				 Posted: Sat Feb 16, 2008 8:34 pm    Post subject: WOW - What a difference (Cooling/Plenums) |
				Just an opinion on the subject of plenums. If you are looking for the very
 last ounce of speed, probably at the sacrifice of engine access, by all
 means, install a plenum. For a given intake and outlet size, you should get
 a few percentage points better cooling because you should have fewer air
 leaks.  But it'll be a single digit savings - probably low single digits.  A
 plenum isn't going to solve serious cooling problems.  Those are usually
 caused by something unique (or not quite right) with the airplane.
 In my case, the oil temperatures were 220f in cruise on warm days for the
 first year or so I flew my RV-6.  In the end, the high temps boiled down to
 two issues: I had the first generation Positech oil cooler, which was a bad
 product.  Bad enough that Positech eventually offered free replacements.
 Also, I hadn't cut a large enough hole in my baffling to feed air to the oil
 cooler.  A plenum wouldn't have solved either of those issues.
 There are boatloads of RV's out there with the stock baffling and cowl and
 the vast majority of those airplanes cool well.  The stock system is simple
 to install (and if you use a plenum, Van's baffle kit will probably form
 much of your plenum anyway), inexpensive, and effective.  Unless you are one
 of those individuals looking for that last 1-2% in speed or efficiency (at
 the expense of time, money, and servicability), the stock baffles and
 cowling work just fine.
 As a side note, it was humid here in N. GA this morning.  Humid enough that
 I pulled prop contrails for the entire length of my takeoff roll and
 probably another 3,000 feet down the runway on climb-out.  It was kinda neat
 seeing a swirling vortex wrapped around the airplane...
 KB
  |  | - The Matronics RV-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		JohnInReno
				 Posted: Sun Feb 17, 2008 2:44 pm    Post subject: WOW - What a difference (Cooling/Plenums) |
				Pictures Please!
 Kyle Boatright wrote:
  that I pulled prop contrails for the entire length of my takeoff roll
  and probably another 3,000 feet down the runway on climb-out.  It was
  kinda neat seeing a swirling vortex wrapped around the airplane...
  KB
 john
  _________________ John Morgensen
RV-9A - Born on July 3, 2013
RV4 - for sale |
