bbradburry(at)bellsouth.n Guest
Posted: Thu Jan 24, 2008 2:56 pm Post subject: Voltage drop under load |
I noticed today that my voltage would drop from about 14.5 volts down to
13.3 volts when I turned all my lights on. That is two 100W landing, two
100W taxi, position, and strobe lights.
I made sure that I had plenty of rpm to be certain that the alternator was
putting out its max. The alternator is rated at 55A.
Is it possible that I am pulling more amps than the alternator can handle?
Is the drop of voltage an indicator of this?
What should be the size of the B lead wire for a 55A alternator?
Bill B
klehman(at)albedo.net Guest
Posted: Thu Jan 24, 2008 3:56 pm Post subject: Voltage drop under load |
Yes voltage starts to sag as the alternator output starts to lag demand.
Quick math suggests that your alternator is working properly. (100 watts
divided by 13.3 volts is about 7.5 amps per 100 watt load) My alternator
can handle all loads but the voltage will drop a bit if I pull the
throttle to idle on approach. No big deal if the battery helps out for a
few dozen seconds on final approach. In cruise my taxi lights wig wag
which halves the current draw.
Ken
Bill Bradburry wrote:
Bill B
nuckolls.bob(at)cox.net Guest
Posted: Sun Jan 27, 2008 9:03 am Post subject: Voltage drop under load |
At 06:52 PM 1/24/2008 -0500, you wrote:
Ken
><bbradburry(at)bellsouth.net>
>Thanks,
>Bill B
13.3 is TOO low. You need to put a temporary lead wire
on the alternator's b-lead terminal and bring it into
the cockpit for attaching a voltmeter. You MAY find that
the alternator voltage at the b-lead is holding up just
fine and that your wiring is too small . . . i.e. accounts
for the drops under load that you've observed.
I recommend 4AWG minimum for all the "fat" wires in
the airplane. There's so little of it that weight deltas
are insignificant . . . but 4AWG or larger makes for
very solid voltage regulation at all loads.
( -Thomas Paine 1776- )
