simplicity wise I
expect the Jab will give the best bang for the lb.(kg in Canada) And the
buck.
Noel
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
Lynn Matteson
PostPosted: Sat Jan 12, 2008 12:23 pm    Post subject: engine selection Reply with quote
Climbing isn't everything, Clint. It depends on your mission. I flew
from Michigan to California and back. Michigan to New York and back.
Michigan to upper Tennessee and back. Michigan to Oshkosh (summer and
winter) and back (no biggee). While that little chunk of wood may not
be as large or as numerous (blades) as the Rotax's use, my experience
shows me that the Kitfox WILL fly behind the Jabiru 2200...at least
mine does.
Oh yes, about the Jabiru being a joke...I laugh all the time while
I'm flying mine, so it must be true. : )
Lynn Matteson
Grass Lake, Michigan
flying w/460+ hrs
get better then a 912ULS. Ivoprop.
sweep wings. Figure
fly with them.
Clint
> From: alexandj(at)preachain.org
> To: kitfox-list(at)matronics.com
the fact
(crank and
> pistons) installed.
that will free
> up a few pounds.
quite a bit
does this
> John Alexander
make an
like
years
but
the
got it
> > forum.
&g==
http://www.matronics.com/Navigator?Kitfox-List_-
============================================================ _-
forums.matronics.com_-
contribution_-
Lynn
Kitfox IV-Jabiru 2200
N369LM
Michel
PostPosted: Sat Jan 12, 2008 1:53 pm    Post subject: engine selection Reply with quote
.. and with my Jabiru, I flew from Norway to Belgium and back, Clint.
Then to north Germany and back. Then to south Germany and back ... and
many flights to western Norway, across the mountains and several
flights to Sweden. Flying is Lynn's and my mission! Smile
Seriously, both the Rotax 582 and 912 are very good engines. Saying
anything else would be an insult for the so many happy owners. But the
Jabiru is also a nice alternative for those who ... like alternatives.
Both Lynn and I are unconventional; we fly Jabiru and we write why ...
on a Macintosh! Smile
One thing to remember, though: Rotax makes engines for any kind of
craft. Jabiru makes engines for their Jabiru aircraft. If you decide to
fit one on anything else, you're within experimental aviation. Because
I realised that and I don't know much about aviation and engines, I
made sure to install my Jabiru as close as possible to the way they
install it on their aircraft: I use a Jabiru oil cooler, a Jabiru
airbox, the Jabiru recommended instruments and a Jabiru propeller. From
the Yahoo Jabiruengines list, I think that those who have problems with
the engine are those who think they know better than the Australian
engineers and do things ... the experimental way.
Cheers,
Michel Verheughe
Norway
Kitfox 3 - Jabiru 2200
Lynn Matteson
PostPosted: Sat Jan 12, 2008 2:20 pm    Post subject: engine selection Reply with quote
why ... on a Macintosh! Smile
Must have been those left-handed cigarettes from way back when...
Lynn
(back to football)
Lynn
N369LM
av8rps
PostPosted: Sat Jan 12, 2008 3:00 pm    Post subject: Re: engine selection Reply with quote
I'm not so sure that I would believe statistics as much as I would actual owner experiences.
I'm confident if you ask around you will find the 912 owners very happy with the performance they get from their 912 Kitfoxes. I'm very happy with the performance my 80 hp 912ul gives in my Model IV (and it's an amphib!) A friend here on the list is currently flyiing a Model V Vixen that is equipped with the 912ul and an IVO inflight adjustable prop. He can climb at 1200 fpm and cruise at 125 mph! Oh yeah, his empty weight is around 775 lbs. (He loves the way it flies so much that he sold his RV-6...) Of course, the 100 hp 912s would just be that much better. (actually, significantly better. Only 20 hp more, but everyone that I know that switched from the 80 to the 100 says it feels more like 50%). There's a reason everyone is using the 912. And look around, not just in Kitfoxes.
