		daveleikam(at)wi.rr.com Guest
				 Posted: Mon Feb 27, 2006 5:47 pm    Post subject: Tough to set rudder rivet - Did it! |
				I drilled out the AN470AD4-4 rivet closest to the trailing  edge of the rudder holding the R-1004A and B together. Rivet tape to hold  the rivet in place, upside down now.  I then had my son Tyler (AKA co-pilot) hold the R-1004A away enough to squeeze the  rivet with a thin nose yoke.  Then re-rivet the R-1004A and B.   Building is so much fun!
  Thanks for the other suggestions.
  Dave Leikam
  #40496
  [quote]   ---
				 Posted: Mon Feb 27, 2006 5:53 pm    Post subject: Tough to set rudder rivet - Did it! |
				 Posted: Mon Feb 27, 2006 5:57 pm    Post subject: Tough to set rudder rivet - Did it! |
  Dave Leikam
  #40496
		jwik(at)crary.com Guest
				 Posted: Tue Feb 28, 2006 7:11 am    Post subject: Tough to set rudder rivet - Did it! |
				I am at that same point with no thin nose yoke.  Was considering an approach like shown on this builders tip for dimplinge and setting rivets in those hard to reach places.
  http://www.experimentalaero.com/Builders%20Tips.htm
  Dave Leikam wrote:
   	  | Quote: | 	 		              I drilled out the AN470AD4-4 rivet closest to the trailing edge of the rudder holding the R-1004A and B together. Rivet tape to hold the rivet in place, upside down now.  I then had my son Tyler (AKA co-pilot) hold the R-1004A away enough to squeeze the rivet with a thin nose yoke.  Then re-rivet the R-1004A and B.  Building is so much fun!
    Dave Leikam
    #40496
     	  | Quote: | 	 		       ----- Original Message -----
      From:     Jeff Carpenter (jeff(at)westcottpress.com)
      To:     rv10-list(at)matronics.com (rv10-list(at)matronics.com)
      Sent: Monday, February 27, 2006 6:08 PM
      Subject: Re: Tough to set rudder rivet
  Hi Dave,
      There are a few approaches that work.  I took some meat out of the center of a bucking bar, leaving about a 3/16" thick surface on either side that I could slide in between the rib flanges... allowing me to buck the rivet (my tech counselor was quite impressed).  I'd take a picture of it to show you but it's on loan to another builder.
      Avery also sells a yoke with a tapered head that will work... but you're looking at $85.00.
      Jeff Carpenter
      40304
      Wings/Forward Leading Edge
           On Feb 27, 2006, at 3:27 PM, Dave Leikam wrote:
            	  | Quote: | 	 		         Probably an old question from a new -10 builder.  How do you squeeze or set the rivet on the lower right side of the rudder (You know the one).  I am considering using a blind rivet on both sides.  Anyone?  Thanks!
        Dave Leikam
        #40496
