sportav8r(at)gmail.com Guest
Posted: Fri Jan 18, 2008 1:42 pm Post subject: APRS tracking technology as alternative to SPOT |
I just replaced my APRS tracker in the RV with a more powerful 8 watt model, as the 300 mW unit was giving erratic results. If everything is programmed and calibrated properly, and if I can get the wheels to roll through the snow on the turf strip, I will be conducting a trial flight is a few minutes to check it out.
The following link should enable tracking in real time. If all goes well, the last recorded flight track from November will be replaced with current data. [url=http://aprs.fi/?call=N30yd&mt=m&z=11&timerange 1600] http://aprs.fi/?call=N30yd&mt=m&z=11&timerange 1600[/url]
I should be airborne by 16:50 EST.
-Stormy N30YD / N4DLN
acepilot(at)bloomer.net Guest
Posted: Fri Jan 18, 2008 2:01 pm Post subject: APRS tracking technology as alternative to SPOT |
I seeeeee you!!
Scott N0EDV
http://corbenflyer.tripod.com/
Gotta Fly or Gonna Die
Building RV-4 (Super Slow Build Version)
Bill Boyd wrote:
| Quote: | I just replaced my APRS tracker in the RV with a more powerful 8 watt
with current data.
<http://aprs.fi/?call=N30yd&mt=m&z=11&timerange 1600>
Posted: Fri Jan 18, 2008 2:15 pm Post subject: APRS tracking technology as alternative to SPOT |
Replying to my own post, here- too many things wrong with the flight so I stood down. Garmin 296 wouldn't lock onto more than 2 birds, and thought the local time was 11:36 AM, so it acts like the internal battery is going south (flown as recently as last week) - but the unit powers up fine on the bench using just its own battery, as I write this. Directional control on the snow was awful, even though there was lots of grass showing - just too much cover. I think I packed the wheel pants with snow in short order. I couldn't even hold brakes against a 1600 rpm run-up without sliding. When I was about 50% beyond my normal rotation point and still hadn't broken ground, weaving like a taildragger pilot in a crosswind (gulp!) I balked the takeoff. Barely had enough braking action to execute a 180 within the width of the strip.
This is disappointing, since I wanted to fly tonight and wanted to demo the APRS, but I guess I get an "A" for decision making. Even if I had had hull coverage I don't think I could have felt good about completing that takeoff, knowing I'd have to return to that same runway in a few minutes and try to stop safely, possibly with frozen brake pads. The weather is supposed to turn here tonight, so that was probably my one window to fly for the next week or two. Snow expected again tomorrow and a deep freeze on top of that. Should stay mushy out there till about April even if the snow dissipates. Some days are like that.
I'll post a heads-up if /when I try the airborne APRS again. Meanwhile I'm going to have harsh words with my 296.
-Stormy
On Jan 18, 2008 4:37 PM, Bill Boyd < sportav8r(at)gmail.com (sportav8r(at)gmail.com)> wrote:
[quote]I just replaced my APRS tracker in the RV with a more powerful 8 watt model, as the 300 mW unit was giving erratic results. If everything is programmed and calibrated properly, and if I can get the wheels to roll through the snow on the turf strip, I will be conducting a trial flight is a few minutes to check it out.
Posted: Fri Jan 18, 2008 2:16 pm Post subject: APRS tracking technology as alternative to SPOT |
You are looking at data from November 3rd, unfortunately
-Stormy
On Jan 18, 2008 4:57 PM, Scott <acepilot(at)bloomer.net (acepilot(at)bloomer.net)> wrote:
[quote] --> RV-List message posted by: Scott <acepilot(at)bloomer.net (acepilot(at)bloomer.net)>
I seeeeee you!!
Scott N0EDV
with current data.
[url=http://aprs.fi/?call=N30yd&mt=m&z=11&timerange 1600]http://aprs.fi/?call=N30yd&mt=m&z=11&timerange 1600[/url]
<[url=http://aprs.fi/?call=N30yd&mt=m&z=11&timerange 1600] http://aprs.fi/?call=N30yd&mt=m&z=11&timerange 1600[/url]>
cjensen(at)dts9000.com Guest
Posted: Fri Jan 18, 2008 2:22 pm Post subject: APRS tracking technology as alternative to SPOT |
Mmmmm, I clicked on the link and didn't see anything other than the map of the Lexington area...what am I missing?