I love the simplicity of the Jabiru 2200, but an 80 hp 912ul will outperform it due to the more efficient (geared) prop on the Rotax. And while the Jab is touted as super light, I've noticed aircraft empty weights for the Jab and Rotax on identical airframes are essentially the same. I personally think the best performance you could expect on a model V would be similar to an 0-200 powered C-150, or maybe your C-140. It is very unlikely you'll see the Supercub-like STOL performance the Outback was designed for.
And while Lynn here on the list makes a good case for the 2200, the Model V airframe is quite a bit heavier than his model IV. A good example of that is my 912ul IV at 650 pounds empty, verses my friends 912ul model V Vixen at 775 pounds. Both aircraft are similarly equipped. Yet the V weighs 125 lbs more. The 2200 would be maxed dragging that around I'm afraid. The 2200 shines on the earlier, lightweight Kitfoxes, replacing 582,s, 503's, etc.
C-85 or 0-200? I'm not a big fan of aircraft engines on the Kitfox generally as I think they just make these little airplanes just too heavy. But if I were to do one I would use either a pumped up, super light 0-235 or an IO-240, those are the only aircraft engine versions I've seen or heard of that provide good performance (and the V can handle either one). An 0-200 (or a C-85) will probably provide anemic Kitfox STOL performance. Performance is all about horsepower to weight, wing loading, and propellor thrust. The smaller aircraft engines just don't provide enough power (or thrust) per pound.
And speaking of propellor thrust, I think if we ever could test all the engines mentioned against eachother using props appropriate to our aircraft, you would see pound for pound the 912 Rotax would come out the winner. It's not just the horsepower rating of an engine. It's how efficiently you can convert that horsepower to prop thrust. A longer, slower turning propellor is just more efficient, particularly on STOL aircraft.
Fuel burn? While those fuel burn numbers posted here were apparently from company stats, I can tell you the 912 numbers posted are far from accurate. I've flown my 912ul IV amphib now for 2+ years and 300+ hours. ON FLOATS I only burn 3.2 gph average, with speeds in the 95-100 mph range. I have to run wide open (124 mph) to get my fuel burn over 5 gallons per hour. Everyone can tell me I'm nuts, but it is a proven fact that a liquid cooled engine will burn less fuel than an air cooled engine. The air cooled engine needs to use fuel to cool it (there's a reason Rutan used a liquid cooled engine to fly around the world without refueling).
One last comment, if you were to reprop that C-140 so the climb was the same as it was, I'd be totally surprised if you didn't gain speed.
Good luck with your engine decision!
Paul Seehafer
Model IV-1200 912ul Amphib
Avid Flyer Sn#1 and Sn#26
Highlander 912s taildragger
Lake Amphibian
Central Wisconsin
paul676@tds.net
shinco(at)bright.net
PostPosted: Sat Jan 12, 2008 3:06 pm    Post subject: engine selection Reply with quote
Lynn
(back to football)
Hey Guys,,I too need some help.I have a KF2 empty wt 533 lb.OK and it
has the 582 in it..I have been looking at different engines too.been
looking at the Jab 2200..BUT now I found a 100 hp.,rotax.that is out of
a KF. in texas.I can buy the engine with every thing.with it..for
$4000.00..no papers or logs..But I wanted to over haul it befor I do any
thing with it.The KF in Texas is wrecked fliped over at end of runway.
