victorbravo(at)sbcglobal. Guest
Posted: Mon Feb 11, 2008 10:45 am Post subject: Sabrina Re: pitching the H-stab |
Sabrina, this would be an important question to ask directly to Zenair,
specifically to Chris Heintz personally. I have no doubt he would be
willing to answer your question. Changing the angle that the tail is
mounted on the airplane is a big change. It's not something you can do
just because someone else has done it or thinks it will work. It has a
huge effect on the safety and stability of the airplane.
Sabrina wrote:
"Overall, moving the stabilizer has been a big success. I plan to add another degree in prop pitch from 10 to 11 degrees at the tip and see what that does. Top speed right now is around 120 mph. We started with 85 at wide open throttle. Climb speed now at 90 mph is 500 fpm - also an improvement since moving the horiz. stabilizer and re-pitching the prop. Oil Temps have come down significantly with several changes to the cowl and prop pitch. Scott Laughlin www.cooknwithgas.com"
Assuming a pitch up 1 degree mis-configuration to a 1 degree down, total 2 degree change could easily result in a 10% increase in speed. Scott has demonstrated results. As far as the person at Air Venture, it should not be too hard to figure out who he is, how many people live near Oshkosh and have built 2 601s. Thank you Sir, if you are reading this.
http://forums.matronics.com/viewtopic.php?p=163510#163510
Posted: Mon Feb 11, 2008 11:57 am Post subject: Sabrina Re: pitching the H-stab |
all said, thats the fun of experimental! Thou art the builder!
Juan
Posted: Mon Feb 11, 2008 1:27 pm Post subject: Sabrina Re: pitching the H-stab |
Sabrina wrote:
| Quote: | Cessna has proven than tail down force on slow aircraft is an acceptable design.
Congratulations on your excellent grasp of airplane design... we're all
genuinely blown away. Here's the "rest of the story" about the tail
angle issue for you to consider:
Just about all of the (non-canard) airplanes flying in the world today
have downforce on the tail. Looking at the highly cambered airfoils that
Zenith airplanes use, it is just about guaranteed that there is a large
pitching (twisting) moment on the airfoil, meaning that a significant
amount of downforce is needed in the back to balance it.
As any airplane designer will tell you, at any "normal" CG the wing and
tail have to be at some angle to each other for the airplane to be
stable. This angle I believe is called "decalage" and has nothing to do
with the fuselage at all. It is the relationship between wing and
stabilizer. Once that decalage angle is determined you can just put the
fuselage in between them at whatever angle gives the lowest cruise drag.
HOWEVER, once an airplane has been built, when you need to adjust the
angle of the tail for some reason, it will change BOTH the decalage AND
the angle of the wing/fuselage (incidence). So if you just change the
tail angle and nothing else, you can be improving the wing/tail
relationship on one hand, and screwing up the fuselage angle worse on
the other hand.
So, when professional designers have to adjust the decalage angle, they
usually make the adjustment at BOTH the wing angle of incidence and the
tail angle... to keep the fuselage flying straight after they changed
the relationship between the wing and tail.
Bill Berle
n85ae
Posted: Mon Feb 11, 2008 2:03 pm Post subject: Re: Sabrina Re: pitching the H-stab |
Pitch trim in my Kitfox is via an actuator that moves the entire horizontal
stab. Full deflection on the leading edge is several inches up and down.
Obviously it is NOT a 601, however what it tells me is that the minor
changes you are talking about will probably not dramatically affect the
planes handling to the point of dangerous. But if you overdo it you may
have to use heavier than normal stick force if you go the wrong way with
your change and can't compensate with trim.
There's always variation from airplane to airplane, minor changes to
the horiz. stab incidence to adjust the trim is a perfectly reasonable
thing to do. Just go a little at a time and you'll be ok.
Jeff
Posted: Mon Feb 11, 2008 2:17 pm Post subject: Sabrina Re: pitching the H-stab |
Isn't that the way a Mooney does it?
