air.guerner(at)wanadoo.fr Guest
Posted: Wed Jan 30, 2008 12:21 am Post subject: Don Dykins book |
Hi all,
I have just read Don Dykins book « Understanding the aerodynamics of your Europa aircraft » and I am puzzled by what I read in the “Prototype flight test performance” section.<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" />
Figure 1 on page 15 shows that you need more power to fly at a given airspeed at altitude than at sea level. I first thought it was a typo, but page 18 confirms this assertion: “more HP is required to fly at a given speed at 10,000ft than at sea level”.
The typical light aircraft cruises about 5 to 10 percent faster at <?xml:namespace prefix = st1 ns = "urn:schemas-microsoft-com:office:smarttags" />10000 ft than at sea level using the same power, and you can verify this with your own Europa as well.
So Don Dykins is wrong. Unless he is talking about indicated airspeed. In that case, talking about performance, this is nonsense.
I cannot believe someone who has contributed to the design of such a wonderful aircraft can be so wrong. Am I missing something?
Please comment.
Remi Guerner
craigb(at)onthenet.com.au Guest
Posted: Wed Jan 30, 2008 3:28 am Post subject: Don Dykins book |
If you consider the fact that you need more power or a longer ground run to take off at high temps or lower pressures (higher density altitude)
then Don's assertions are correct. Consider also that some aircraft were supercharged during world war 2 only to delay the onset of "coffin corner"
and allow for a higher service ceiling. Well thats my 2 cents worth.
Craig
[quote] --
m.j.gregory(at)talk21.com Guest
Posted: Wed Jan 30, 2008 3:35 am Post subject: Don Dykins book |
Hello Remi,
Yes, the airspeed axis on page 15 Figure 1 is labelled "VEASKTS", standing for Equivalent Airspeed in knots, which is a more technically precise term than Indicated Airspeed for aerodynamicist's calculations. For practical purposes, they may be treated as equal for the flight envelope of the Europa.
The reason why you need more horsepower at altitude for a given IAS is that, for a given efficiency, the engine is providing thrust to equal the same drag (which is dependent on IAS) but the True Airspeed is greater, so the actual distance moved in a given time is greater. Work = Force x Distance; Power = Work/time. The engine is therefore having to do more work in a given time at the same IAS at altitude, but this is more than offset by the gain in TAS, so cruising at a given TAS requires less horsepower at altitude.
I do not believe Don Dykins is wrong, and I do not agree that it is nonsense to talk about performance in terms of indicated airspeed. As I understand it, he is showing his calculations of aerodynamic performance and comparing them with the results of flight tests, where IAS is measured.
It would be interesting to know how the latest VP propellers compare in efficiency with his working assumption of 80%.
Best regards
Mike
From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of Remi Guerner
Sent: 30 January 2008 08:12
To: Europa-List Digest Server
Subject: Don Dykins book
Hi all,
The typical light aircraft cruises about 5 to 10 percent faster at 10000 ft than at sea level using the same power, and you can verify this with your own Europa as well.
Please comment.
Remi Guerner
[quote] [b]
mikenjulie.parkin(at)btin Guest
Posted: Wed Jan 30, 2008 6:30 am Post subject: Don Dykins book |
Craig,
I am not sure that is correct. 'Coffin Corner' describes the area of the flight envelope where stalling speed meets the critical mach no. This is a problem with high flying aircraft such as the U2. I don't think that extra power would help here.
regards,
Mike
do not archive.
Posted: Wed Jan 30, 2008 12:16 pm Post subject: Don Dykins book |
Sure my use of the term "coffin corner" may not be correct, but it is a simmilar situation is it not??
If the approach to coffin corner is caused by a lack of power rather than a design limitation then it would be, wouldnt it? Say like trying to fly your Europa with 60hp
at high altitude, you would end up in the same situation, can't go slower or I'll stall, can't go faster not enough power. Some of the heavier 912ul powered europa are flat out
at around 120kts arent they, yet the design is good for about 165-175 kts.
craig
[quote] --
Posted: Wed Jan 30, 2008 4:14 pm Post subject: Don Dykins book |
Craig,
What you are talking about is a stall - plain an simple. It is nothing to do with the "Coffin Corner". Please see [url=http://en.wikipedia.org/wiki/Coffin_corner_(aviation]http://en.wikipedia.org/wiki/Coffin_corner_(aviation[/url])
regards,
Mike
Posted: Thu Jan 31, 2008 1:08 am Post subject: Don Dykins book |
Mike Gregory wrote:
"Yes, the airspeed axis on page 15 Figure 1 is labelled "VEASKTS", standing for Equivalent Airspeed in knots ..........I do not believe Don Dykins is wrong, and I do not agree that it is nonsense
to talk about performance in terms of indicated airspeed. "
Mike,
I fully understand that. But again when talking about cruise performance, what the builder owner or pilot of the Europa is interested in is True Air Speed, not Indicated Airspeed. This is why I said this is nonsense.
Fortunately I did not pay the 5 British Pounds for the book, as I just borrow it!
Best regards
Remi
