darrellhaas(at)gmail.com Guest
Posted: Wed Jan 16, 2008 9:12 pm Post subject: FAA certification |
OK team-Help! I have searched the archives and I'm still confused by an email I got from the FAA. I wrote: I have recently purchased a Zenith Zodiac 601XL fuselage kit and will be constructing it at home in Fairview, Oregon. I am unsure of the requirements for certification/inspection of this light sport homebuilt aircraft. Any advice you can give will be appreciated. His (FAA) response: I looked into the Zodiac home web page and saw that your aircraft may qualify as a light sport aircraft by weight and operating speeds, but am not sure which way you want to proceed with certification. To be eligible for the experimental light sport certification, the aircraft must qualify under Special Light Sport Aircraft regulations, and must meet a consensus standard including instructions from the manufacturer for construction, maintenance, inspection, and operation of the aircraft.
If you wish to certificate as an Experimental Amateur-built aircraft, a different process and set of regulations are followed. Please let me know which avenue you wish to pursue, and I can help provide the proper information for certification.
I am a private pilot that wants to fly without all the money and red tape to get a medical every couple years. I want to fly with my drivers licence for my medical and be my own repairman and mechanic. This all seems like double talk. Advice?
Thanks for listening.
Darrell
psm(at)att.net Guest
Posted: Wed Jan 16, 2008 9:32 pm Post subject: FAA certification |
Hi Darrell,
You can only have your plane certified as Experimental-Amateur Built. It is not possible to get an E-SLA since there is not a corresponding S-LSA from the same manufacturer.
The good news is this doesn't make any difference with regard to who can fly it. The idea of flying with Sport Pilot limitations is a good one for many people. It doesn't matter what kind of airworthiness certificate the plane has. It just matters that it meets the performance and equipment requirements for an LSA.
Have fun,
Paul
XL fuselage
At 09:08 PM 1/16/2008, you wrote:
[quote]If you wish to certificate as an Experimental Amateur-built aircraft, a different process and set of regulations are followed.
Darrell
Posted: Thu Jan 17, 2008 5:27 am Post subject: FAA certification |
simple:
register EAB, then fly off 40 hours and go to FSBO to get repair ticket
register ELSA, fly of less hours but the take class 14 hours to repair ticket
thats bout it.
Juan
Gig Giacona
Posted: Thu Jan 17, 2008 6:44 am Post subject: Re: FAA certification |
And to register as E-LSA he has to finish it before the end of this month.
| amyvega2005(at)earthlink. wrote: | simple:
thats bout it.
Juan
601XL Under Construction
randy(at)rjhebertassoc.co Guest
Posted: Thu Jan 17, 2008 8:05 am Post subject: FAA certification |
I have seen this comment before but still have questions.
I understand that the deadline is for converting "fat ultralights" to
the E LSA but that new kit/plans builds will be eligible for E LSA as
they are completed.
Can someone guide me to the regs that will help clarify it for me?
I had planned to register mine (701) as an E LSA.
I still cannot find definitive documentation.
Randall J Hebert
Randall J Hebert & Associates, Inc
Consulting Civil / Structural Engineers
Lafayette, Louisiana
PH 337-261-1976 - FX 337-261-1977
Posted: Thu Jan 17, 2008 8:14 am Post subject: FAA certification |
This is what I am basing my opinion on
http://www.sportpilot.org/learn/lsa/likely_lsa.pdf
Randall J Hebert
passpat(at)aol.com Guest
Posted: Thu Jan 17, 2008 8:17 am Post subject: FAA certification |
you need to read FAA Order 8130.2f with change 3 this has all of the info with in
Pat
AB-DAR
Gig Giacona
Posted: Thu Jan 17, 2008 9:03 am Post subject: Re: FAA certification |
That's the thing Randy. Right now Zenith doesn't produce an S-LSA. One of the requirements for E-LSA is that it is a kit version of an S-LSA. The exception for this is the Fat Ultralight exemption that ends this month. And from reading EAA releases on the issue if you haven't already gotten it done now there is a real good chance it isn't going to get done.
Call the EAA they are very helpful on stuff like this.
| randy(at)rjhebertassoc.co wrote: | I have seen this comment before but still have questions.
they are completed.
Randall J Hebert
Posted: Thu Jan 17, 2008 10:34 am Post subject: FAA certification |
Thanks Gig and Pat
By the way I tried to follow the Order 8130-2f Chg 3 but it got lost in
the translation.
i.e. I lost patience. Yes I will call EAA
Randall J Hebert
bryanmmartin
Posted: Thu Jan 17, 2008 1:13 pm Post subject: FAA certification |
The Zodiac can be registered as an experimental amateur built or it can
be registered as an E-LSA under the "fat ultralight" clause of the LSA
regulations. However, the deadline for the "fat ultralight" clause is
January 31st of 2008, so you probably won't be able to go that route
because you won't be able to get the airworthiness inspection done by
the end of this month; you will have to register it as an E-AB. In
either case, as long as you register it with a gross weight of 1320
pounds or less, it will meet the limitations of the LSA rule and can be
flown under the sport pilot rules. A sport pilot can fly any plane with
a Standard, Primary, E-AB or LSA airworthiness certificate as long as it
meets the limitations of the LSA rule and has continued to do so since
its original certification.
Check out the EAA website (www.eaa.org), find a local chapter, keep a
good builder's log with photographs of you building the kit and use the
EAA technical councilor program. You don't really have to get the FAA
involved until you are ready to schedule an airworthiness inspection. As
the primary builder of an E-AB, you will automatically qualify for the
repairman certificate for that plans, you may be able to submit the
application for that certificate at the time of your airworthiness
inspection. The process really isn't all that complicated. Don't forget
about the requirements for registering an aircraft in your state,
including tax obligations, if any.
