		Mike Whisky
				 Posted: Wed Jan 23, 2008 3:03 pm    Post subject: Trimming the cowling |
				Guys,
 I am hesitating to trim the cowling due to the fact that the straight edge method doesn't give me the possibility to make a line along the side.
 How did you do it?
 Michael
  _________________ RV-10 builder (flying)
#511 |
		dlm46007(at)cox.net Guest
				 Posted: Wed Jan 23, 2008 3:51 pm    Post subject: Trimming the cowling |
				You need the flexible steel scale which bends nicely. Another technique is
 to mark the distances on the fuselage about every three inches and connect
 the dots. Then make an initial cut about .1" short of the aft end of the
 starting cowl so that additional trimming can take place with files and
 sanding blocks. IIRC we started with the bottom and matched the top to it.
		Jim Berry
				 Posted: Wed Jan 23, 2008 6:57 pm    Post subject: Re: Trimming the cowling |
				I was able to trim mine to a very close fit with 2 layers of masking tape. Two inch wide tape works well for the cowl. Position the first layer of tape so that the forward edge matches the forward edge of your sheet metal. Position your upper or lower cowl per Van's instructions. Now position a second layer of tape the same width as the first so that the aft edge matches the aft edge of the first layer of tape. The forward edge of the second layer is your cut line.
 Jim Berry
 40482
		drfred(at)suddenlinkmail. Guest
				 Posted: Wed Jan 23, 2008 8:14 pm    Post subject: Trimming the cowling |
				Michael;
 I did the first cut on the side of the cowl tonight.  I used a laser
 level and picked three points, one at the inside of the inlet, one at
 the outside and one at the aft edge, then drew the line on the cowl.
 I'll use that as my reference line.  Next, will trim the bottom 1/2 up
 to that line.  Will see how well that works tomorrow night.
 Question to those who used skybolt fasteners for the sides.  How thick
 of an aluminium strip did you use for the side fasteners?  0.050 as per
 the top strip?
 Dr Fred.
 Michael Wellenzohn wrote:
  Guys,
  How did you do it?
  Michael
  RV-10 builder (engine, prop, finishing)
  #511
  http://forums.matronics.com/viewtopic.php?p=160067#160067
		dmaib@me.com
				 Posted: Wed Jan 23, 2008 8:27 pm    Post subject: Trimming the cowling |
				Jim, I am confused. It sounds like the second layer of tape is
 exactly on top of the first if the aft edge of the second layer
 matches the aft edge of the first layer. I must be missing something
 here. (would not be the first time!) Is the first layer of tape on
 the sheet metal? The second layer on the cowl? Now I am confusing
 myself even more! ^_^
 David Maib
 40559
 Jim Berry
 40482
 http://forums.matronics.com/viewtopic.php?p=160132#160132
  _________________ David Maib
RV-10 #40559
New Smyrna Beach, FL |
		mritter509(at)msn.com Guest
				 Posted: Thu Jan 24, 2008 4:31 am    Post subject: Trimming the cowling |
				I used 0.063 all around which was hard to bend around the curves.  Also hard to bend the tabs to match the slope of the cowl.  If I had it to do over again I would try 0.050.
  Mark
  RV-10/N410MR
  185 Hrs.
 <html><div></div></html>
  > Date: Wed, 23 Jan 2008 22:11:10 -0600
  	  | Quote: | 	 		   From: drfred(at)suddenlinkmail.com
  Subject: Re: RV10-List: Trimming the cowling
  --> RV10-List message posted by: "Fred Williams, M.D." <drfred(at)suddenlinkmail.com>
  Michael;
  the top strip?
  Dr Fred.
  > --> RV10-List message posted by: "Michael Wellenzohn" <rv-10(at)wellenzohn.net>
  > Guys,
  > How did you do it?
  > Michael
  > #511
 &g=======================
 &g==
 Connect and share in new ways with Windows Live. Get it now!
		Jim Berry
				 Posted: Thu Jan 24, 2008 11:01 am    Post subject: Re: Trimming the cowling |
				David,
 The first layer of tape goes on so that the forward edge of the tape matches the forward edge of sheet metal. Position the cowl. The excess material on my untrimmed cowl overlapped the fuselage by less than 2", so the aft edge of the tape was still visible. The second layer of tape goes on top of the first tape so that the aft edges match. The second tape also overlaps the cowling, with the forward edge of the tape corresponding to the forward edge of the sheet metal. Perfect match. Try it and you will like it.
 Jim Berry
 40482
		dmaib@me.com
				 Posted: Fri Jan 25, 2008 3:21 am    Post subject: Trimming the cowling |
				Thanks Jim!
