keithhickling(at)clear.ne Guest
Posted: Wed Jan 30, 2008 8:45 pm Post subject: Epoxy Measuring - Balances vs Digital Scale vs Ratio Pump |
Roger,
I used the Europa balance, but modified by using 20 lb breaking strain nylon
fishing line as the pivot, rather than the nail as described in the manual.
The nylon line goes through the brass tube, and is stretched tight across
the frame. This was a suggestion from Dr Martin Armstrong, technical
director of SP systems (now Gurit) who make Ampreg resins. He pointed out
that if you use a nail for the pivot, the brass tube tries to roll on the
nail, resulting in a slight movement of the pivot point, and it also causes
significant friction, both resulting in inaccuracies.
I tested the balance against accurate pharmacy scales and found it was
accurate to less than 0.02 g when balancing a 100 g weight with a 25 g +-
small weights using the 4:1 ratio (ie 40 cm to 10 cm on the balance). In
practical terms, I can easily detect the effect of 1 drop of hardner when
nearly balanced. I expect that using digital scales would take longer, as
you have to accurately measure quantities of both resin and hardner, whereas
with the ratio balance you just pour roughly the amount of resin you want,
then add exactly the right amount of hardner. Having now got close to the
end, I have been amazed at the number of resin mixes needed - far more than
I initially envisaged - so any time saved here is significant.
I also always mixed the resin and hardner back and forward between the two
cups, rather than simply pouring the resin into the hardner as suggested and
then reusing the resin cup next time. I had thought, and Martin Armstrong
confirmed, that this can result in significant inaccuracies, depending how
long you spend draining the resin from the cup each time, as well as
allowing water (vapour) and CO2 into the residual resin in the cup.
I'll be interested to hear what others have found.
Keith Hickling,
New Zealand.
Engine in, working on cowls.
gregoryf.flyboy(at)comcas Guest
Posted: Wed Jan 30, 2008 11:18 pm Post subject: Epoxy Measuring - Balances vs Digital Scale vs Ratio Pump |
Keith Hickling wrote:
"I expect that using digital scales would take longer, as you have to
accurately measure quantities of both resin and hardner, whereas with the
ratio balance you just pour roughly the amount of resin you want, then add
exactly the right amount of hardner. "
I have always used the digital scale. It is an Ohaus, with a resolution of
0.1 gram and does not suffer hysteresis inaccuracies like some do. Absolute
accuracy is not important, since the accuracy error will factor out in a
ratio, as long as repeatability is good. No need to bother with using the
sample weights that come with the scale to make it accurate.
With the scale, you never need 2 cups to mix the resin back and forth, and
only have to carefully measure the hardener. I put resin pumps on the
containers of hardener and resin, and leave them there(they can be obtained
from the local epoxy supply, such as Tap Plastics, or probably Aircraft
Spruce or Wicks), with a plastic bag over them when finished. Upon needing a
batch, just grab both out of the temperature-controlled storage area, pull
off the plastic bags, and start pumping. For example:
Epoxy:
Put a disposable cup onto the scale. Turn it on, and it will auto zero,
excluding the weight of the cup from the equation. Dump in whatever amount
of resin you feel like. It does not need to be measured, a wild-ass guess
will do, but write down the final amount of the weight of the resin.
Multiply this amount by 0.27 (Aeropoxy), and you have your hardener amount
to add. Add that number back to the initial amount of resin measured, and
you get the total amount of resin plus hardener needed. Simply pump hardener
into the same cup until you get close to the final amount, then go drop by
drop until you nail the reading to a tenth of a gram (resolution of the
scale), and you got it! Its very easy and takes almost no time, and no need
to mess around with pouring between the resin cup and hardener cup to use
all of the material -just keep a calculator handy, and a pencil to tap the
numbers to keep the calculator clean. Mix until you see a homogenous
mixture, and you are done. It took a little while to explain, but it goes
really fast. As a final check, keep a mixture lookup chart nearby and right
before adding the hardener, verify that the calculated hardener amount to
add is close to proper value.
