Posted: Sun Feb 17, 2008 4:05 pm Post subject: Vg's |
I liked Gene's idea of VG's on one wing. That would indeed be a control test. Cheap, too. I wouldn't volunteer even if the Firestar was flying, as I couldn't tell the difference with my limited experience. I have read up on them, but never saw anyone try it on one wing only. I think it would be safe enough, but tricky doing a normal stall landing.
FS?
biglar
Posted: Sun Feb 17, 2008 4:35 pm Post subject: Vg's |
In all serious-ness, I have to say, "Don't Do It." Someone just might get the idea to give it a whirl and actually try putting vg's on one wing without thinking it thru. This is only my personal reasoning, but I'd think that anything that might alter the flying characteristics of a wing could possibly cause a wing to stall before the other one and result in a low altitude spin. Could well be deadly. Lar.
william sullivan wrote: [quote] I liked Gene's idea of VG's on one wing. That would indeed be a control test. Cheap, too. I wouldn't volunteer even if the Firestar was flying, as I couldn't tell the difference with my limited experience. I have read up on them, but never saw anyone try it on one wing only. I think it would be safe enough, but tricky doing a normal stall landing.
FS?
Larry Bourne
Santa Fe, NM
Building Kolb Mk III
"Vamoose"
www.gogittum.com
www.gogittum.com/blog[b]
_________________ Larry Bourne
Palm Springs, CA
Building Kolb Mk IIIC
"Vamoose" |
beauford173(at)verizon.ne Guest
Posted: Sun Feb 17, 2008 4:56 pm Post subject: Vg's |
...if VG's didn't work...seriously doubt that Boeing, Airbus, Lockheed, et.al. would
have gleefully festooned the wing and tail airfoils of their hardware with them for
the past three or four decades as a mere science experiment or a joke... whaddya think?
..just a thought...
Idle Beauford
FF-076
Brandon Fl
Posted: Sun Feb 17, 2008 5:07 pm Post subject: Vg's |
Beauford:
I have never said VG's do not work.
Simply have never found a requirement for them on my airplanes.
I can imagine those manufacturers had a requirement for them long before they started sticking.
..just a thought...
Idle Beauford
_________________ John Hauck
Titus, Alabama |
Posted: Sun Feb 17, 2008 5:55 pm Post subject: Vg's |
...but they LOOK so good, John....and they whistle when ya
go fast.... and besides... what's good
enough for Boeing Bullmoose is good enough for beauford....
...count me in...
P.S. What Big Lar said...!!! Dumb as 'ol beauford may be... he
would never recommend intentionally setting up an asymetric
stall-control scenario.... VG's on one wing be mucho bad demo concept.
If someone actually tries it, can beauford have yer watch...? (see me offline,
preferably prior to the attempt...)
Beauford
FF-076
jindoguy(at)gmail.com Guest
Posted: Sun Feb 17, 2008 8:53 pm Post subject: Vg's |
If anyone out there does decide to try the VG's on one wing test, may I suggest you read the book, "Anatomy of a Spin" by John Lowery first.
Rick
On Feb 17, 2008 7:52 PM, beauford T <beauford173(at)verizon.net (beauford173(at)verizon.net)> wrote:
[quote] ...but they LOOK so good, John....and they whistle when ya
...count me in...
Beauford
FF-076
JetPilot
Posted: Sun Feb 17, 2008 11:06 pm Post subject: Re: Vg's |
VG's on one wing would be VERY DANGEROUS. I would never do a test like that. You could easily find yourself in an uncontrollable and unrecoverable spin. You could also find yourself in an uncontrollable roll even at normal speed as one wing could have significantly more lift than the other at a given angle of attack.
If you want to test VG's, first fly your plane without VG's, and then put them on and record all your numbers again. If you think you may not want the VG's permanently, put them on with double sided 3M automobile trim tape ( Not the cheap stuff ) that is what Possums and I did. That way you can get the VG's off if you do not like them. My results with putting VG's on were so good, I will never again fly my Kolb without them. Of the many people that have put VG's on their Kolbs, I have never heard of anyone not liking them and taking them off, that in itself should tell you something.
Kolb MK-III Xtra, 912-S |
ez(at)embarqmail.com Guest
Posted: Mon Feb 18, 2008 6:49 am Post subject: Vg's |
On Feb 17, 2008, at 11:50 PM, Richard Girard wrote:
| Quote: | If anyone out there does decide to try the VG's on one wing test,
first.
Rick
>>>As for a true apples to apples VG test we need to have this
settled once and for all by having a well seasoned kolb pilot try
slow flight to stall with VG's on just one wing. < g > <<<
Hey guys,
Please notice what I said,
I said ,,,,,, a "well seasoned " ,,,, kolb pilot ,,,,, and please also
notice WHO I wrote that too ; ^) ,,,,,, and please notice the ,,,,, <
g >.
I'm sure the degree of my seriousness in that idea was not lost on
John, and If anybody were actually able to pull it off I'm sure it
would be none other than John.
So if you are NOT John Hauck ,,,,,,, please DO NOT ever try my
DANGEROUS test suggestion.
Eugene Zimmerman
Posted: Mon Feb 18, 2008 7:03 am Post subject: Vg's |
| Quote: | DANGEROUS test suggestion.
