cookflys(at)yahoo.com Guest
Posted: Mon Jan 28, 2008 3:36 pm Post subject: Kitfox-List Digest: 30 Msgs - 01/27/08 |
582 bleeding coolant
I have searched archives and cannot find, someone told how to bleed all air out of coolant system on 582 and it worked like a champ.(3 years ago).
Charles 363KF
Kitfox-List Digest Server <kitfox-list(at)matronics.com> wrote:
[quote]*
Today's complete Kitfox-List Digest can also be found in either of the
of the Kitfox-List Digest and can be viewed with a generic text editor
HTML Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 08-01-27&Archive=Kitfox
Text Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 08-01-27&Archive=Kitfox
Kitfox-List Digest Archive
Total Messages Posted Sun 01/27/08: 30
Today's Message Index:
1. 04:41 AM - Re: Tru-Trak Autopilot in S5/Vixen (fox5flyer)
2. 07:10 AM - Console covering (fox5flyer)
3. 07:36 AM - carb/throttle connection (kerrjohna(at)comcast.net)
4. 07:55 AM - Re: Console covering (kcflys)
5. 08:24 AM - Re: Console covering (john oakley)
6. 09:22 AM - carb to throttle linkage (kerrjohna(at)comcast.net)
7. 10:27 AM - Info found on HVLP gun setup! (SUE MICHAELS)
8. 10:40 AM - Re: Console covering (paul wilson)
9. 10:50 AM - Re: carb/throttle connection (Lynn Matteson)
10. 12:29 PM - Re: Console covering (fox5flyer)
11. 12:31 PM - Re: Re: Console covering (fox5flyer)
12. 12:46 PM - Re: Console covering (Clint Bazzill)
13. 12:47 PM - Re: Info found on HVLP gun setup! (Vic Baker)
14. 01:42 PM - Luggage Pod ideas (LarryM)
15. 01:43 PM - Re: Info found on HVLP gun setup! (Ron Zeppin)
16. 02:07 PM - Re: Luggage Pod ideas (Michel Verheughe)
17. 04:07 PM - Re: Console covering (kerrjohna(at)comcast.net)
18. 04:18 PM - Re: Console covering (GONER752(at)aol.com)
19. 04:36 PM - Re: Console covering (Sbennett3(at)aol.com)
20. 04:44 PM - 912S oil temp (lazflyn)
21. 05:06 PM - Re: Luggage Pod ideas (fox5flyer)
22. 05:06 PM - Re: Console covering (fox5flyer)
23. 05:07 PM - Re: Console covering (fox5flyer)
24. 07:06 PM - Re: Console covering (Cudnohufsky's)
25. 08:03 PM - (RAY Gignac)
26. 08:11 PM - Re: 912S oil temp (jeff puls)
27. 08:38 PM - Re: Console covering (Guy Buchanan)
28. 08:38 PM - Re: Re: Luggage Pod ideas (Guy Buchanan)
29. 08:38 PM - Re: 912S oil temp (Guy Buchanan)
30. 08:38 PM - Re: Re: Console covering (Guy Buchanan)
________________________________ Message 1 _____________________________________
Time: 04:41:07 AM PST US
Subject: Re: Tru-Trak Autopilot in S5/Vixen
Thanks for the report, Travis. After you get a few hours on it, please give
us another update.
Deke Morisse
Mikado Michigan
S5/Subaru/CAP 355+ TT
"The aim of an argument or discussion should not be victory, but progress."
- Joseph Joubert
----- Original Message -----
Sent: Saturday, January 26, 2008 3:28 PM
I have completed the install of the autopilot. No major headaches or
fabrication needed. However....I so apologize!!!! When we finished
everything it was a cold rainy day (our hanger is open on two sides).
After we cleaned up all the tools, etc. Kathy pulled out the camera, and
after that...dead battery warning! We did not take ANY pictures. Since I
had the help, we put the plane back together and flew it the next day.