Chuck Jensen
Posted: Fri Jan 18, 2008 2:48 pm Post subject: APRS tracking technology as alternative to SPOT |
Not sure, Chuck. Java scripts, maybe?? I just clicked on it and it displays a beautiful depiction of my figure-8 over Lexington. Unfortunately, that's not today's flight, which, as I posted a while ago, was aborted due to snow pack on the runway and lack of tundra tires on the RV
The 296 straightened itself out about 5 minutes after I lied to it and told it that I had stored it without batteries. It now shows correct local time and position. Pretty finicky for a $1400 unit that wants to moonlight as a doorstop. If it continues to misbehave I'm going to stop feeding it electrons and make it come to heel.
-Stormy
On Jan 18, 2008 5:18 PM, Chuck Jensen <cjensen(at)dts9000.com (cjensen(at)dts9000.com)> wrote:
[quote] --> RV-List message posted by: "Chuck Jensen" <cjensen(at)dts9000.com (cjensen(at)dts9000.com)>
Chuck Jensen
rv7(at)b4.ca Guest
Posted: Fri Jan 18, 2008 2:51 pm Post subject: APRS tracking technology as alternative to SPOT |
That's pretty neat.
So what's the coverage like? I think someone's previous post said that the
range can be 100 miles, and the repeaters would take it from there? How
dense are the repeaters?
The main benefits of the SPOT system right now are the GPS coverage
(effectively unbroken coverage across North America), and Satellite Phone
uplink (ditto).
-Rob
Posted: Fri Jan 18, 2008 4:47 pm Post subject: APRS tracking technology as alternative to SPOT |
Dangit! No wonder there's no snow on the ground! Do Not Archive
Scott
Bill Boyd wrote:
| Quote: | You are looking at data from November 3rd, unfortunately
-Stormy
I seeeeee you!!
Scott N0EDV
watt
wheels to
trial
> with current data.
> < http://aprs.fi/?call=N30yd&mt=m&z=11&timerange 1600
<http://aprs.fi/?call=N30yd&mt=m&z=11&timerange 1600>>
> Regards,
Posted: Fri Jan 18, 2008 7:13 pm Post subject: APRS tracking technology as alternative to SPOT |
The repeater infrastructure is fairly good all across the country, I'm told. For aerial use, the repeater coverage is not really an issue because the line of sight is so good (in the absence of mountainous terrain obstructions.) All we need for internet tracking is to have the position packet make it to a single I-Gate station that posts it to the APRS web server. That's much simpler in many ways than trying to send a position report from one terrestrial station to another by a series of digipeater hops. I use a path of WIDE2-2 from the plane, which gives me 2 hops before the message dies. If any of the stations involved in either hop is an I-Gate, I'm golden - my packet is stored on the server from then on, to be recalled by whatever viewer one might use - even months later.
The drawback to APRS is that there is no closed loop or acknowledgment of the packet sent back to the originating station, so one must simply hope that some of the blind (unproto) packets have gotten through. Make sense?
I think the only real advantage that APRS might have over SPOT is the cost (free once you have the tracker). Well, fully implemented APRS, which I don't have and don't plan to set up in the plane, would allow two-way text messaging - I think the SPOT only allows one way.
-Stormy
On Jan 18, 2008 6:17 PM, Rob Prior <rv7(at)b4.ca (rv7(at)b4.ca)> wrote:
[quote] --> RV-List message posted by: "Rob Prior" <rv7(at)b4.ca (rv7(at)b4.ca)>
On 13:37 2008-01-18 "Bill Boyd" <sportav8r(at)gmail.com (sportav8r(at)gmail.com)> wrote:
That's pretty neat.
rv7(at)b4.ca Guest
Posted: Fri Jan 18, 2008 8:29 pm Post subject: APRS tracking technology as alternative to SPOT |
On 19:07 2008-01-18 "Bill Boyd" <sportav8r(at)gmail.com> wrote:
| Quote: | I think the only real advantage that APRS might have over SPOT is the
That's correct, and it's the one minor downside to the SPOT system.
Messaging is one-way, and you have only three messages you can send ("I'm
OK", "Friends, I need help", and "Send the cavalry", effectively). The
major downside, as you point out, is the yearly cost.
