jack(at)comconn.com Guest
Posted: Fri Feb 15, 2008 1:57 pm Post subject: opinion on epoxy primer? |
Due to rust popping through the old paint on a project I just picked
up, I'm going to strip the fabric, and start from scratch. I
just stopped by a local paint store, and they offer a 2-part epoxy
primer: Transtar 2K epoxy. Does anyone have any opionion one way
or the other on using this product? I will be using the stits poly
process for covering - I'm already familiar with it, and have quite
a bit of extra left over from a previous project.
-Jack
dcsfoto
Posted: Fri Feb 15, 2008 2:53 pm Post subject: Re: opinion on epoxy primer? |
I would use PPG primer
David Do not arcive
Tom Jones
Posted: Fri Feb 15, 2008 4:55 pm Post subject: Re: opinion on epoxy primer? |
Jack, I would want to make sure it is compatible with the Poly Fiber materials before using it. Thats a lot of work, not to mention the expense, if there may be adhesion problems down the road.
_________________ Tom Jones
Classic IV
Ellensburg, WA |
patreilly43(at)hotmail.co Guest
Posted: Fri Feb 15, 2008 5:31 pm Post subject: opinion on epoxy primer? |
Jack, Opinion only since I have no experience with the brand you are talking about, but I used a 2 part automotive primeer to prime bare spots on my frame. It appears that almost any 2 part epoxy primer is impervious to MEK based paint. I have glued over the 2 part I used successfully.
Pat Reilly
Mod 3 Rebuild
Rockford,IL
| Quote: | Date: Fri, 15 Feb 2008 15:53:06 -0600
Subject: Kitfox-List: opinion on epoxy primer?
--> Kitfox-List message posted by: Jack L Bell <jack(at)comconn.com>
Float Flyr
Posted: Fri Feb 15, 2008 6:45 pm Post subject: opinion on epoxy primer? |
Is there Zinc chromate in that epoxy? With 4130 I'd stick to something with
zinc chromate in it.
Noel
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