We made a few control adjustments while in flight (changing the torque and
movement speeds of the servos). This is done at the control head and is
actually quite easy to do. We locked on altitude at 2,000' and it did not
change by more than 10' up or down. It also held us on course and making
directional changes are easy. We took it down to 800' because it was
really turbulent at that altitude. Altitude +/- 20 and it held the course
heading. We had to increase the lateral adjustment (how fast the servo
responds and moves). After that it did a fantastic job of keeping the
wings level even though it was a rough ride. At present...I have no
complaints about the ADI Pilot II. I'm just glad it is installed...and
I'm thrilled.
The main servo is mounted on the left side of the fuselage behind the
seat, attached with Adell clamps to the two V shaped tubes. The elevator
servo is also behind the seat just above the push/pull tubs. It is also
mounted to the structural tubes in that location. The pushrod is attached
the elevator pushrod under the seat.
When we pull the plane down for it's next 100 hour inspection I will take
lots of pictures with printed detail and post them. I really feel bad
that i was unable to take the pictures...but I had help and didn't want to
delay the test flight.
If you have any specific questions, please ask!
Travis
Travis Rayner
Mobile, AL
Skystar Vixen
N-789DF
http://forums.matronics.com/viewtopic.php?p=160586#160586
________________________________ Message 2 _____________________________________
Time: 07:10:21 AM PST US
Subject: Console covering
When I built my S5 (1st flight May 2000) I chose to cover the console
top side with Cordura fabric to match the seats. My biggest reason for
using fabric was to cover up all of the rivets that would have been
visible had I painted it. I used spray on 3M adhesive and it held up
for about three years and since then it has gradually worked loose and
looked unsightly so I removed it. Now I need to recover with something.
What have some of you used to cover your console that has lasted? I'm
just looking for alternatives to what I've already tried and didn't work
very well. Vinyl contact paper was suggested, but I don't know where to
find something suitable and of course, color would be a limiting factor.
Any suggestions out there?
Deke Morisse
Mikado Michigan
progress."
- Joseph Joubert
________________________________ Message 3 _____________________________________
Time: 07:36:42 AM PST US
Subject: carb/throttle connection
Dan Mc Intyre and others
Can you give me a source for more information on the Jelati throttle arm. the
posted pictures appear to offer a possible to a solution faced with a larger Bing
carb on a Rotek radial engine.
John Kerr
Classic IV
RV9
Hatz Classic
arm. the posted pictures appear to offer a possible to a solution
faced with a larger Bing carb on a Rotek radial engine.
John Kerr
Classic IV
RV9
Hatz Classic
________________________________ Message 4 _____________________________________
Time: 07:55:54 AM PST US
Subject: Re: Console covering
Deke,
Have you considered screw down snaps like for boat covers, etc. A little more
weight but would probably need half doz. or less.
Keith C.
kitfox wannabe
C-150
Rancho Cordova CA
http://forums.matronics.com/viewtopic.php?p=160653#160653
________________________________ Message 5 _____________________________________
Time: 08:24:23 AM PST US
Subject: RE: Console covering
Deke,
I used nagahide on my fox panel top. I had a bead sown in along the front
edge of the top and glued in place. I still looks great after 10 year and
that includes 4 years in the summer sun at high altitude.
John Oakley
Speedster 4 912ul cap
_____
[mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of fox5flyer
Sent: Sunday, January 27, 2008 7:39 AM
When I built my S5 (1st flight May 2000) I chose to cover the console top
side with Cordura fabric to match the seats. My biggest reason for using
fabric was to cover up all of the rivets that would have been visible had I
painted it. I used spray on 3M adhesive and it held up for about three
years and since then it has gradually worked loose and looked unsightly so I
What have some of you used to cover your console that has lasted? I'm just
looking for alternatives to what I've already tried and didn't work very
well. Vinyl contact paper was suggested, but I don't know where to find
Deke Morisse
Mikado Michigan
- Joseph Joubert
________________________________ Message 6 _____________________________________
Time: 09:22:16 AM PST US
Subject: carb to throttle linkage
can you give me a source for more information on the Jelanti throttle arm? I have
a Rotek radial engine with a larger Bing throttle and the pictures of you installation
suggest a solution to a problem I am having.
John Kerr
Classic IV w 912ul
RV9 w 0320
Hatz Classic w 150hp Radial
throttle arm? I have a Rotek radial engine with a larger Bing throttle and the
pictures of you installation suggest a solution to a problem I am having.
