Floscan and IO/360
Jerry Cochran
PostPosted: Sun Feb 26, 2006 2:21 pm    Post subject: Floscan and IO/360 Reply with quote
Hey Folks,
Anyone with an injected engine have pix of their Floscan setup? This is for
the center tunnel ala RV7-7a with center boost pump. I don't see any really
good spots inside the firewall and would rather not subject it to engine heat,
although one guy in the archives mounted it just upstream from the
divider...Any and all advice, pix more than welcome.
Jerry Cochran
Wilsonville, OR
Closer & closer...
dwight(at)openweave.org
PostPosted: Sun Feb 26, 2006 3:22 pm    Post subject: Floscan and IO/360 Reply with quote
Jerry,
If I remember right (call him to verify) Don at Airflow Performance
recommends mounting it near the flow divider. I figure they have been
in the biz of making things work in the engine compartment long enough
that I'll trust their opinion. Sure saves having to shoe-horn it into
the center tunnel. I intend to find out more details next weekend when
I go down to take their "Fuel Injection 101" class as I'll have the
same issue to deal with eventually.
-- Dwight
On Sun Feb 26 17:18:55 2006, Jerry2DT(at)aol.com wrote :
Hey Folks,
Jerry Cochran
dbris200(at)sbcglobal.net
PostPosted: Sun Feb 26, 2006 6:50 pm    Post subject: Floscan and IO/360 Reply with quote
Mine is mounted between the fuel servo and the flow divider, per
instructions. I didn't see any reason to change to any other location.
Dave
Jerry2DT(at)aol.com wrote:
Hey Folks,
Jerry Cochran
Wilsonville, OR
Closer & closer...
wgill10(at)comcast.net
PostPosted: Sun Feb 26, 2006 7:53 pm    Post subject: Floscan and IO/360 Reply with quote
Hello Dwight,
Please post information on the list regarding the Floscan location after
your class.
Best regards,
Bill
PostPosted: Wed Mar 08, 2006 10:22 am    Post subject: Floscan and IO/360 Reply with quote
Since William requested the information I thought I'd float a post regarding
the suggested install location for the Floscan sensor. To give a little bit
of background, I attended the "Fuel Injection 101" class given by Airflow
Performance at their factory in Spartanburg, SC.
I'm going to inject a personal opinion here. If you don't want to read about
how much I enjoyed the FI-101 class, skip past this paragraph. Smile The class
is great and is, in my opinion, a tremendous resource. If you are considering
installing FI in your plane and don't already have good knowledge about how
fuel injection works (particularly if you are installing an Airflow or Bendix
system!) I would very much recommend the class. Don Rivera teaches the bulk
of the class (though you spend time with his technicians as well getting to
run the fuel injection components on their diagnostic flow benches too!) and
communicates both the theory and practice of fuel injection in a way that
even *I* could understand. There is classroom time, hands-on lab time, hanger
time, and social time. Don and Colleen are great hosts .. and API is a small
friendly operation that really welcomes and educates folks at these classes.
The class is enthusiastically recommended. If you have any other questions
about my experience at the class last-weekend write me off-list as this is
already starting to sound too much like an ad for API.
Ok .... soapbox mode off .... other than to say I have NO affiliation with
Airflow Performance other than as a customer and student. Smile
The easy location for installing the Floscan seems to be after the fuel
controller, but before the purge valve (or the flow divider, if you don't
use a purge valve). Regarding the recommendations to install the sensor
with certain minimum amounts of straight line in front/behind the unit and
the wires exiting strairht up ... my impression was that these constraints
should be met for those situations where you need EXTREMELY precice flow
measurements (like in a laboratory setting). For our applications that
extreme level of precision isn't going to add any significant value. Ease
of installation and servicing carries (for me, at least .. YMMV) more weight.
Therefore, as long as there is some (even relatively minimal) straight section
of tubing .. maybe even just a fittings-worth .. ahead of the Floscan it
has proven to operate just fine. The folks at API have seen (and performend)
a number of installations with these sorts of installation criteria and have
not seen any problems with the operation of the units. I'll be installing
mine as suggested ... after the fuel controller, and before my purge valve.
-- Dwight
On Sun Feb 26 22:49:27 2006, William Gill wrote :
Hello Dwight,
your class.
Best regards,
randy(at)romeolima.com
PostPosted: Wed Mar 08, 2006 11:10 am    Post subject: Floscan and IO/360 Reply with quote
I'll be installing
valve.
-- Dwight
Dwight,
Was anything said in the class about the fact that if you mount the sensor
this far downstream it will necessarily be mounted to the engine itself in
some manner and therefore subjected to significant vibration and heat? The
Floscan needs to be horizontal so that means it will likely be on top of the
cylinders somewhere near the flow divider.
I'll need to make a decision on where to mount mine in a few months. On my
last RV I mounted it behind the firewall and it worked very well.
