Windshield scratches
n212pj(at)gmail.com
PostPosted: Sun Feb 24, 2008 7:52 pm    Post subject: Windshield scratches Reply with quote
Help! Scratches on windshield.............
Wanted to clean off the bugs and, using a nylon encased sponge, just about put as many scratches on the windshield that I could do. Any advice appreciated. I've looked up some products on ACS, but wondered if anyone had had such a problem and found a solution that they could recommend....PLEASE! Ugh.
John J
(on the GlaStar, not the unfinished -10)
pitts_pilot(at)bellsouth.
PostPosted: Sun Feb 24, 2008 8:14 pm    Post subject: Windshield scratches Reply with quote
Get a Micro Mesh kit. Follow the instructions and use copious amounts of water .... adding a little dish soap won't hurt either. Take your time. You'll get some sore arm muscles in trade for a clear view.
Linn
John Jessen wrote:
[quote] (at)page Section1 {size: 612.0pt 792.0pt; margin: 72.0pt 90.0pt 72.0pt 90.0pt; } P.MsoNormal { FONT-SIZE: 12pt; MARGIN: 0cm 0cm 0pt; FONT-FAMILY: "Times New Roman" } LI.MsoNormal { FONT-SIZE: 12pt; MARGIN: 0cm 0cm 0pt; FONT-FAMILY: "Times New Roman" } DIV.MsoNormal { FONT-SIZE: 12pt; MARGIN: 0cm 0cm 0pt; FONT-FAMILY: "Times New Roman" } A:link { COLOR: blue; TEXT-DECORATION: underline } SPAN.MsoHyperlink { COLOR: blue; TEXT-DECORATION: underline } A:visited { COLOR: blue; TEXT-DECORATION: underline } SPAN.MsoHyperlinkFollowed { COLOR: blue; TEXT-DECORATION: underline } PRE { FONT-SIZE: 10pt; MARGIN: 0cm 0cm 0pt; FONT-FAMILY: "Courier New" } SPAN.EmailStyle19 { COLOR: navy; FONT-FAMILY: Arial; mso-style-type: personal-reply } DIV.Section1 { page: Section1 } Help! Scratches on windshield.............
John J
eagerlee
PostPosted: Sun Feb 24, 2008 8:18 pm    Post subject: Re: Windshield scratches Reply with quote
I believe you have two choices. The first one is messy - ruins the paint job: replace the windscreen. The second one isn't as bad but probably takes just as much time: buff out the scratches with progressively finer abrasive material. The stuff you need comes in a kit with instructions. You start out coarse(400 grit?) and graduate up to 1800 or 2000 (crocus cloth?) with water. I've never done it but I hear it works. Mask off anything you don't want to scratch while you are removing scratches.
Paul Hahn
#40203
kearney(at)shaw.ca
PostPosted: Sun Feb 24, 2008 8:22 pm    Post subject: Windshield scratches Reply with quote
John
Every year there is a chap at KOSH who flogs a 3M scratch repair kit similar to:
http://www.skygeek.com/window-tools.html
I have watched while a window is scratch and the all the scratches are polished out. I tried this on my PA218 a few years back and ended up just replacing the window. If you try one of these products, get someone who knows what they are doing to do it for you. My impression is that these products can be very effective in the right hands.
Cheers
Les
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Jessen
Sent: February-24-08 8:47 PM
Subject: Windshield scratches
John J
Tim Olson
PostPosted: Sun Feb 24, 2008 9:09 pm    Post subject: Windshield scratches Reply with quote
I've used this kit before, on a couple different planes, and it
worked miracles.
http://www.aircraftspruce.com/catalog/cspages/scratchoff.php
It's called "Scratch Off".
I used it on all of my windows when I got done, to get rid of
any scratches I caused during construction.
John J
john_rv10(at)yahoo.com
PostPosted: Sun Feb 24, 2008 10:38 pm    Post subject: Windshield scratches Reply with quote
John,
This happened to an RV6 in our hangar. It was repaired by a chap who does motor cycle plastic repairs and after he finished you could not tell it had been done. The process was complex with many stages and he was clearly masterful at it. Having seen it done, I wouldn’t try it myself.
Good luck,
John Cleary
Sent: Monday, 25 February 2008 2:47 PM
John J
Release Date: 24/02/2008 12:19 PM
24/02/2008 12:19 PM
Tim Olson
PostPosted: Mon Feb 25, 2008 7:27 am    Post subject: Windshield scratches Reply with quote
After seeing a couple of posts about people saying that
this is a job left for the experts, I'd like to add
a counter opinion. Using the kit linked below, removing
scratches that are minor shouldn't concern anyone...it's
very simple to do and do right, and the compounds aren't
very aggressive.