-- Craig
Posted: Mon Feb 11, 2008 3:14 pm Post subject: Sabrina Re: pitching the H-stab |
I was talking about geometric decalage, which is easier to deal with and
more appropriate when talking about cruise stability. Airplanes very
rarely fly at the wing's zero-lift angle, and if they do... it ain't for
long
It appears that this all started with someone wanting to deviate from
Chris' designed decalage angle, because someone was unhappy with the
elevator authority or the force required for liftoff and flare. So my
point was that if you want to deviate from that decalage angle you
should know whether it was really wrong in the first place, and then
whether changing it could cause some unwanted side effect. For example,
if the leading edge of the stabilizer were lowered, there is some
possibility that the "restorative force" applied by stabilizer in spin
recovery could be weakened, in other words the airplane would tend to
not lower the nose as much as otherwise. That's the kind of thing that
needs a real aero engineer to look into.
Bill
Sabrina wrote:
You assume the change was made after the rear spar was set. This is a long design process that involves a little bit of math. It is inherent in creating an E-LSA as opposed to an amateur built aircraft. I am sure Chris can help you maintain his desinged decalage and supply you with the proper dimension (distance from main longeron to top rear spar) for the Riblett GA 35-A-415 airfoil (601 wing) depending upon the angle of incident you choose for the horizontal stab. You guys are almost as tough as my professors! Ouch. Where you referring to the aerodynamic decalage or the geometric decalage? In building an E-LSA, I had to get it right the first time because once certified, it takes an IA to make a major alteration to an E-LSA, and this would be a major alteration. Again, what is right for my craft might not be right for yours. Do you have a 3" spacer and metal prop? Do you have 90 extra pounds spread across the airframe compared to the AMD? Etc... Relax, an!
d enjoy the process...
http://forums.matronics.com/viewtopic.php?p=163557#163557
john.marzulli(at)gmail.co Guest
Posted: Mon Feb 11, 2008 3:42 pm Post subject: Sabrina Re: pitching the H-stab |
..and Cub Crafter's PA-18.
DO NOT ARCHIVE
On Feb 11, 2008 2:14 PM, Craig Payne <craig(at)craigandjean.com (craig(at)craigandjean.com)> wrote:
[quote] --> Zenith-List message posted by: "Craig Payne" <craig(at)craigandjean.com (craig(at)craigandjean.com)>
-- Craig
Jeyoung65(at)aol.com Guest
Posted: Mon Feb 11, 2008 3:52 pm Post subject: Sabrina Re: pitching the H-stab |
Also used to fly faster that mach 1
In a message dated 2/11/2008 6:43:10 P.M. Eastern Standard Time, john.marzulli(at)gmail.com writes:
[quote]...and Cub Crafter's PA-18.
DO NOT ARCHIVE
[quote]--> Zenith-List message posted by: "Craig Payne" <craig(at)craigandjean.com (craig(at)craigandjean.com)>
-- Craig
Posted: Mon Feb 11, 2008 4:02 pm Post subject: Sabrina Re: pitching the H-stab |
Berle,
give the young lady a brake(aero pun intended)! Telling her a "real engineeer" needs to look at this issue is a bit hubris for the fact that she redesigned an engine, built the plane and flew it. If she did the math, give her the respect she deserves. we may not al agree to mess with the angles , I think some of us forget the kit is just a kit, and you are the manufacturer, did you forget the word"experimental" in your vernacular?
You go girl!
Juan
barcusc(at)comcast.net Guest
Posted: Mon Feb 11, 2008 4:21 pm Post subject: Sabrina Re: pitching the H-stab |
Chris Heinz is a "real engineer" and I would trust his opinion or I would
not have bought the 601 XL in the first place. I have had the pleasure of
discussing concerns with him more than once and he always gave a thoughtful
and clear response. I am convinced Chris does not take questions or concerns
lightly, if the change or adjustment you are asking about is anywhere near a
grey area I am sure he would immediately inform you of the danger involved.
