udog1(at)earthlink.net Guest
Posted: Sun Jan 20, 2008 1:49 pm Post subject: Mechanical Fuel Pump Troubleshooting |
I am attempting to start an O-360 engine on an RV-4 for the first time since installation. The engine has been previously run on a test stand with no problems. The airplane has a Facet electric boost pump (per Vans blueprints) and the stock Lycoming mechanical fuel pump and MA5 carb. I can not obain any fuel pressure or fuel flow through the mechanical pump using only the boost pump. The boost pump provides adequate pressure and flow at the mechanical pump inlet fitting but there is only a trickle of fuel flow through the pump. What possible mechanical pump failure mode would prevent the boost pump from supplying the engine? I had to replace the fuel pump vent fitting - could a blocked fuel pump vent prevent flow through the pump? Any other troubleshooting ideas before I go through the pain of removing the pump - very difficult on an RV-4!
Thanks for any helpful ideas
Rob
vft(at)aol.com Guest
Posted: Sun Jan 20, 2008 9:13 pm Post subject: Mechanical Fuel Pump Troubleshooting |
Rob,
There are two check valves in the pump. One each on the inlet and outlet. You should be able to blow through the inlet side but not the other way. It's possible one or both are stuck.
Danny Melnik
F1 N14ZM
Rocket Factory
Melbourne, FL