John Kerr
Classic IV w 912ul
RV9 w 0320
________________________________ Message 7 _____________________________________
Time: 10:27:13 AM PST US
Subject: Info found on HVLP gun setup!
Found an interesting web that describes how to set up the Harbor Freight's current
HVLP spray gun # 43430. Harbor Freight has them on sale for $40.00 in the
store price but go to their WEB site and buy it for $20.00. Even if you don't
like it, for 20 bucks you can always paint the patio furniture with it. No, I
have not tried it but I ordered one.
http://purplesagetradingpost.com/sumner/techinfo/HVLPspraygun.html
George
________________________________ Message 8 _____________________________________
Time: 10:40:51 AM PST US
Contact paper is in the housewares dept of WalMart, Target etc. Its
worth a try because the cost in minimal.
PW
To: Kitfox List
console top side with Cordura fabric to match the seats. My biggest
reason for using fabric was to cover up all of the rivets that would
have been visible had I painted it. I used spray on 3M adhesive and
it held up for about three years and since then it has gradually
worked loose and looked unsightly so I removed it. Now I need to
lasted? I'm just looking for alternatives to what I've already
tried and didn't work very well. Vinyl contact paper was suggested,
but I don't know where to find something suitable and of course,
Deke Morisse
Mikado Michigan
- Joseph Joubert
________________________________ Message 9 _____________________________________
Time: 10:50:14 AM PST US
Subject: Re: carb/throttle connection
You might be referring to the arm that Dave Jalanti engineered for
his Jabiru installation in his Kitfox. If so, I got mine from Pete at
USJabiru ( www.usjabiru.com or email them at
info(at)usjabiru.com ) in Tennessee, a Jabiru dealer. This arm extends
the length of the VERY short Bing throttle arm, and thus allows for a
more precise control of the throttle.
Lynn Matteson
Grass Lake, Michigan
flying w/460+ hrs
On Jan 27, 2008, at 10:09 AM, kerrjohna(at)comcast.net wrote:
| Quote: | Dan Mc Intyre and others
throttle arm. the posted pictures appear to offer a possible to a
solution faced with a larger Bing carb on a Rotek radial engine.
John Kerr
Classic IV
RV9
Hatz Classic
www.matronics.com/Navigator?Kitfox-List _-
www.matronics.com/contribution _-
________________________________ Message 10 ____________________________________
Time: 12:29:15 PM PST US
John, thanks for the tip. Do you have a photo you could send? Unless
there is some List interest you can just send it to me direct.
Deke
Deke,
front edge of the top and glued in place. I still looks great after 10
year and that includes 4 years in the summer sun at high altitude.
John Oakley
To: Kitfox List
Deke Morisse
Mikado Michigan
progress."
- Joseph Joubert
________________________________ Message 11 ____________________________________
Time: 12:31:25 PM PST US
Subject: Re: Re: Console covering
No, I hadn't considered that, but I will. Thanks,
Deke
JKarp(at)ccrgroup.com Guest
Posted: Tue Jan 29, 2008 2:59 am Post subject: Kitfox-List Digest: 30 Msgs - 01/27/08 |
Hi there,
First, thank you for hosting the list. I had no idea how active it was and have learned a lot reading this last week. Unfortunately this is my company email and its just too many messages, so would you mind taking me off the distribution please? I don’t want to cancel my account, just cant receive so many emails here- and by the way, I forgot my password and I cant get anywhere trying that route to log off the emails-
Best,
John D.K. Karp, P.E.
Director of Operations
Cost Recovery Services, LLC
1400 Computer Drive
Westborough, MA 01581
Maine Office: (207) 221-2952
Cell (774) 293-0555
dave
Posted: Tue Jan 29, 2008 4:17 am Post subject: Re: Kitfox-List Digest: 30 Msgs - 01/27/08 |
John,
You can easily log onto the forum here
http://forums.matronics.com/viewforum.php?f=8
This is 100 times better that using the antiquated email list and alot easier to post pics etc.
If you are on the mail list you can change the settings to get no mail or just a daily digest.
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube |
