MaxNr(at)aol.com Guest
Posted: Sun Jan 27, 2008 12:54 pm Post subject: Dumb questions |
I have been sitting in the back row on this list, hoping to learn something. I was born without any electronic genes. I am building an all metal light sport plane.(Zenith) Right or wrong, I developed the habit (over five decades of personal, military and commercial flying) of listening to broadcast radio on the ADF. I'm thinking that I need to install an of the shelf automobile radio in my project. No second hand Ebay ADF's. My two questions are: Will I fry the radio if I use only a headset and no speakers? About the antenna. I know that I should mount it vertically, but it must withstand airspeed excursions to Vne (156kts/180mph) without going L shaped. I've come up with somehow jamming it inside the canopy, or insulating it and mounting against the landing gear, or inside some kind of tubular mast on the belly. I did come across a NOS Volkswagen telescoping antenna in my shop. It would be great if that Lyc carburetor turns up again the same way. Somebody stop me if I'm on the wrong track. This isn't the most pressing problem out there, but all suggestions are appreciated.
Bob Dingley
Start the year off right. Easy ways to stay in shape.
http://body.aol.com/fitness/winter-exercise?NCID=aolcmp00300000002489 [quote][b]
jon(at)finleyweb.net Guest
Posted: Sun Jan 27, 2008 2:06 pm Post subject: Dumb questions |
Hi Bob,
Might I suggest you take a look at satellite radio - like XM (http://www.xmradio.com) or Sirius? I've been flying with an XM setup (Roady XL) and love it. I can move it from car to airplane to house or listen on my computer/Internet, in-flight station reception doesn't fade out every 15 minutes (as I fly away from a station), and the antenna is a little tiny thing that is mounted inside my airplane (zero drag). It does require a subscription so is not free. In my plane, I just connect the radio output to my intercom music input.
Jon
jindoguy(at)gmail.com Guest
Posted: Sun Jan 27, 2008 2:25 pm Post subject: Dumb questions |
Bob, I'm no expert, but I did learn this from one. Some automotive audio systems use completely separate grounds for each channel. For that you'd have to rewire your headphones and run three jacks instead of two. This info may be old, it was a few years ago and things move on, but it never hurts to ask the sales guy or look at the wiring layout of any system you're thinking of buying.
Rick
On Jan 27, 2008 2:49 PM, <MaxNr(at)aol.com (MaxNr(at)aol.com)> wrote:
[quote] I have been sitting in the back row on this list, hoping to learn something. I was born without any electronic genes. I am building an all metal light sport plane.(Zenith) Right or wrong, I developed the habit (over five decades of personal, military and commercial flying) of listening to broadcast radio on the ADF. I'm thinking that I need to install an of the shelf automobile radio in my project. No second hand Ebay ADF's. My two questions are: Will I fry the radio if I use only a headset and no speakers? About the antenna. I know that I should mount it vertically, but it must withstand airspeed excursions to Vne (156kts/180mph) without going L shaped. I've come up with somehow jamming it inside the canopy, or insulating it and mounting against the landing gear, or inside some kind of tubular mast on the belly. I did come across a NOS Volkswagen telescoping antenna in my shop. It would be great if that Lyc carburetor turns up again the same way. Somebody stop me if I'm on the wrong track. This isn't the most pressing problem out there, but all suggestions are appreciated.