 David Maib
 40559
 On Jan 24, 2008, at 1:01 PM, jim berry wrote:
 David,
 Jim Berry
 40482
 http://forums.matronics.com/viewtopic.php?p=160274#160274
RV-10 #40559
		ricksked(at)embarqmail.co Guest
				 Posted: Thu Jan 31, 2008 7:08 am    Post subject: Trimming the cowling |
				For the last three days I have been staring at the first few steps of fitting the cowling...The plans indicate not to trim the sides but the sides interfere with getting to fit the nose ring. Any tips on the first few steps of the cowl? By using the straight edge method it looks like about an 1/8 or little more needs to come off the inner intake on the top cowl. The bottom doesn't sem to need any trimmig on the outer portion of the intakes. Comments on how those who have completed have done this? The masking tape method really looks like a great way to fit the aft part of the cowl...I just can't get a picture of how Vans wants you to do the first few steps.
 Rick S.
 40185
		Mike Whisky
				 Posted: Thu Jan 31, 2008 7:40 am    Post subject: Re: Trimming the cowling |
				Rick,
 since I just did this step here are my lessons learned.
 1.) I had to cut a bit off the outer air intake to get the parts together. However do not cut along to the sides too much. I did that but I guess this will be no problem.
 2) I put the two halves together and drilled & clecoed them as per plans.
 3) For the further steps I followed the plans.
 I am not done yet but I was irritated because the to halves didn't fit at the beginning and it looked so easy on the plans.
 I will try to update my web site www.wellenzohn.net with some pictures tonight.
 Michael
#511 |
		Jim Berry
				 Posted: Thu Jan 31, 2008 4:42 pm    Post subject: Re: Trimming the cowling |
				Rick,
 Like Michael I found it necessary to trim the inner and outer walls of the air inlet to get the upper an lower portions to come together. I also trimmed about 2" along the side of the upper cowl. Once you have the upper and lower cowl in position(let the sides of the lower cowl overlap the outside of the upper cowl) you can decide where you want the side seams to be. Lay out your chosen line on the upper cowl, cut and sand to a straight edge. Then you can use the masking tape trick to transfer that line to the lower cowl. I failed to mention in an earlier post that I also used the masking tape routine to fit my doors to the cabin top. It is much easier than trimming a little at a time until it comes together.
 Don't worry if you take off a little too much at some point. It is easy to build up an edge with a little flox if needed. Also I have seen several 10's where the rivets that hold the piano hinge to the cowling(and/or the paint) have started to crack out. I dealt with that by putting a 2 bid tape over the rivet lines.
 Jim Berry
 40482
				 Posted: Sun Feb 03, 2008 12:50 pm    Post subject: Trimming the cowling |
				I cut the top cowl in today...Guys and Gals I gotta tell you the masking tape to mark the firewall cut is the BOMB!!!! Perfect fit with only a few passes with the sanding block needed. The only thing I did different was to use the tape as a guide to apply a fine pen line that I cut just shy of then hand sanded to that line. I was worried the tape would gum up the cut off wheel. Dremel has a new line of cut off wheels added to their line of products made just for plastic, only metal was previously available. I use two wheels so far and that inclusdes the slot in the bottom cowl, my slot is much long due to the three blade prop...highly recommended these nifty cut off wheels.
 Rick S.
 40185
		Mike Whisky
				 Posted: Sun Feb 03, 2008 11:19 pm    Post subject: Re: Trimming the cowling |
				Rick,
 how long is the cut for the slot that you did. I also have a three blade prop and I know I need to cut the slot longer. It works right now because the front gear wheel sits on a box.
 Michael
#511 |
				 Posted: Mon Feb 04, 2008 7:24 am    Post subject: Trimming the cowling |
				I'll measure it tonight, funny I eyeballed the cut after looking at Wayne's RV-10 at Nellis. I should have been gambling yesterday because I hit it right on the money. It is about 4 inches from the front of the air intake.I'll make some .032 panels with nutplates on the cowl to tie it all together and return the cowl to proper strength on the bottom
 Rick S.
 40185
		Lew Gallagher
				 Posted: Sun Feb 24, 2008 5:29 pm    Post subject: Re: Trimming the cowling |
				Hey Jim,
 Just a follow up to tell you how much I appreciate your tape method.  Today I used it to mark the doors to fit the cabin.  I made the first cut a hair outside the line just in case I didn't get it quite right, but after sanding some, I went right to the line and it's about perfect!  How easy is that!
 Thanks again.  Later, - Lew
  _________________ non-pilot
crazy about building
NOW OFICIALLY BUILDER #40549
Fly off completed ! |
