		Steve Boetto
				 Posted: Tue Jan 29, 2008 6:06 pm    Post subject: "clip-wing Firestar/Slingshot wannabe" |
				Oh, changed the Tagline in case anyone was interested in your  project.
  steve
   In a message dated 1/29/2008 4:43:37 P.M. Eastern Standard Time,  1planeguy(at)kilocharlie.us writes:
   	  | Quote: | 	 		  | "clip-wing Firestar/Slingshot  wannabe" |
 Start the year off right.  Easy ways to stay in shape in the new year.
		Steve Boetto
   	  | Quote: | 	 		  | "clip-wing Firestar/Slingshot wannabe" | 	   Thanks for posting the pictures Jeremy,
  How short are you going on the wings
  What kind of struts
  what kind of engine
  What is that frame hanging from the ceiling?
  Steve  B
 Firefly 007/Floats with small unsafe wings (-:
 do not  archive
		1planeguy(at)kilocharlie. Guest
				 Posted: Wed Jan 30, 2008 10:44 am    Post subject: "clip-wing Firestar/Slingshot wannabe" |
				 	  | Quote: | 	 		       "clip-wing Firestar/Slingshot wannabe"
  What kind of struts
  what kind of engine
  Steve B
 <snip>
 Wings are going to be 22' just like Firefly/Slingshot...7 full ribs
 instead of the 5 on a Firefly.  Single lift struts.  incidence and
 decalage rigged like the Slingshot to get the 3 point stance up with the
 lower AOA of the wing.  Flip-over Slingshot-like canopy.  Will have
 longer than stock Firestar legs...most likely straight like the Kolbra
 instead of bent like the Slingshot.  Have a 503 to put on it but am
 trying to talk myself into the HKS.
 Jeremy Casey
 The cage was a Kitfox Series 5 project that I decided not to build...got
 my money back out of it and sent it on its way.
		Steve Boetto
				 Posted: Wed Jan 30, 2008 11:50 am    Post subject: "clip-wing Firestar/Slingshot wannabe" |
				In a message dated 1/30/2008 1:44:58 P.M. Eastern Standard Time,  1planeguy(at)kilocharlie.us writes:
   	  | Quote: | 	 		       Have a 503 to put on it but am
 trying to talk myself into the  HKS. |
  Sounds good, did you make provisions for the added weight of the HKS?
    Steve    B
 Firefly 007/Floats
 do not  archive
		ElleryWeld(at)aol.com Guest
				 Posted: Wed Jan 30, 2008 5:10 pm    Post subject: "clip-wing Firestar/Slingshot wannabe" |
				Jeremy
  I have installed and set up two HKS Engines  I  dont think you will be disapointed with one on your kolb there a very nice 4  stroker only my opinion
   I had another airplane N941LA get its  airworthyness today  6 more planes to finish now
  Ellery in Maine
   	  | Quote: | 	 		  -->    Kolb-List message posted by: Jeremy Casey    <1planeguy(at)kilocharlie.us>
     What kind of struts
  what kind of engine
  Steve B
  do not    archive
 <snip>
 Jeremy Casey
 my money back out of it and sent    it on its    es  y       -->                 - MATRONICS WEB FORUMS  nbsp;               - List Contribution Web Site  ;                             =========================
		JetPilot
				 Posted: Thu Jan 31, 2008 9:32 am    Post subject: Re: |
				It is pretty well known that a longer wingspan results in better performance.  By making the wingspan shorter, you will most likely...
 Reduce Climb Rate
 Reduce the Glide Ratio
 Poor performance at high altitude density
 Very probably reduce cruise speed
 Increase Takeoff and landing distances
 Increase stall speed
 You reduce a lot of safety margins by reducing the wingspan of the plane.  There will be some advantages like higher roll rate and a couple others, it might not be worth all the bad effects shorter wings will have.  You should research what you are dong and the effects before you do this.
 Mike
  _________________ "NO FEAR" -  If you have no fear you did not go as fast as you could have !!!
Kolb MK-III Xtra, 912-S |
		Mnflyer
				 Posted: Thu Jan 31, 2008 9:45 am    Post subject: Re: HKS WT VS 503 |
				The weight of the HKS is about 25 to 30 lb more than a 503 ( its within 3 lbs of a 582)depending on accessories like starter, oil injection gearbox type etc. The HKS is a 60 hp engine thus 8 more than a dual carb dual ignition 503 burns 3 gph running it at 5700 rpms and has electric start a very quiet ignition and alternator (minimal noise in the radio) and starts almost instantly, has a 800 TBO.