Bob Dingley
http://body.aol.com/fitness/winter-exercise?NCID=aolcmp00300000002489 | Quote: |
tp://forums.matronics.com
| [b]
nuckolls.bob(at)cox.net Guest
Posted: Mon Jan 28, 2008 5:25 am Post subject: Dumb questions |
At 04:21 PM 1/27/2008 -0600, you wrote:
| Quote: | Bob, I'm no expert, but I did learn this from one. Some automotive audio
Rick
What Rick is referring to is the differential balanced PAIR
of wires that goes to each speaker. This is a technique that
allows TWO amplifiers to drive both wires of a speaker out
of phase with each other. This effectively doubles the potential
peak-to-peak voltage to drive each speaker . . . 4x the watts
without having to resort to power supply boosters or very low
impedance speakers. It also eliminated the need for an output
coupling capacitor . . . a fat passive rascal that was a
necessary inconvenience. See:
http://www.aeroelectric.com/Pictures/Schematics/LM4752.pdf
Here's a "single ended" stereo amplifier. Note the
1000 uF capacitors in series with the speakers. Note
also that the speakers are grounded on one side. See:
http://www.aeroelectric.com/Pictures/Schematics/LM4950.pdf
Here we see two amplifiers wired to each side of the
speaker. No 1000 uF capacitor needed.
Most car radios use a similar scheme with one pair
of dif-amps for the front speakers and another pair
for the rear speakers, a total of eight, ungrounded
wires.
There are perhaps a half-dozen ways to adapt the
speaker outputs of a radio to the headphone inputs
of the intercom. However, many automotive radios have
line output features for taking stereo audio to external
amplifiers. These are already in the ballpark for
connection directly to the stereo inputs of an intercom
system. They're already single-ended and shielded against
case ground for the radio. I'll suggest you seek a radio
with the AUX OUTPUT feature and start from there. If this
proves unsatisfactory, I can show you how to craft an
interface network to go between your radio's speaker
outputs and the stereo inputs of your intercom.
The antenna is another deal entirely. Vertically
polarized, medium wave signals run along the
ground and work really fine with short antennas on
ground based vehicles. Once you leave the ground,
performance for a short whip antenna degrades.
The antenna input to an automotive AM receiver is
a unique beast. It's a very high impedance port
that is performance degraded by CAPACITY. If you
cut the feedline open on a car radio antenna, you
may find that the center conductor is a very small
single strand of wire supported down the center of
the coaxial cable by a hollow plastic tube. This
high-impedance coax was supplied to us in large spools
at Cessna way back when . . . it was necessary for
the purpose of extending the sense antenna feeder from
radio on the panel to a feed-through insulator on
the cabin roof.
I suspect that this input philosophy is still used.
Off-the-shelf car antennas come with a run of this
specialized "coax" that is already terminated to mate
with jacks on radio and base of antenna.
The 'ideal' AM receiver antenna for airborne applications
would be the "ferrite loopstick" described in the
'Connection's section on antennas. This is an H-field
antenna that is not unlike that which your ADF uses
to find bearing of an incoming signal. Unfortunately,
the loopstick IS directional. Unless you can rotate the
antenna, you would need 2 or three of the things along
with an ability to switch between them as well as tune
them to the station's frequency for best reception.
This calls for some experimentation. Ideally, your
radio's antenna input would be characterized for
performance with a longer piece of coax (higher
capacity) and a relatively long wire antenna not
unlike that used for sense antennas of the earliest
ADFs. In this respect, the ADF receivers and AM radio
receivers have a great deal in common with respect
to crafting a high performance antenna with an
exceedingly small size compared to the wavelength
of energy being tapped.
Crafting a "high speed" whip antenna has it's
challenges. My first thought is that actual orientation
of the antenna would have little effect on performance.
I think I'd experiment with a "trailing wire" . . .
a 5' of wire that attaches to a suitable fitting
just before you taxi out. Or, consider crafting a
j-bend antenna, not unlike that used for marker
beacons. Use the standard AM radio antenna that's
a solid rod. Heat it with a torch so that you can
put a 90-degree bend in it about 6" from the base.
Then allow it to fair rearward and support the tip
on an insulated mast of some variety.
Check with the automotive radio/audio shops for
an antenna with longer than usual coax cable.
This might be for a truck, van or RV. The antenna
can't be a telescoping variety . . . solid stainless
rod is called for. But then, depending on your
particular installation, perhaps a standard automotive
antenna for a sedan will have enough coax. See what
it takes to install it on the belly modified and
supported as described above.
Let us know how it works out!
