msm_9949(at)yahoo.com Guest
Posted: Tue Feb 05, 2008 7:49 am Post subject: Panel layout - was Completed Kitfoxes |
Good suggestions Stan. If I was where Gary is now, I'd put Tach and EGT in the 2" holes on left and a Tru-Trak ADI in the open big hole. With the ADI he can ditch the ball, it has one built in. Make a new hole for intercom over on the other side somewhere. There's plenty of room.
SOURDOSTAN(at)aol.com wrote: [quote] In a message dated 2/4/2008 7:46:50 P.M. Mountain Standard Time, delbelbelluz(at)rogers.com writes:
| Quote: | | I'm on the home stretch with the panel layout in my Classic IV |
Good looking panel, Gary; however, I suggest some changes in instrument positions. You'll most likely find that you will want certain flight and engine instruments within your immediate view, especially during takeoff and landing. I suggest you move your clock to where the tach is now (you don't really need to refer to the clock very often); place the tach where the ball is now (so you can easily see it without moving your head away from your immediate view outside the cockpit); and place the ball where the clock is now. I have mine set up similarly to what I am suggesting, and after almost 1300 hours find it very suitable.
Keep up the good work!
Stan Specht
Kitfox Model IV Speedster "Columbine"
49 states and 1285 hours on a 912ul
Denver, Colorado
Who's never [quote][b]
