emrath(at)comcast.net Guest
Posted: Fri Jan 25, 2008 12:22 pm Post subject: Rv-list Step Crack |
Looks like I'll regret having put the flange on the inside of the side skin. :>(
Marty in Brentwood TN RV-6A not flying yet.
Time: 10:51:02 AM PST US
Subject: Re: Step crack
I don't think the problem is inside, its exterior. No need for all the
nutplates and added labor.
To remove the step for repair, all I did was cut a 5 inch square hole in
the baggage floor over the plastic block, bolt and nut of the step unit.
Removed the bolt, made the repair to the step, reinstalled and fastened
a new cover plate over the baggage floor cutout. Easy. And if it
happens again, access will even be quicker with only two or four screws
to remove to gain access.
Chuck
Subject: RE: Step crack
Another reason I'm glad I used nutplates on my baggage floor. Look s
like checking this location needs to be part of the annual
Ed Anderson
Posted: Fri Jan 25, 2008 1:17 pm Post subject: Rv-list Step Crack |
You may not Marty. I put the flange on the inside of my Rv-6A back in 1997 and as of yet, have not had any crack problems.
Ed
_________________ Ed Anderson
Rv-6A N494BW Rotary Powered
Matthews, NC
eanderson@carolina.rr.com |