So I am wanting to know about if the weight would Be too heavy for my
KF2? my empty 533lb-950=417 left.usefull load. What does every one
think on this?? Steve Shinabery N554KF KF2 with 582 for now
PostPosted: Sat Jan 12, 2008 3:15 pm    Post subject: engine selection Reply with quote
> Lynn
> (back to football)
of a KF. in texas.I can buy the engine with every thing.with it..for
any thing with it.The KF in Texas is wrecked fliped over at end of
runway. So I am wanting to know about if the weight would Be too heavy
for my KF2? my empty 533lb-950=417 left.usefull load. What does every
one think on this?? Steve Shinabery N554KF KF2 with 582 for now
All so I only have 2,,,,6gal wing tanks,,,,,Steve Shinabery N554KF
KF2 582 for now Thanks again every one
Float Flyr
PostPosted: Sat Jan 12, 2008 3:42 pm    Post subject: engine selection Reply with quote
I don’t know whether to say thank you or not.... I expect that when I install my 912 I won’t get as short a take off as I can with the 582. I do however expect climb rate once airborne to increase. Cruise speed? Well the Kitfox, Mod III-A, a modified Mod II with the under cambered wing, isn’t designed to break any speed barriers.
Noel
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Clint Bazzill
Sent: Saturday, January 12, 2008 3:02 PM
Subject: RE: engine selection
The O-200 is going to come in at least 100 Lbs more then the 912ULS. The 2200 is a joke (I think) many reports out that says that the 2 stroke 582 out climbs the Jabiru 2200. You cannot drive a Kitfox with that little chunk of wood out front. Before you get involved with hundreds and hundreds of hours building. Do some research and fly with these different airplanes. My take is can't get better then a 912ULS. Ivoprop.
Clint
> pistons) installed.
> up a few pounds.
> John Alexander
> > forum.
&g==
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
Float Flyr
PostPosted: Sat Jan 12, 2008 5:21 pm    Post subject: engine selection Reply with quote
Michael:
Did you install a pressure cowl to direct cold air down through the cooling
fins?
Noel
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
PostPosted: Sat Jan 12, 2008 5:41 pm    Post subject: engine selection Reply with quote
A dinner says your take off will be a lot shorter. Clint
My friend told me once, only fools and crooks bet. Which one am I?
[quote] From: noelloveys(at)yahoo.ca
Date: Sat, 12 Jan 2008 20:12:00 -0330
.ExternalClass EC_p.MsoNormal, .ExternalClass EC_li.MsoNormal, .ExternalClass EC_div.MsoNormal {margin-bottom:.0001pt;font-size:12.0pt;font-family:'Times New Roman','serif';} .ExternalClass a:link, .ExternalClass EC_span.MsoHyperlink {color:blue;text-decoration:underline;} .ExternalClass a:visited, .ExternalClass EC_span.MsoHyperlinkFollowed {color:purple;text-decoration:underline;} .ExternalClass p {margin-right:0in;margin-left:0in;font-size:12.0pt;font-family:'Times New Roman','serif';} .ExternalClass pre {margin-bottom:.0001pt;font-size:10.0pt;font-family:'Courier New';} .ExternalClass EC_span.HTMLPreformattedChar {font-family:Consolas;} .ExternalClass EC_span.EmailStyle20 {font-family:'Times New Roman','serif';color:windowtext;font-weight:normal;font-style:normal;} .ExternalClass .EC_MsoChpDefault {font-size:10.0pt;} (at)page Section1 {size:8.5in 11.0in;} .ExternalClass EC_div.Section1 {page:Section1;}
I don�t know whether to say thank you or not.... I expect that when I install my 912 I won�t get as short a take off as I can with the 582. I do however expect climb rate once airborne to increase. Cruise speed?� Well the Kitfox, Mod III-A, a modified Mod II with the under cambered wing, isn�t designed to break any speed barriers.
Noel
Subject: RE: Kitfox-List: engine selection
The O-200 is going to come in at least 100 Lbs more then the 912ULS. The 2200 is a joke (I think) many reports out that says that the 2 stroke 582 out climbs the Jabiru 2200. You cannot drive a Kitfox with that little chunk of wood out front. Before you get involved with hundreds and hundreds of hours building. Do some research and fly with these different airplanes.� My take is can't get better then a 912ULS. Ivoprop.
Clint
pistons) installed.
up a few pounds.
