		Troy Maynor
				 Posted: Tue Feb 19, 2008 7:25 pm    Post subject: Monowheel Capture |
				Hi Folks,
 Can some of you measure the distance that the sides of the ramp comes up and
 has contact on the sides of the landing gear frame? Also note if you have
 the larger diameter tire. I have the Air Trac tire and the one-off steel
 trailer that I bought from Europa USA years ago. The sides didn't come up
 very far so I had some extra length added to the side tabs to better capture
 the gear frame. Now the brake caliper is hitting when I roll the plane onto
 the ramp. So I'll have to cut some off again. It never ends.......
 Troy Maynor
  |  | - The Matronics Europa-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		rlborger(at)mac.com Guest
				 Posted: Tue Feb 19, 2008 7:49 pm    Post subject: Monowheel Capture |
				Troy,
 I just put my monowheel fuselage onto the Europa trailer this week and
 took it to the airport.  The only problem was the plates that were
 supposed to capture the tailwheel.  There was no way to fit them onto
 the trailer.  Way too much crap in the way.  Anywho,  when I have an
 opportunity I'll run out to the airport and take some pics and
 measurements for you.
 Good building and great flying,
 Bob Borger
 Europa Kit #A221 N914XL, XS Mono, Intercooled 914, Airmaster C/S
 http://www.europaowners.org/N914XL
 (90%) tail kit done, wings closed, cockpit module installed, pitch
 system in, landing gear complete, rudder system in with Singleton Mod,
 outrigger mod in, Fuselage Top on, lift/drag/flap pins in, wing
 incidence set, tie bar in, flap drive in,  baggage bay in. Fuel system
 complte.  Rotax and Airmaster installed.  Mods 62, 66, 70 & 72 done.
 Compled the instrument panel install.   Europa interior kit being
 installed.  Installed windows.  Working in -  25 Electrical, 28 Flaps,
 30 Fuel System, 32 Tail, 34 Door Latches & 35 Doors, 37 Finishing.
 Mostly finishing these days.
 3705 Lynchburg Dr.
 Corinth, TX  76208
 Home:  940-497-2123
 Cel:  817-992-1117
 On Feb 19, 2008, at 21:18, Troy wrote:
  Hi Folks,
  comes up and
  have
  steel
  come up
  capture
  plane onto
  Troy Maynor
		96victor(at)gmail.com Guest
				 Posted: Wed Feb 20, 2008 5:05 pm    Post subject: Monowheel Capture |
				Hi Troy
 I also have a larger tire and had the same problem.  I added a piece of steel to extend the hinge of the ramp aft so then the existing ramp would hold the arms.  Fairly easy to do.  I can take photos if you need.
 Tom
 On Tue, Feb 19, 2008 at 7:18 PM, Troy <wingnut54(at)charter.net (wingnut54(at)charter.net)> wrote:
 [quote] --> Europa-List message posted by: "Troy" <wingnut54(at)charter.net (wingnut54(at)charter.net)>
  Hi Folks,
  Troy Maynor
		Troy Maynor
				 Posted: Wed Feb 20, 2008 6:54 pm    Post subject: Monowheel Capture |
				Tom,
 Yes, a picture or two here would be great. Maybe of the hinge area and the LG frame contact area if your plane is on the trailer now. Thanks.
 Troy
 Visit -  www.EuropaOwners.org
				 Posted: Sat Feb 23, 2008 7:06 am    Post subject: Monowheel Capture |
				Troy,
 I have posted a number of pics of my monowheel on the trailer.
 Unfortunately, the fuselage is all masked up for painting so you can't
 see the tire.  Not much text yet, but some comments in the pics.
 Perhaps you can see what you needed.  The pics are in my Trailer album.
 Bob Borger
 3705 Lynchburg Dr.
 Corinth, TX  76208
 Home:  940-497-2123
 Cel:  817-992-1117
 On Feb 20, 2008, at 20:47, europaman wrote:
  Tom,
  Thanks.
  Troy
		Troy Maynor
				 Posted: Sat Feb 23, 2008 8:09 am    Post subject: Monowheel Capture |
				Thanks Bob for posting the pix. They are helpful. Now I've got more work to do.
 Troy
