richard.goode(at)russiana Guest
Posted: Wed Jan 23, 2008 7:07 am Post subject: Difference between Series I and II |
I believe that the changeover was 1982.
Both types are totally interchangeable, and both produce 360hp.
The changes are quite significant - for example the cylinders are different, and there are a number of internal changes.
Perfectly possible to change Series I to Series II, but at considerable expense.
External identification is very easy, because Series II has the large 5 inch circular plate on the top port side of the gear box.
Richard Goode Aerobatics
Rhodds Farm
Lyonshall
Herefordshire
HR5 3LW
United Kingdom
Tel: +44 (0) 1544 340120
Mob: +44 (0) 7768 610389
Fax: +44 (0) 1544 340129
www.russianaeros.com
dsavarese(at)elmore.rr.co Guest
Posted: Wed Jan 23, 2008 7:21 am Post subject: Difference between Series I and II |
I forgot about the plate on the nose case Richard. Thanks for adding that.
Dennis
tjyak50
Posted: Wed Jan 23, 2008 7:24 am Post subject: Re: Difference between Series I and II |
Between the Type I and Type II you can also see an external difference in the Cooling Fins on the cylinders. On the Type II it will appear that every other fin is recessed. A side by side comparison makes this pretty obvious.
Additionally there are differences in the valve rocker box area that are not interchangeable (valve spring cups for example).
The pistons are a different mass, and the wrist pins and pin caps are different design and mass. However the total mass is identical.
Tj
Posted: Wed Jan 23, 2008 7:39 am Post subject: Difference between Series I and II |
I believe the photos that I posted show the fin differences.
Dennis
MarkWDavis
Joined: 03 Jan 2007 Posts: 104 Location: Syracuse, KS
Posted: Wed Jan 23, 2008 7:49 am Post subject: Difference between Series I and II |
Dennis and Richard,
Any difference internally or in the durability of the two? Are all accessories interchangeable between the two series?
Mark Davis
N44YK
tjyak50
Posted: Wed Jan 23, 2008 7:59 am Post subject: Re: Difference between Series I and II |
between some M14 variants there is a difference in how oil is transmitted through the accessory case and these parts are not transferable.
Tj
Posted: Wed Jan 23, 2008 8:27 am Post subject: Difference between Series I and II |
The Russians were very through,and had the money to do the work well,so it is a reasonable assumption the the SeriesII is an improvement.
All accessories are interchangeable.
Richard
Rhodds Farm
Lyonshall
Hereford
HR5 3LW
United Kingdom
tjyak50
Posted: Wed Jan 23, 2008 9:04 am Post subject: Re: Difference between Series I and II |
ALL accessory cases are not.
jan.mevis(at)informavia.b Guest
Posted: Wed Jan 23, 2008 1:34 pm Post subject: Difference between Series I and II |
Thanks to all for the replies ! One specific question: is it possible to
upgrade a series I to an M14PF ?
Jan
Posted: Wed Jan 23, 2008 2:45 pm Post subject: Difference between Series I and II |
Yes, all it takes are Ben Franklins.
Doc
Posted: Wed Jan 23, 2008 3:14 pm Post subject: Difference between Series I and II |
Ummm, not so sure of that Doc. I believe that it might have been
recommended not to use Gen 1 engines for a PF upgrade. I think Gen II
types are what were preferred. Richard Goode would know for sure of
course. I am just getting that feeling that I have heard something
about a limitation somewhere in the past.
Mark Bitterlich
N50YK