Eugene Zimmerman
Gene Z:
I relinquished my "test pilot" duties some time back.
Nothing like flying something tried and true. The old mkIII is like putting
on an old pair of work boots.
Titus, Alabama |
a58r(at)verizon.net Guest
Posted: Mon Feb 18, 2008 9:05 am Post subject: Vg's |
At last we now have a dagger to put through the heart of SeaFoam: VGs!
regards,
Bob N. FireFly 070 Old Kolb
Posted: Mon Feb 18, 2008 9:37 am Post subject: Vg's |
....what's Seafoam.....?
beauford
Ralph B
David Lucas
Joined: 10 Jan 2006 Posts: 79 Location: Europe. based Amsterdam NL
Posted: Wed Feb 20, 2008 8:59 am Post subject: Re: Vg's |
VG's on one wing . . . . It's been done !
Was talking to a certain KOLB pilot one day at a fly-in and was discussing the Mklllxtra and the pro's and con's of fitting VG's when this admission came out. The resulting test stall 'maneuver' was, as he put it, 'very interesting !'
I've just checked a definition of 'maneuver'. It says " A deliberate coordinated movement requiring dexterity and skill " Not so sure that 'maneuver' is the correct word now. Yes it was deliberate but I'm not so sure you could call the event 'coordinated' although it did, no doubt, require 'dexterity and skill' in the following recovery.
Anyway, the VG's are on both wings now that his curiosity is satisfied, and I got the distinct impression that he's not going to do that again.
If that particular KOLB pilot (who monitors and occasionally contributes to the list) wants to post some info on this but still remain anonymous , then please contact me off list and I'll 'cut 'n paste' your reply .
David.
JetPilot
Posted: Wed Feb 20, 2008 9:40 am Post subject: Re: Vg's |
I have also gotten some private emails for information about VG's from people that want to install them, and I will respect their privacy.
The bigger issue here is that it is very sad that a small group of individuals has created such an atmosphere of intimidation, and group bashing on this list that people are now afraid to post good information on Kolbs. I cant say I blame people for not wanting to post information that this group does not like, just look at the two nasty responses I got yesterday that were nothing more than nasty and personal attacks, and were quietly supported.
If you agree with this small " Clique " of individuals, personal attacks and nasty posts are quietly ignored and supported by this group. If you disagree with one of the members of this small group, there is a quick negative public response by them. There is not a standard on this list of keeping things civil, there is a standard of keeping posts civil, unless some people don't like what someone is saying, then personal attacks and nasty posts are tolerated.
The fact that people are now afraid to post good and accurate information on Kolbs here on the list speaks very poorly for this group.
Mike Bigelow
lcottrell
Posted: Wed Feb 20, 2008 11:11 am Post subject: Vg's |
Posted: Wed Feb 20, 2008 11:36 am Post subject: Vg's |
On Feb 20, 2008, at 12:40 PM, JetPilot wrote:
| Quote: | If you have no fear you did not go as fast as you could have !!!
Hey guys
If you have not yet created an atmosphere of intimidation, and group
bashing on this list your ego is not yet as inflated as it could be.
jb92563
Joined: 23 Mar 2007 Posts: 314 Location: Southern California
Posted: Wed Feb 20, 2008 12:17 pm Post subject: Re: Vg's on one wing only |
Ohh my god......BAD VERY BAD idea to put VG's on one wing only.
That is a sure way to get someone hurt or worse!!!
What do you think would happen if one wing stalled before the other...say on the landing flair?????
Can anyone say SPIN?!!!!
Geez, there are some people who find a straight forward stall to be a problem, so for gods sake don't suggest they might survive a spin at low altitude.......Yikers!!!!!
Also, think about this.....one wing develops full lift(VG's) on takeoff before the other is even flying.....nice roll to the un-VG'd wing......maybe even all the way inverted if your not reacting fast enough.
Or how about the unequal lift causing the need for constant roll correction .....better get to the gym and work those biceps.
NO nothing good can come of VG's on one wing only!
Please don't try it!
_________________ Ray
Moni MotorGlider
Schreder HP-11 Glider
Grob 109 Motorglider
Do Not Archive |
jb92563
Posted: Wed Feb 20, 2008 12:31 pm Post subject: Re: Vg's |
Is there a thread in the forum for making/installing the VG's?
I was wondering how they are made, how they are attatched to the Polyfiber? and where on the wing chord are they located for optimal effect?
Also interested if anyone has done an oil flow test on the wing to get a better idea of what the air is doing normally and around the VG's.
It would certainly confirm where to place the VG's if nothing else.
I suspect nobody has volunteered to get their wing oily yet....I don't blame them.
I also know of some other type of Turbulators that can substancially improve wing performance, more aimed at gliders, however may work on a Kolb wing as well.
Moni MotorGlider
Do Not Archive |
dhkey(at)msn.com Guest
Posted: Wed Feb 20, 2008 12:32 pm Post subject: Vg's |
I'd say "quietly praised" in this case.
[quote] From: lcottrell(at)fmtcblue.com
Subject: Re: Re: Vg's
Date: Wed, 20 Feb 2008 12:08:46 -0700
--> Kolb-List message posted by: "Larry Cottrell" <lcottrell(at)fmtcblue.com>
Posted: Wed Feb 20, 2008 2:17 pm Post subject: Vg's |
Ray, ck Archives.