Araldite:
Araldite won't pour, and needs to be scooped out with a Popsicle stick. It
will adhere grossly to the stick. Hence in this case, put the stick and the
cup on the scale before it zeros the value, to cancel out the weight of the
popsicle stick too. Make sure it is always in the cup during measurement.
Scoop out the araldite needed, and put the scooped amount along with the
stick, into the cup. The measurement reading taken will be for the araldite
only, since the stick was cancelled out. Make the calculation (multiply by
0.4, similar to the epoxy, above) Then pour in the hardener from a
ketchup-like bottle which has the ability to dispense from stream to drops,
depending on squeeze pressure (I purchased one from the local epoxy shop,
and it is similar). Verify calculated amount with the araldite mixture
lookup sheet (found on one of the web sites) to verify that the calculated
amount is close, then mix.
In the build manual, I write the resin amount measured, and hardener amount
to be mixed, along with the total amount of the two, which is the important
number, since you will add hardener until the total amount is achieved, then
write how close I actually got to the calculated total amount. Almost
always, the final resin + hardener measurement (actual) is the same as what
is calculated.
It is amazing how accurate the ratio scale can be if it is built properly,
like using the fishing line technique that Fred described. And it is
cheaper. For me though, the $100.00 digital scale which you can sometimes
find for 35 or 40 works really well, is fast, and if carefully done and
verified, will always make the proper ratio.
Have fun,
~Greg Fuchs
topglock(at)cox.net Guest
Posted: Thu Jan 31, 2008 9:30 am Post subject: Epoxy Measuring - Balances vs Digital Scale vs Ratio Pump |
Roger,
Guess I'm the odd man out, but I used the pump and loved the ease and
speed. Only down side I found was having to clean it up every few
months. 15 minute job. Well worth it, in my opinion, for the
convenience of pulling the handle and you're done...
BTW, I got the pump with the kit, so cost was not a factor for me...
Jeff - Baby Blue
363 hrs
Roger Lowe wrote:
Quote: |
Hi, I've purchased a partially complete Europa a little over a year ago and had to put it storage until my garage/workshop was re-vamped in order to build the kit. It is now to a point to where I can start moving my kit into it and start working on it.
I have question about the different devices used to measure the epoxy and wondering what most builders have done in the past. The cheapest of course is to make the Europa mechanical balance which should be no problem (is it quick and easy to use during a layup?) but I'm leaning towards either a Ohaus / Sartorius digital scale with a resolution of 0.01gm (do I need that much precision or can I get away with a lower cost 0.1gm unit?) OR a ratio pump like a Glenmarc Portionator MBT-JR from A/S which is the most expensive of the all the options (is it worth the cost for ease of use?).
I live in Canada so I will be using Aeropoxy resin (100:27 by weight or 3 to 1 by volume).
I would appreciable any feedback/experience that you have that would help me make up my mind!
Thanks, Roger
Visit - www.EuropaOwners.org
Posted: Thu Jan 31, 2008 3:22 pm Post subject: Epoxy Measuring - Balances vs Digital Scale vs Ratio Pump |
Ira wrote:
A scale that gives you 0.5% is way better than necessary since 5% is
probably just fine.
Favid Miller wrote:
the Aeropoxy reps at Oshkosh, they were clearly amused by anyone bothering
to measure to the nearest tenth of a gram - off the record they indicated
that the tolerance levels for a proper cure are quite high.
I don't know who is correct, but Martin Armstrong, technical director of SP
Systems (Ampreg) told me, as stated in the data sheets, that 2% is the
maximum permissable error in mixing resin and hardener - any greater error
results in measurable and significant reductions in strength. He was very
concerned that some people get a bit "gung ho" about it. And 2% is only 0.1
gram of hardener in a 5g / 20 g mix. And a similar error in the opposite
direction neasuring the resin would result in a 4% total error.
Keith Hickling,
New Zealand.