Darrell Haas wrote:
| Quote: | OK team-Help! I have searched the archives and I'm still confused by an
Fairview, Oregon. ...
Darrell
Bryan Martin
Zenith 601XL N61BM
Ram Subaru, Stratus redrive
_________________ --
Bryan Martin
do not archive. |
bryanmmartin
Posted: Thu Jan 17, 2008 1:34 pm Post subject: FAA certification |
Go to: http://www.matronics.com/searching , choose the Zenith archives
and enter the search string "E-AB vs. E-LSA", you'll find an earlier
post I made citing the regulations. I paraphrased the regulations in my
post but included the FAR paragraph numbers if you want to look up the
actual rules yourself.
Basically, if you already bought your CH 701 kit, you will not be able
to register it as an LSA unless you can get it done by the end of this
month. You will have to register it as an E-AB. Even as an E-AB, the
plane will still meet the limitations of the LSA rule and can be flown
At some future date Zenith may choose to build a consensus standard
compliant CH701 S-LSA and then they can offer E-LSA kits based on that
prototype. Until then, no CH701s can be certificated as E-LSA after the
end of this month. Zenith Aircraft hasn't announced any intention of
offering an E-LSA version of the CH701.
Randall J. Hebert wrote:
they are completed.
Bryan Martin
Zenith 601XL N61BM
Bryan Martin
do not archive. |
Posted: Thu Jan 17, 2008 1:43 pm Post subject: FAA certification |
Thank you all for your great information. I love this list!
Darrell
On 1/17/08, Bryan Martin <bryanmmartin(at)comcast.net> wrote:
> Darrell
Bryan Martin
Zenith 601XL N61BM
dragonfuel(at)aol.com Guest
Posted: Thu Jan 17, 2008 4:07 pm Post subject: FAA certification |
| Quote: | | Zenith may choose to build a consensus standard compliant CH701 S-LSA and then they can offer E-LSA kits based on that prototype. |
Bryan,
I don't think it is likely that Zenith will do that. #1 they haven't built finished production type planes that I recall (within the Zenair family of companies, AMD does that), #2 they are selling plenty of 701 kits as it is, #3 they would pick up a significant amount of manufacturers liability by certifying a consensus standard 701 (and by the way have you noticed how "non-standard" many of the 701 builders are?). Also, of course, you have the fact that AMD is selling a similar SLSA "Patriot".
I would think it more possible that Zenair would work out some way to sell a consenus standard ELSA Zodiac 601XL kit. After all AMD builds a production SLSA Zodiac now under license from Zenair and Zenith builds the Zodiac 601XL kits also under Zenair license.
In either case it would have to make some financial sense to all the companies. Licensing a consenus standard kit would not come without financial consideration to cover the inevitable manufacturers liability, plus some profit. Without that, ELSA as we know it is almost at an end.
Cheers,
Bob Archibald
Dragonfly Aviation
CH601XL/125hp Lyc/Dynons/400 hrs
More new features than ever. Check out the new AOL Mail!
bryanmmartin
Posted: Thu Jan 17, 2008 5:06 pm Post subject: FAA certification |
I agree, Zenith isn't likely to offer an E-LSA version of the C701. I
was just indicating what would be required for getting an E-LSA
certificate for a CH701 and why it won't be possible to get that
certification on any current kit after this January.
My main point is that the airplane doesn't need an LSA certificate to be
eligible for a sport pilot to fly it, the E-AB certificate will work
just as well for that purpose. There still seems to be a lot of
confusion over that point.
dragonfuel(at)aol.com wrote:
Bryan,
Bryan Martin
Zenith 601XL N61BM
Bryan Martin
do not archive. |
Posted: Thu Jan 17, 2008 7:39 pm Post subject: FAA certification |
Sport Pilot News > News Archive 01/16/08 - TIME IS RUNNING OUT FOR E-LSA CONVERSION
EAA continues to monitor the backlog of experimental light-sport aircraft that have been registered, but not yet certificated, with the January 31, 2008, deadline for doing so fast approaching.
On December 17, 2007, EAA submitted an exemption request asking the FAA to extend that deadline for people who have submitted their aircraft registration applications, but for whatever reason will be unable to certificate the aircraft in time. The agency (FAA) has not indicated whether or not the exemption will be approved, so it is exceedingly important that affected individuals complete the entire registration and certification process by the January deadline.
If the FAA approves EAA’s exemption petition, then owners of converting E-LSA aircraft would have until January 31, 2008 (received-by date) to submit their aircraft registration application to the FAA. They would then be authorized to complete the aircraft’s airworthiness certification inspection in the spring/summer of 2008. EAA needs to stress that the FAA has not approved the exemption yet, so don’t stop or alter your plans to register and certify your E-LSA by the January 2008 deadline.
If you need to obtain the required Aircraft Registration Application, AC Form 8050-1, be aware it is not available as an on-line document. The form can only be obtained by visiting or calling:
If you do not have a registration application form yet, you must factor the amount of time required to obtain the form, plus the time to complete it, plus the time needed to get it to the aircraft registration office – to make sure that it’s received by January 31, 2008. For those just now submitting their aircraft registration application, it’s highly recommended you use an overnight delivery service to send the information to the Aircraft Registration Branch at this address:
FAA Aircraft Registration Branch, AFS-750
Registry Building Room 118
6425 South Denning
Oklahoma City, OK 73169-6937