Randy Lervold
PostPosted: Wed Mar 08, 2006 12:22 pm    Post subject: Floscan and IO/360 Reply with quote
Randy,
Those issues were brought up (by me, in fact). I'm always cautious about
being conveying, second-hand, something someone else said. For that reason
rather than start this off by saying "Don said" .. I'll couch it more in
"what I understood was" type of language. There is always the possibility
that I mis-understood (and I would be happy to be corrected) so if you have
any concerns at all ... call API and ask them straight out.
So ... what I understood was that while Floscan tends to specify optimal
installation requirements (horizontal, wires facing up, with certain minimum
amounts of straight lines leading into and out of the unit) that in practice
there is a lot more flexibility in how they can be installed and still
perform. My understanding is that they have been successfully installed
vertically with a short straight fitting leading into the sensor and a
90-degree fitting leading immediately out hanging down between two cylinders.
This seems to be in opposition to virtually ALL the requirements I have
heard for Floscan installations .... but the units reportedly worked fine
and gave good service.
Note that the class didn't focus on issues like Floscan installation, and
this was a side-discussion with Don because I was particularly interested
in hearing what his experience had been with the units. I have been trying
to decide if I need to arrange for the installation of the sensor now (which
would require finding/making space in my cabin tunnel area as others have
done), or if I can put it off until firewall-forward time. The approach
suggested by API sure opens the door to a lot of flexibility ... though
clearly if you accommodate the optimal install (horizontal, wires up, long
runs fore/aft, etc.) then you CLEARLY can't be going wrong.
I guess it is an issue of comfort level since there is disagreement about
what is the minimum install requirements for the device. API has a lot of
engine experience, but it could be argued that Floscan knows their product
too. How to decide? Beats me. Smile Don's real-world experience leads me to
feel confident in his opinion. But if you've not met Don and heard what he
has to say first-hand ... then I wouldn't blame you for coming to a totally
different opinion. (Wouldn't it be boring, though a good bit quieter, if we
all had identical opinions about things??)
-- Dwight
On Wed Mar 8 14:03:29 2006, Randy Lervold wrote :
Dwight,
Randy Lervold
Don
PostPosted: Wed Mar 08, 2006 2:31 pm    Post subject: Re: Floscan and IO/360 Reply with quote
I'll chime in here. Dwight is correct in his assessment of the Flowscan installation. Although the reason we don't like to install the device on the suction side of the engine driven pump is the fact that the Flowscan has a fairly small hole going into the transducer. By having this restriction on the suction side of the engine driven fuel pump you are inviting possible vapor problems. I know a lot of people have done it this way(mounted the Flowscan in the cabin), but to me your rolling the dice. Also on carbureted installations you can get away with some installation issues that you can't with fuel injection.
That said we have always mounted the Flowscan device after the fuel control (servo) and before the flow divider. We always install AN816-4-4D fittings in the inlet and outlet of the Flowscan. I have used a hose as short as 3" on the inlet side (all straight fittings) and a hose with a full flow 90 degree fitting on the outlet end. We have done some installations where the wires came out horizontal. These installations all worked fine. The Flowscan is never mounted directly to the engine, but hung between the hoses which are supported or supported to the engine mount with Adel clamps. The trick here is to keep the metered hose as short as possible. I have seen certified installations where the Flowscan was mounted directly to the outlet fitting on the engine driven pump or to the inlet fitting on the flow divider. I guess this works too but not my choice. I haven't had any issues with heat on the Flowscan, typically the transducer is protected with firesleeve after the installation is complete.
That's my take on the installation, if you have additional questions on this subject you can contact me at airflow2(at)bellsouth.net.
Don
PostPosted: Wed Mar 08, 2006 3:48 pm    Post subject: Floscan and IO/360 Reply with quote
I am glad you did chime in Don .. as it is better to get it straight from
the source than second-hand through me! It also is nice to know that I
was remembering the details I gave correctly. Smile
I _knew_ there was another reason you didn't like the installation in the
cabin, but could not for the life of me remember why ... and since I could
not remember the details of that point, I decided to not say anything.
I had forgotten about the issue of the Floscan adding a restriction in
the feed line and causing pressure loss and because of that possible vapor
problems. Furthermore ... remembering the vapor pressure table reminds
me that when it comes to possible vaporization of fuel pressure (more,
rather than less) is your friend.
See, I did learn something (I hope!). Smile
-- Dwight
do not archive ... as this is just a "me too" followup post ...
installation. [ ... snip ... ]
PostPosted: Wed Mar 08, 2006 3:54 pm    Post subject: Floscan and IO/360 Reply with quote
Don,
Great information here and sounds like you have a lot of experience. I
would appreciate any pictures you might have concerning this
installation as well as from others that have done it this way. Thanks.
Best regards,
Bill Gill
RV-7 avionics & finish
Lee's Summit, MO
