Roll Bar
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> RV4-List
baremetl(at)gvtc.com
PostPosted: Fri Feb 22, 2008 10:32 pm    Post subject: Roll Bar Reply with quote
Does anyone have any info on how modify the original Van's roll bar on an rv-4 to the style that has a rounded top. I have seen these on a few -4's and HRII's over the years and wish to make one for an F-1 rocket with a tip over canopy. Perhaps someone knows of a supplier?
Thanks.
Ivan Haecker -4 1437 hrs. S. Cen. Tx
- The Matronics RV4-List Email Forum -
http://www.matronics.com/Navigator?RV4-List
sonex32(at)earthlink.net
PostPosted: Sat Feb 23, 2008 8:36 am    Post subject: Roll Bar Reply with quote
Ivan,
I made one from scratch using a U tube and two straight pieces of tubing. Draw what you want full size and it will be easy to cut the U tube in the right place. You'll have to Google the U tube, as I no longer have the URL.
http://picasaweb.google.com/tonyboytoo/RV3BFuselage/photo#5136844894985929762
Tony
PostPosted: Sat Feb 23, 2008 9:33 am    Post subject: Roll Bar Reply with quote
Ivan,
Here's the link for the U tube: http://www.magnumforce.com/ubend.asp
And here's another stab at the roll bar photos: http://picasaweb.google.com/tonyboytoo/RV3BFuselage
Tony
PostPosted: Sun Feb 24, 2008 9:30 pm    Post subject: Roll Bar Reply with quote
Thanks to both of you for your responses. One other question: When attaching the curved top piece to the two straight side bars, is a short piece of tubing inserted before joining the pieces to strengthen what would otherwise be a weaker butt joint?
Ivan Haecker -4 1439 hrs. So. Cen. Tx
PostPosted: Mon Feb 25, 2008 4:14 am    Post subject: Roll Bar Reply with quote
Ivan,
With a proper weld I don't think the joint will be any weaker than the base metal. On mine, the U bend is mild steel and the straight legs and braces are 4130. After all the pieces fit properly, I safety wired the assembly to a plywood board for tack welding.
Tony
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> RV4-List All times are GMT - 8 Hours
