larywil(at)comcast.net Guest
Posted: Sat Jan 19, 2008 7:36 am Post subject: Removing Tanks |
Hello again,
I mis-worded my question. It should have said,"how do you remove a tank?"
I think most of us would have a tough time working on a plate with
the tank still on the wing. It could be done, maybe, but I think it's
time for me to take the tank off and do a good job on the leaks,
replace the sender, and comply with the fuel sender SB. So... since I
didn't build my RV-4, I am asking for advice in removing the tank.
I'm pretty sure I'll have to use a razor blade around certain edges
to avoid chipping the paint. I know to drain the tank. Are there any
other pitfalls? Any other tips?
The rest of the advice about removing and replacing the plate(s), I
have printed out in LARGE PRINT on my work sheets. I should have
asked for that advice also, but my first objective is to remove the tank.
To those of you who have posted suggestions, keep on doing it! There
are plenty of us doing this for the first time, and there is plenty
of up-to-date solutions that we are unaware of. The archives are
great, but it can be like a safari through the Congo trying to find
what you really need. Thanks again.
Louis
Posted: Sat Jan 19, 2008 3:04 pm Post subject: Removing Tanks |
Louis Willig wrote:
Hello again,
I think most of us would have a tough time working on a plate with the
tank still on the wing. It could be done, maybe, but I think it's time
for me to take the tank off and do a good job on the leaks, replace the
sender, and comply with the fuel sender SB. So... since I didn't build
my RV-4, I am asking for advice in removing the tank. I'm pretty sure
I'll have to use a razor blade around certain edges to avoid chipping
the paint. I know to drain the tank. Are there any other pitfalls? Any
other tips?
The rest of the advice about removing and replacing the plate(s), I have
printed out in LARGE PRINT on my work sheets. I should have asked for
To those of you who have posted suggestions, keep on doing it! There are
plenty of us doing this for the first time, and there is plenty of
up-to-date solutions that we are unaware of. The archives are great, but
it can be like a safari through the Congo trying to find what you really
need. Thanks again.
Louis
I had to disconnect the fuel line on both ends so it could be retracted
into the fuselage slightly. I had to move the tank toward the fuselage
slightly to get it off and there's the back flange of the inboard rib to
deal with also; that's why I had to move the fuel line.
I used popsicle sticks to spread the back flanges slightly so that the
dimples wouldn't hang on the countersinks in the spar flanges. A thin
blade like a small putty knife can be used to lift the flanges to insert
the sticks.
It was a little bit of a chore to get the tank started, but fairly easy
after that to remove it. I think I used a small pry bar between the back
of the tank & the spar to get it started. I did it alone, with a
rigged-up padded platform under the tank in case it tried to fall.
I think that I used thin cardboard or plastic sheet to protect the spar
flanges when I re-installed the tank. Hard to explain in words, but it
was easier to spread the flange & insert multiple sticks to remove the
tank & easier to use a continuous strip of sheet material while pushing
the flanges back over the spar during re-installation.
Hope that helps,
Charlie
flying -4, -7 finish kit on order
