dlm46007(at)cox.net Guest
Posted: Sun Feb 03, 2008 4:47 am Post subject: fuel tank flush |
I have QB wings and am ready to flush the tanks and the remaider of the fuel system to remove any trash left behind by the builders. anyone else flush their wings before putting in the fuel sumps and running the engine? If so with what?
carl.froehlich(at)cox.net Guest
Posted: Sun Feb 03, 2008 7:03 am Post subject: fuel tank flush |
One way is to install a temporary clear auto type fuel filter in a line going from the firewall fuel fitting to gas cans, or via a temporary hose to the other gas tank. If you are using an in line fuel filter, like the Airflow Performance one Van’s sells, this should be removed and replaced with a straight piece of tubing so that you don’t trap the trash in it. You want all the trash to end up in temporary filter.
Fill one tank, sump the tank until you get a clear sample, and then use the boost pump to pump the fuel into gas cans or the other tank via the auto filter. This way you have clean gas to use over and over until you are satisfied the trash is gone. If you see any particles while sumping the tanks you are not yet done. You may want to agitate the gas in the tank by rocking the wing to help dislodge particles and get them to the bottom of the tank.
This is also the time to do a first check to make sure you have minimum fuel flow rate (final check is after you reinstall the permanent inline filter) and calibrate the fuel senders if you are using an electronic engine indication system.
Carl Froehlich
RV-8A (400 hrs)
RV-10 (wings)
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of David McNeill
Sent: Sunday, February 03, 2008 7:41 AM
Subject: fuel tank flush
| Quote: | | http://www.matronics.com/Navigator?RV10-List | 0123456789
apilot2(at)gmail.com Guest
Posted: Sun Feb 03, 2008 11:44 am Post subject: fuel tank flush |
Recommend you use a fluid less volatile than gasoline for the process...like water or stoddard solvent.
On Feb 3, 2008 7:57 AM, Carl Froehlich <carl.froehlich(at)cox.net (carl.froehlich(at)cox.net)> wrote:
One way is to install a temporary clear auto type fuel filter in a line going from the firewall fuel fitting to gas cans, or via a temporary hose to the other gas tank. If you are using an in line fuel filter, like the Airflow Performance one Van's sells, this should be removed and replaced with a straight piece of tubing so that you don't trap the trash in it. You want all the trash to end up in temporary filter.
Carl Froehlich
RV-8A (400 hrs)
RV-10 (wings)
From: owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com) [mailto:owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)] On Behalf Of David McNeill
Posted: Tue Feb 05, 2008 11:27 am Post subject: fuel tank flush |
I flushed them with water. I also cut an access ports on the rear of the tanks to install the sender units.
I went out and purchased a brand new shop vacuum and blew air into the tanks for a few hours to ensure no water remained. Of course all the opeings were open when i did this to ensure the air being blown in had someplace to exit.
John G.
[quote] From: dlm46007(at)cox.net
Subject: RV10-List: fuel tank flush
Date: Sun, 3 Feb 2008 05:41:25 -0700
get=_blank>http://www.matronics.com/Navigator?RV10-List
p://forums.matronics.com
| [b]