What's the weight of the hardware necessary for APRS? How easy would it be
to remove from a downed plane if you needed to and/or decided to leave the
crash site? One benefit of SPOT over ELT is that if you need to move, you
can bring the beacon with you and trackers will know that you've moved and
know where you are.
-Rob
Posted: Sat Jan 19, 2008 7:11 am Post subject: APRS tracking technology as alternative to SPOT |
I'm guessing the APRS hardware I am using (gps and 8 watt tracker, with its homemade circuit-board (copperclad) enclosure) wieghs about 3 ounces or so. Without an external battery, there is no point in removing it from the ship, and I have not made provisions for that. If your crash site is too remote to allow people to see the wreckage from town, it may also be too remote to hit a digipeater from the ground with low power there is no way to tell but to try it, and with transmit-only hardware, no way to know if you are being digipeated. It certainly has its limits.
-Stormy
On 19:07 2008-01-18 "Bill Boyd" <sportav8r(at)gmail.com (sportav8r(at)gmail.com)> wrote:
ronlee(at)pcisys.net Guest
Posted: Sat Jan 19, 2008 8:24 am Post subject: APRS tracking technology as alternative to SPOT |
A possible serious negative of APRS is coverage in mountainous/western
areas.
I think that Spot is going to win out in coverage.
As far as 2-way texting...it sounds good but to me the most important
element
is notification of the need for help/rescue.
Plus Spot is "off the shelf"
Ron Lee
d-burton(at)comcast.net Guest
Posted: Sat Jan 19, 2008 8:40 am Post subject: APRS tracking technology as alternative to SPOT |
One consideration if you don't think the continued subscription costs of the
Spot system sounds attractive is to rent one when taking a trip that puts
you over wilderness areas. Satellite phone stores rent phones for trips
like this and they also rent Spots... your choice.
DaveB
Posted: Sun Jan 20, 2008 12:46 pm Post subject: APRS tracking technology as alternative to SPOT |
I'm going to try again, Orville
The snow is sublimating in the sunshine and 22 degree wind, and I think I can get airborne without packing the wheelpants with slush. It might be a long downhill takeoff roll, with a 20 knot tailwind, but the landing will be almost a hover.
I hope to be up at altitude by 3:00 EST. Here's the link again: [url=http://aprs.fi/?call=N30yd&mt=m&z=11&timerange 1600]http://aprs.fi/?call=N30yd&mt=m&z=11&timerange 1600[/url]
Hopefully we will see some new data points appearing in real-time. This stronger transmitter has not been recalibrated as-installed for clean output, proper deviation, etc except at the factory, so I am hopeful, but not guaranteeing anything.
If this works in googlemaps, try clicking the google earth KML feature to see a 3D flight path depiction in real time (will SPOT do that??)
-Stormy
fingers crossed on the Garmin 296, too.
Posted: Sun Jan 20, 2008 1:18 pm Post subject: APRS tracking technology as alternative to SPOT |
Well, I'm not selling the bicycle shop, that's for dang sure. Flight to 7200' MSL and not a single ping- something is very wrong. I'll be back---!
-Stormy
On Jan 20, 2008 2:46 PM, Bill Boyd < sportav8r(at)gmail.com (sportav8r(at)gmail.com)> wrote:
[quote]I'm going to try again, Orville
I hope to be up at altitude by 3:00 EST. Here's the link again: [url=http://aprs.fi/?call=N30yd&mt=m&z=11&timerange 1600]http://aprs.fi/?call=N30yd&mt=m&z=11&timerange 1600 [/url]
-Stormy
Larry Bowen
Posted: Sun Jan 20, 2008 2:43 pm Post subject: APRS tracking technology as alternative to SPOT |
Hang in there. We're watching...
Larry Bowen
Larry(at)BowenAero.com (Larry(at)BowenAero.com)
http://BowenAero.com
On Jan 20, 2008 4:07 PM, Bill Boyd <sportav8r(at)gmail.com (sportav8r(at)gmail.com)> wrote:
[quote]Well, I'm not selling the bicycle shop, that's for dang sure. Flight to 7200' MSL and not a single ping- something is very wrong. I'll be back---!
-Stormy
| Quote: | I'm going to try again, Orville
-Stormy
_________________ Larry Bowen
RV-8 SOLD,
RV-7QB in progress... |