Clyde Barcus
601 XL
To: <zenith-list(at)matronics.com>
Sent: Monday, February 11, 2008 5:10 PM
Subject: Re: Sabrina Re: pitching the H-stab
long
point was that if you want to deviate from that decalage angle you should
know whether it was really wrong in the first place, and then whether
changing it could cause some unwanted side effect. For example, if the
leading edge of the stabilizer were lowered, there is some possibility
that the "restorative force" applied by stabilizer in spin recovery could
be weakened, in other words the airplane would tend to not lower the nose
as much as otherwise. That's the kind of thing that needs a real aero
Bill
> across the airframe compared to the AMD? Etc... Relax, !
an!
planecrazydld(at)Yahoo.co Guest
Posted: Mon Feb 11, 2008 4:25 pm Post subject: Sabrina Re: pitching the H-stab |
some of the mooneys pitch (and yaw as well i think) the entire rear tip of the fuselage supporting the entire empennage.
Craig Payne <craig(at)craigandjean.com> wrote:[quote] --> Zenith-List message posted by: "Craig Payne"
-- Craig
tigerrick(at)mindspring.c Guest
Posted: Mon Feb 11, 2008 9:01 pm Post subject: Sabrina Re: pitching the H-stab |
Hear, hear, Juan!
Right on the money, compadre!
No aircraft designer, no matter how talented, can possibly anticipate the variety of subtle CG shifts in every single flying example that is built under the amateur category. Sure, there's an acceptable CG range, but I doubt any two 601s will leave the hangar with identical weights or CGs.
The proof of the pudding is the flight test, period. This is where you really find out if the slow speed characteristics of the aiplane are acceptable, or not. Since the 601 wants to fly at a comparatively low airspeed (about 45 mph in my case), it's important that there's enough control authority available to take full advantage of it.
After all, it's not the designer's job to fine tune each and every airframe to perfection - it's ours. And to fly an out of trim, or out of rig airplane "because the plans said so" is missing the point entirely. The designer provides the broad brush strokes. WE fill in the details.
Sabrina, you GO girl!!
Rick Lindstrom, Contributing Editor
KITPLANES Magazine
N42KP
jlatimer1(at)cox.net Guest
Posted: Tue Feb 12, 2008 9:38 am Post subject: Sabrina Re: pitching the H-stab |
Super Cubs do it this way also.
Jerry
NYTerminat(at)aol.com Guest
Posted: Mon Feb 18, 2008 10:32 pm Post subject: Sabrina Re: pitching the H-stab |
Hi all,
With all the talk of pitching the horizontal stabilizer lately I have a quick question. I am doing my conditional inspection on my 701 and decided to replace the front horizontal stabilizer brackets to the .063 material. There were no cracks in my old ones but I figured I might as well bite the bullet now while the weather is keeping me from flying anyway. I have always felt that I was flying in a nose high attitude while at cruise and that I do not see the higher MPH that others see. I purchased a digital level and have discovered that my horizontal stabilizer was about a half of a degree low in the front (approx 3 mm). I plan on raising it one degree so that I will be a half of a degree higher in the front based on the A-E line. I am wondering if this is a good idea as I believe this will get me flying in a better attitude at cruise and pick up some speed. Any thoughts?
Bob Spudis
N701Zx/ CH-701/ 912S/ 140hrs
In a message dated 2/11/2008 2:20:58 P.M. Eastern Standard Time, chicago2paris(at)msn.com writes:
| Quote: | --> Zenith-List message posted by: "Sabrina" <chicago2paris(at)msn.com>
Zenith Aircraft indicated it was a "good idea." I can't imagine that they would say so without calling up Chris in France. So too, the math seems to work out, but more importantly, people have done it and proved it. (Bryan, Scott and several others.) I personally would not go to 3 degrees. The AMDs appear to be about 1 degree down, but they will not confirm that. The problem may be that some actually have the stab pitched slightly up, and that is in fact more dangerous than pitching it slightly down with a nose heavy aircraft. Cessna has proven than tail down force on slow aircraft is an acceptable design. W&B on a 601 is critical. One must always start with an accurate weight and balance sheet (in other words, don't use bathroom scales.)
http://forums.matronics.com/viewtopic.php?p=163526#163526
Delicious ideas to please the pickiest eaters. Watch the video on AOL Living.
bryanmmartin
Posted: Tue Feb 19, 2008 12:29 am Post subject: Sabrina Re: pitching the H-stab |
The stabilizer has little to do with the cruise flight attitude of the fuselage, it mainly has to do with the trim condition of the airplane. If you can trim out the elevator forces in cruise without excessive trim tab deflection, re-pitching the stabilizer won't help you. I re-pitched my stabilizer because I couldn't trim out the stick forces, not because the attitude of the airplane was wrong. I had to hold back pressure on the stick all the time to keep the plane from diving.
