Mounting RV8 - F-827c flap fairing after the floor is instal
vhimsl(at)adelphia.net
PostPosted: Sun Jan 27, 2008 5:14 pm    Post subject: Mounting RV8 - F-827c flap fairing after the floor is instal Reply with quote
Fef: F-827c Dwgs 28 and 43 mounting flap fairing views DD and EE
Hello,
I permanently installed the floors thinking I had everything covered. Not quite, seems those seven holes on the bottom of the fuselage that have been staring back at me for several years belong to the flap fairing and I now cannot access them from inside the fuselage.
Removing the floor is not an option so I am wondering if someone has unique solution before I grab the pop rivets.
Vince H. (Finish)
I see the light at the end of the tunnel. Unfortunately this is the fourth tunnel in a row.
schad(at)cooke.net
PostPosted: Sun Jan 27, 2008 5:33 pm    Post subject: Mounting RV8 - F-827c flap fairing after the floor is instal Reply with quote
The solution is called cherry max rivets. That is what I did. In fact, I probably used 50 of them in my RV-8. They aren't cheap, but they work well.