I first saw them at OSH, and although was skeptical, I
actually got to watch them do a piece of window. It
amazed me a bit, so I bought a kit to use on my old
plane that had some sort of overspray feeling to the
plexi, and had scratches. It all polished right out
with no issues. So I didn't hesitate at all when my
-10 was done to use it on those windows to get rid of
any marks that were left. You get progressively
finer compounds to use, and on the -10 I only had to
use the 1 or 2 finest ones. I plan to try it by
hand this summer to get rid of some scratches left
by sun shields at OSH. And then I plan to be more
careful at OSH when using sunshields.
Using this kit is pretty simple.
worked miracles.
> John J
John Ackerman
PostPosted: Mon Feb 25, 2008 8:02 am    Post subject: Windshield scratches Reply with quote
Second that, Tim.
We bought a 152 for my daughter's flight school that had a windshield
that had been mistreated. On our first try with Micromesh it came out
just fine, even though the whole windshield needed doing. Since then
(~1990) we've used it for smaller jobs a couple times with excellent
results.
Marlys and John 40458
very aggressive.
> worked miracles.
> Tim Olson - RV-10 N104CD - Flying
> John Jessen wrote:
>> Help! Scratches on windshield............. Wanted to clean off
>> could recommend....PLEASE! Ugh. John J
Tim Olson
PostPosted: Mon Feb 25, 2008 8:37 am    Post subject: Windshield scratches Reply with quote
Yeah, I hate to discourage the do-it-yourself-ers when it's a job
that isn't too hard to do at all. I mean, to me, it was really
a simple process...and many many things during the build were
far more challenging...this one took almost no thinking.'
I'm just that way about everything though...this weekend I
decided to take Harbor Freight up on their sale prices for carpet
tools and lay carpet as a D-I-Y job. Last week it was drywall
and texture (which my skills are getting better at, after
painting the plane. Wink ) There is just so much to be
saved, and tons to be learned by doing some things yourself.
BTW: For those who like browsing harbor freight, it seems
that air powered body saw has been consistently at $19.99
on sale for a while...perfect for cutting leading edge light
holes and lots of other things. I keep finding more and more
stuff to buy there as time goes on. Wish I could still
get their bandsaw...I could really use one at home now
that mine is at the hangar.
John Ackerman wrote:
Second that, Tim.
results.
mritter509(at)msn.com
PostPosted: Mon Feb 25, 2008 10:52 am    Post subject: Windshield scratches Reply with quote
I had a scratch on my RV-10 windscreen on the inside about 4 inches long in a curved portion of the window (slap anyone who tries to put their headsets on the glareshield) that was really difficult to get to. Wish I had left it to the experts. At the end of the day I got rid of the scratch OK but ended up with a distortion I couldn't live with - not one of my better monemts. Ended up replacing the windscreen - you can imagine how much fun that was. Had the plane been painted I would have really been up a creek.
Mark
RV-10/N410MR
<html><div></div></html>
Date: Mon, 25 Feb 2008 09:24:00 -0600
Subject: Re: Windshield scratches
--> RV10-List message posted by: Tim Olson <Tim(at)MyRV10.com>
very aggressive.
> worked miracles.
>> John J
&g================
Need to know the score, the latest news, or you need your HotmailŪ-get your "fix". Check it out. [quote][b]
n212pj(at)gmail.com
PostPosted: Mon Feb 25, 2008 10:56 am    Post subject: Windshield scratches Reply with quote
Thanks to everyone for your posts on windshield scratches. I will order the
Micromesh and have at it. I'll take pictures of the tools that made the
scratches, the actual scratches, the tools assembled to get rid of them, and
document the process. If I'm successful, I'll post everything on my site
and send it on to Tim so it can be placed in a convenient location for
future reference. Knowing Tim, there's probably something on the topic on
his site already.
If I have to replace the windshield, I'll take pictures of Hell's canyon
just before the leap.
You know, I just never thought that the windshield I'm zooming through the
air behind (well, relative zooming) would be this soft. Another lesson...
John J
40328
AV8ORJWC
PostPosted: Mon Feb 25, 2008 11:35 am    Post subject: Windshield scratches Reply with quote
Your point is well taken. Care and protection of the windscreen leads to years of trouble free enjoyment with continued clarity.
Bugs, ballpoint pens, clipboards, headsets and other sundry items leave a lasting and less than enjoyable impression. There have been a few novel headset hangers in some of the pictures that have drifted from this list over the months. The Repairman’s cap needs to be on while we are wearing the Builder cap. It can substantially reduce the post production repairs list.
John
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Mark Ritter
Sent: Monday, February 25, 2008 10:30 AM
Subject: RE: Windshield scratches
Mark
RV-10/N410MR