The cruise flight attitude of the fuselage is controlled mainly by the angle of incidence of the main wing. Increasing the angle of incidence of the main wing will bring the nose of the fuselage down, but then you will also have to pitch the stabilizer up to get it back into trim.
On Feb 19, 2008, at 1:26 AM, NYTerminat(at)aol.com (NYTerminat(at)aol.com) wrote:
Hi all,
Bob Spudis
Bryan Martin
N61BM, CH 601 XL,
RAM Subaru, Stratus redrive.
do not archive.
_________________ --
Bryan Martin
do not archive. |
n801bh(at)netzero.com Guest
Posted: Tue Feb 19, 2008 5:12 am Post subject: Sabrina Re: pitching the H-stab |
Hi Bob. I built my 801 as close to the specs as I could and measured my wing and horizontal stabilizer incidence multiple times. I am very confident I have my plane right and it to flys nose up. If I set it up in level cruise flight and add just a little bit of flaps the nose drops a couple of degrees and it picks up about 4 mph. I don't know if I want to try to change the tail setting cause mine is all painted and it will be major surgery to switch.
Ben Haas
N801BH
www.haaspowerair.com
Hi all,
Bob Spudis
">http://www.matronics.com/Navigator?Zenith-List
tronics.com
www.matronics.com/contribution
_____________________________________________________________
Click here for legal help with your social security disability!
daveaustin2(at)primus.ca Guest
Posted: Tue Feb 19, 2008 6:25 am Post subject: Sabrina Re: pitching the H-stab |
Bob,
I'd be interested to know where your trim tab is positioned when at cruise with what I would describe as your "usual" loading of the aircraft? (conditions you fly under most of the time). It should be at a neutral position. If not, then adjust the hor. stab angle to give that condition. (Does mean you have to land without moving the elevator trim a few times). That produces least drag for that flying condition. I slotted the rear attachments to give me the adjustment, then replaced them with unslotted.
Following from that, the trim tab needs to be large enough to be able to trim properly for approach and landing.
Dave Austin 601HDS - 912, Spitfire Mk VIII
Posted: Tue Feb 19, 2008 7:32 am Post subject: Sabrina Re: pitching the H-stab |
Ben, Mine reacts the same way. I didn't want to mess up my paint job either but I am using an artist brush to repaint the rivets, primed them last night, will see today how it comes out. Every once in a while I will hit a sweet spot and the nose will be a little lower in cruise and the plane will do about 6-7mph faster, I can usually find the spot if I bump the nose down in cruise but not all the time. The plane will fly hands off with the elevator trim in neutral but I know it can do better.
Bob
In a message dated 2/19/2008 8:14:04 A.M. Eastern Standard Time, n801bh(at)netzero.com writes:
Ben Haas
N801BH
Posted: Tue Feb 19, 2008 7:45 am Post subject: Sabrina Re: pitching the H-stab |
Dave,
My trim is centered in cruise. I usually fly alone, not much change with a passenger. My CG is slightly aft but well within range. I like the idea of a slotted bracket to try different settings. If this setting that I am choosing doesn't work, I may try the slotted bracket to adjust the rear of the stabilizer. How much of a difference does one degree or 6 mm make? I know that the 601 and 701 are different but they would probably react similar.
Bob
In a message dated 2/19/2008 9:26:55 A.M. Eastern Standard Time, daveaustin2(at)primus.ca writes:
| Quote: | Bob,
Posted: Tue Feb 19, 2008 8:21 am Post subject: Sabrina Re: pitching the H-stab |
Bob,
The slot was about 1/4 inch long before I got it the way I wanted. Be sure to leave good edge clearance to the slot!
Re other notes, I haven't been able to figure out how you can put the nose down without losing height, since the wing incidence would change from level flight. If the flaps or ailerons are adjusted for greatest speed, I understand that, but then wouldn't you want to adjust the hor. stab for trim neutral?
