		kevann(at)gotsky.com Guest
				 Posted: Mon Feb 11, 2008 6:07 am    Post subject: Rotax 914 regulator mounting location |
				I am trying to decide where to mount the regulator in my 914
 installation. I hear these regulators fail if you draw more than 14 amps
 or so, possibly due to heat? Mine will be used as a backup, switched
 off, unless the IRalternator I have mounted on the vacpump pad fails.
 Has anyone mounted it in the air intake area near the air filter? I am
 thinking of bolting it to the passenger foot well front in the air
 intake plenum. Seems like it would get cool air,and maybe some heat sink
 advantage from contact with the aluminum CD6.
 It would be easier to just put it on top of a foot well. Anyone have any
 advice?
 Thanks, Kevin
  |  | - The Matronics RotaxEngines-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
				 Posted: Mon Feb 11, 2008 6:30 am    Post subject: Rotax 914 regulator mounting location |
				Kevin Klinefelter a écrit :
  	  | Quote: | 	 		   I am trying to decide where to mount the regulator in my 914
  amps or so, possibly due to heat?
 Heat, yes.
 Have a look at http://contrails.free.fr/elec_ducati_en.php
  	  | Quote: | 	 		   Mine will be used as a backup, switched off, unless the IRalternator I
  sink advantage from contact with the aluminum CD6.
 Cool air, yes. But remember that anything protruding into the airflow,
 albeit internal, will generate drag, unless the airflow has really
 slowed down.
  any advice?
 You can put it in any location you see fit, provided cooling air is
 sufficient and wires are not overly long.
 Best regards,
 Gilles