John Alexander
> I have been following the talk on engine choices..just another
> cooled engine.how much does the 912 series really weigh when you
> forum.
&g==
0[b]
av8rps
PostPosted: Sat Jan 12, 2008 5:42 pm    Post subject: Re: engine selection Reply with quote
(Steve Shinabery wrote; been looking at the Jab 2200..BUT now I found a 100 hp.,rotax that is out of a KF in texas. I can buy the engine with every thing with it..for $4000.00..)
Steve,
Don't waste any time making up your mind on that one. That will not be easy to find again...
I believe the first Kitfox to have a 912 was a model 2. So I can't see any reason yours wouldn't accept the engine. Only thing I have to tell you is, you had better HANG ON the first time you crack that throttle! A 100 hp 912 on a model 2 is going to be a real rocketship!!! If you work at it, you could end up with a 575 lb airplane. That'll give you a 5.75 lbs per hp power loading (e.w.). That's almost 30% better than a new kitfox with a 914. So as I said, you'll have a real rocketship! Oh yeah, having the undercambered, high lift wing, you should have one awesome short field, climbing monster as well! But you will have to learn to keep a close eye on your VNE and maneuvering speeds, as you'll most likely blow by them so quickly it will scare you...
But oh, what great fun all that sounds like!!!!!
Paul Seehafer
Lake Amphibian
Central Wisconsin
paul676@tds.net
avidfox
PostPosted: Sat Jan 12, 2008 6:19 pm    Post subject: engine selection Reply with quote
Hey guys,
Take a breather.... check this out. http://www.aero-news.net/index.cfm?ContentBlockID=925e6690-ed1f-43e0-b4f7-1abc3d534a6a &
Seems to depend on specific gearbox SN's installed on 912's and 914's.
Steve Benesh
84KF.
Ok...Carry on.
PostPosted: Sat Jan 12, 2008 6:24 pm    Post subject: engine selection Reply with quote
If you don't buy it let me know. I will
Clint
Date: Sat, 12 Jan 2008 17:42:39 -0800
--> Kitfox-List message posted by: "av8rps" <paul676(at)tds.net>
Steve,
Paul Seehafer
Avid Flyer
Lake Amphibian
Central Wisconsin
paul676(at)tds.net
http://forums.matronics.com/viewtopic.php?p=157733#157733
Sbennett3(at)aol.com
PostPosted: Sat Jan 12, 2008 6:26 pm    Post subject: engine selection Reply with quote
When I learned on my 912 motor, my instructor made me use half throttle on the ground, then three quarter after stable and on the centerline. Only once airborne would I get to crack the throttle... Just be ready to use a LOT of right rudder on climb out. Steve Bennett Durham NC. 4-912ul
Start the year off right. Easy ways to stay in shape in the new year.
PostPosted: Sat Jan 12, 2008 7:00 pm    Post subject: engine selection Reply with quote
Steve,
Paul Seehafer
Avid Flyer
Lake Amphibian
Central Wisconsin
paul676(at)tds.net
Thanks Paul.That will help me decide.I do not know what model the KF
is..or the model of the rotax 912.I do not know of TT on engine,no paper
work on it..But will have logs on AF..so I still think to over haul
engine .and start out with 0 time.and new engine log book..what do U
think.plane is in Texas and I am in Ohio.Thanks again Steve Shinabery
N554KF KF 2..and the little 582 4 now
Lynn Matteson
PostPosted: Sat Jan 12, 2008 7:21 pm    Post subject: engine selection Reply with quote
Be cautious of any engine that flipped, Steve. It might have suffered
a prop strike, and might have a bent crank...a couple of MIGHT's here
is all.
Lynn Matteson
flying w/460+ hrs
Steve,
Paul Seehafer
Avid Flyer
Lake Amphibian
Central Wisconsin
paul676(at)tds.net
Lynn
N369LM
Page 1 of 3
