Replacing Hoses on a Rotax
Dennis.Kirby(at)kirtland.
PostPosted: Thu Jan 24, 2008 1:42 pm    Post subject: Replacing Hoses on a Rotax Reply with quote
Kolb Friends -
The time has come for me to replace some of the rubber fluid lines on my
912ul. This would include the fuel, oil, and coolant hoses. These are
the original hoses that came with the engine from the factory over 5
years ago, and they are showing signs of deterioration (cracks, splits,
etc.)
Looking in the Rotax catalog, I found the following prices on
replacement sets of fluid lines:
"Fuel Hose Assembly" - $223.
"Oil Tube" - $56.
"Coolant Hose" - $53.
Yikes!
Are there any acceptable "Auto Parts Store equivalent" hoses that I can
use instead?
When Rotax warns us to only use "Genuine Rotax parts" on our engines, I
can understand if they're referring to the hardware. But it seems that
fuel hoses, etc., could be replaced with "generic" products, and not
compromise the integrity or reliability of the engine. Does anyone
agree? Has any body done this?
Thanks for your opinions -
Dennis Kirby
Cedar Crest, NM
PostPosted: Thu Jan 24, 2008 2:26 pm    Post subject: Replacing Hoses on a Rotax Reply with quote
use instead?
Dennis Kirby
Dennis K:
I use 1" ID heater hose, 1/4" black neoprene fuel line. I like Gates, but
other name brands are just as good.
Oil line I get from Travis at TNK. He has access to that nice blue line.
Remember, the oil line is primarily vacuum on the intake side and 3 to 5 psi
on the outlet side. I think the most important factor is hose that can
handle the temps, up to 300F working temp, not ultimate, and will hold its
shape in bends without crimping. Give Travis a call on the blue hose. If
you do, you can join the blue oil hose gang at Monument Valley in May. It
is almost as prestigeous as the Black Hat Gang at MV. Wink
mkIII with blue oil hose and black hat.