 GB
  _________________ GB
MNFlyer
Flying a HKS Kitfox III |
		Steve Boetto
				 Posted: Thu Jan 31, 2008 10:40 am    Post subject: "clip-wing Firestar/Slingshot wannabe" |
				In a message dated 1/31/2008 12:35:30 P.M. Eastern Standard Time,  orcabonita(at)hotmail.com writes:
  | 	   Yes Mike, but,   What if the wing you are starting with is too  long?  You are assuming that the original Firestar wing is "The Right  Length".  As I understand it the original Firestar has almost as much wing  area as Your MKIIIX. By your logic you would have to increase your wingspan to  almost 60 feet.
  As far as a longer wing being better, It depends what the mission is. By  virtue of the fact that I fly my Firefly with 60 # of float all the time, I Am  60# over weight of a standard Fly. Performance  is tremendous.
  At one point Bryan and I thought about increasing the wingspan a tad but  after flying the stock configuration for two years I see no reason to do  so.
  As far as:
  Reduce Climb  Rate   -----------              Climbs at over 800 fpm with Floats
 Reduce the Glide  Ratio  -----------          Doubt it
 Poor performance at high altitude density    ----------   flies nice at 8000 ft
 Very probably reduce cruise  speed  ----------doubt it
 Increase Takeoff and landing  distances    ------------Takeoff on Glassy water  150 ft/  Lands on less
 Increase stall speed  ---------------- You might be right  here, but the current stall is fine
  I am not trying to give you a hard time here Mike but it is pretty hard to  beat the package that Dennis S and the crew put  together.
  I suggest that you try the stew before you add Salt, The Chef may have  gotten it right.
  Steve
 Firefly 007/Floats
 do not  archive
				 Posted: Thu Jan 31, 2008 10:56 am    Post subject: "clip-wing Firestar/Slingshot wannabe" |
				Most of what you say is true about the clipped wings.  My MkIII has
 the bow tips shortened by a foot. (X2)
 giving me about the same area as a FSII , ~ 150sq'.  Since it came
 with one wing intact I wasn't
 ambitious enough to change it.  There are benefits:  the roll rate is
 much better than my old (yawn) aeronca,
 less drag for a blazing 65 mph cruise, space to get the left tip past
 an old VW beetle carcass in the shed,
 a little easier to install/remove the safety pins for the fold back
 maneuver, which I skip and take them off anyway.
 If I had the extra two feet I could get a fatter girlfriend.  -Too
 late for that now.
 BB, MkIII, vibratin' suzuki, everything's shorter these days
 On 31, Jan 2008, at 12:32 PM, JetPilot wrote:
  Reduce Climb Rate
  Mike
  http://forums.matronics.com/viewtopic.php?p=161575#161575
				 Posted: Thu Jan 31, 2008 11:19 am    Post subject: "clip-wing Firestar/Slingshot wannabe" |
				JetPilot wrote:
  Reduce Climb Rate
  Mike
 <Stall speed is almost entirely controlled by wing AREA, not span.  For
 a given AREA if you vary the span you have to vary the chord to maintain
 the same area...hence you are changing the ASPECT RATIO.  Usually a
 bigger ASPECT RATIO will net a better rate of climb for a given amount
 of power, due to the better SPAN EFFICIENCY.  But in the real world (as
 opposed to the perfect world of fluid dynamics)  a reduction in ASPECT
 RATIO generally produces a lighter structure which in many cases negates
 the small reduction of efficiency (i.e. less efficient wing but it
 doesn't have to lift as much weight). Since I'm not actually changing
 the chord I'll ignore Reynolds number effects for this discussion.
 Soooo, Reduce climb rate? With a power increase of 30-50% depending on
 which engine I go with...I don't think so.
 Reduce the glide ratio...well the higher wing loading won't help but the
 drag reduction I'm doing will, so the best glide speed will increase but
 the best L/D probably won't be hurt much if at all...some sailplanes
 have much higher wing loading than us (many carry water ballast to
 INCREASE wing loading)and they seem to do all right.
 Poor performance at high DA...maybe but see the HP answer above...also
 this is a toy I'm building and my backyard airstrip is at 340' MSL
 Reduce Cruise speed...The decrease of span is basically the first
 modification to every serious RENO racer on the circuit...would reduce
 the higher speeds only if the reduction in area got to the point that
 the Coefficient of Lift got into the high drag part of the curve..also
 Takeoff/landing differences...Takeoff distances are absolutely minuscule
 ..300' or 75' still leaves lots of possible runways to use and the
 higher wing loading can reduce float which can net an actual shorter
 TOTAL landing distance required even with the slightly higher approach
 speed.  I also added a flaperon mechanism that will lower the approach
 speeds to at or near the original long wing no-flap configuration.
 I guess you could say I've thought a few of these things through
 already...what I don't want is a flitterbug that is so lightly wing
 loaded that it gets shoved around by every little puff of wind and
 turbulence.  Having flown big wings and small wing versions of the same
 plane, I'll take the smaller wings (within reason) every time...that's
 just my choice...might not be everyones choice but that's one of those
 great things about having your own
 Jeremy Casey
