LarryM
Posted: Sat Feb 23, 2008 7:27 am Post subject: Oil injection filter |
Hi,
I'm trying to get some guidance. The oil lines into my pump are getting rather hard. ('93) I want to change them and I thought to change the filter at the same time. The only oil filter that I can find for Ski Doo is a small inline 1/4" barb filter. The oil pump has a 5/16"(+/-) barb. What is the proper filter to use, and how often should it be replaced? According to the local sled shop, the small one is what Ski Doo calls for on all of their injected engines. If that's the case, why the 5/16th fitting on the pump? What's a guy to do????
larry
Guy Buchanan
Posted: Sat Feb 23, 2008 8:44 pm Post subject: Oil injection filter |
At 07:27 AM 2/23/2008, you wrote:
| Quote: | According to the local sled shop, the small one is what Ski Doo
Hi Larry,
I assume we're talking 582 here? I suspect the 1/4" is fine
from a flow standpoint, the oil moves awfully slow. I buy my oil
filters from CPS (http://www.800-airwolf.com/) and they pretty much
match the oil injection system barb. I change it at annual, though
I've never heard one way or another. (I guess I should have cut my
last one open to find out if anything was inside.)
Guy Buchanan
San Diego, CA
Deceased K-IV 1200
A glider pilot too. |
dave
Posted: Sun Feb 24, 2008 4:16 am Post subject: Re: Oil injection filter |
| Quote: | Hi Larry,
Guy Buchanan
No the 1/4" is not the right one. you can get the 5/16"s one for a 5$ or so.
Use a urethane line on it as well. And you don't have to cut it open to see what is inside as you can look into the end of it once off and see and debris on the screen. It is just a plastic housing with a screen inside. I would continue to change them annually.
Toll free line to get them here http://www.rotaxservices.com/
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube |
