		CJohnston(at)popsound.com Guest
				 Posted: Tue Feb 26, 2008 1:11 pm    Post subject: Urethane pourable expanding foam in doors? |
				Hey all -
 I know someone around here has thought about filling the doors with an expanding foam to give them some density and make 'em be less flimsy.  Anyone care to speculate if you'd split your door in two by doing this?  I was thinking something like this:
 http://jgreer.com/Foam%20Page.htm
 I called and spoke with John Greer there and tried to explain myself.  "uh, so, I'm building an airplane, and I was thinking..."  you know how those conversations go.  I asked if he thought I'd blow up the door by filling it with that stuff, and he said he didn't think so.  After thinking about it a bit, I think I agree.  My reasoning:  on his website (and others with similar products) there's a picture of a paper cup with some foam that has been poured and expanded in it.  the foam expands over the top, and creates a muffin-top type situation.  the paper cup retains it's shape, and doesn't split.  So, think I, as long as you have open space for the foam to expand, it's not going to split the door.
 Now, this is all my hair-brained theory.  The leap to filling my already-fitting and built doors with something that could destroy them gives me pause.  The upside to doing this is that it seems like it'll make the doors feel much less flimsy, not add too much weight, insulate a bit, cut down on noise, etc.  Downsides?  possibly having to build new doors.  hmmm.  I think I'm going to get some of this foam and do some testing.  While I'm on this voyage of discovery, anyone want to give their opinion?  A search of the archives only had one entry on the subject, and it had not much detail.
 cj
 #40410
 finishing/FF/various science projects
 www.perfectlygoodairplane.net
		glastar(at)gmx.net Guest
				 Posted: Tue Feb 26, 2008 1:27 pm    Post subject: Urethane pourable expanding foam in doors? |
				The paper cup is a different story as it can easely expand, if you have
 a small and narrow channel the story might come out different!
 I would be very carefull with that approach, for a short open space ok,
 for a long (>3" and narrow (1" or less)) I would leave my fingers off,
 and then there is the weight of UR foam.
 as usuasl just my 5cents
 Werner
 Chris Johnston wrote:
  	  | Quote: | 	 		   Hey all -
  cj
  #40410
		Tim Olson
				 Posted: Tue Feb 26, 2008 1:37 pm    Post subject: Urethane pourable expanding foam in doors? |
				There are people who have put fabric on their doors who already
 can't get the lift cylinders to stay up well.  It would
 only get worse over time.  Mine work good, but I would never
 bother filling them with foam.
 If you want me to be blunt, I could just say
 "Hey cj, that's a dumb idea."  But instead, I'll just
 say......is it really worth the possible downsides?
 I think you'll find that just having fabric on the inside of the
 plane will deaden echo'd sounds, and make it pretty quiet.
 And, warmth wise you really have no concerns.  The heat
 output in the -10 is incredible.  I fly in 10F weather with
 no jacket in the plane because you can easily warm it
 comfortable with 1/2 heat.  I can't even use full heat.
 Anyway, you got my .02.   No offense, just havin' fun.
  	  | Quote: | 	 		   Hey all -
  cj #40410 finishing/FF/various science projects
		ron.mcgann(at)baesystems. Guest
				 Posted: Tue Feb 26, 2008 1:47 pm    Post subject: Urethane pourable expanding foam in doors? |
				Hey CJ,
 Have you installed the windows in the doors yet?  I thought the doors
 were flimsy too, until I installed the windows.  Seem plenty rigid to me
 now.  With real issues surrounding door fit, the door latch and the
 installation of a locking mechanism, rigidity of the door has not been a
 concern for me. YMMV tho'
 Cheers,
 Ron
 187 still trying to finish
				 Posted: Tue Feb 26, 2008 2:16 pm    Post subject: Urethane pourable expanding foam in doors? |
				Absolutely do not do this!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  You will find out several things. As has been said, with so little space for the foam to expand into, it can easily seal itself off, leaving no place for the expansion to go and it will warp and bow out your doors. If you could have each part half still in their mold halves and then fill it and close the mold, it would be a different story.
  "Do Not Seek The Treasure!!!!" Oh Brother Where Art Thou
  JOhn G.
  	  | Quote: | 	 		   Subject: Urethane pourable expanding foam in doors?
  Date: Tue, 26 Feb 2008 13:08:02 -0800
  Hey all -
  cj
  #40410
				 Posted: Tue Feb 26, 2008 3:43 pm    Post subject: Urethane pourable expanding foam in doors? |
				Been there, done that .... but not on parts like these doors.  If you
 decide to go down this path .... and I think it's a good idea .... there
 are a few things you can control, and a few that you can't.
 You really should make some weep holes along the cavity ..... a place
 for the pressure to go.  Plug these with a tapered plug that's snug, not
 tight.  At any signs of swelling, pull the plugs.
 The pressure can get fairly high per sq. in., but having a close space
 makes the foam denser, and therefore stronger.  If there's a seam that
 didn't get sufficient epoxy, it may part.
 To do a good job, you need to get the liquid foam  to coat the whole
 cavity before it flashes off.  The cooler you keep it, the longer your
 working time.  once it starts to kick, it generates it's own heat and
 it'll run away pretty quickly.
 You need to have some way to get the liquid mix into the cavity .....
 you may be able to take a baggie, cut a corner off, and tape a tube in
 the hole.  Fill the baggie with the mix, and squeeze it like a bakers
 icing bag into the cavity.  I had a machine that mixed the two parts and
 I could spray it into a cavity.
 Having gone all through this, if there's a boat manufacturer near you,
 they have the machine to spray foam into flotation places and can give
 you some pointers.
 Linn
  	  | Quote: | 	 		  Hey all -
 cj
 #40410
		GRANSCOTT(at)aol.com Guest
				 Posted: Wed Feb 27, 2008 5:59 am    Post subject: Urethane pourable expanding foam in doors? |
				CJ,
  What happens to Urethane when it burns...what types of gasing off are  you going to get as the foam expands and continues to gas-off.  Some  applications of expandables can cause irritation to lungs and soft tissues both  immediately and long term migration.
  P
 Delicious ideas to please the pickiest eaters. Watch the video on AOL Living.
		Jon Reining
				 Posted: Wed Feb 27, 2008 9:25 am    Post subject: Re: Urethane pourable expanding foam in doors? |
				I just foamed the walls of my house for insulation and went through a pretty extensive search.  There's a big difference between the open and closed cell foam.  Its looks like you're looking at closed cell foam.  The open cell foam tends to weigh less, but also have a pretty huge expansion factor when its applied.  So I'd definitely stay away from that.
 The closed cell foam doesn't expand as much, is denser (and weighs more) but also adds quite a bit of structural strength.
 I ended up going with closed cell foam that is made primarily from soy beans and had an R value of like 7.5 per inch of foam.  As an insulator on a house its awesome.
 So, to apply all this to airplane building...  I don't think its entirely crazy, but I'd be especially careful.  Perhaps glass up a simulated door cavity and try it out and see how you like it.
		rene(at)felker.com Guest
				 Posted: Wed Feb 27, 2008 9:49 am    Post subject: Urethane pourable expanding foam in doors? |
				Just one thought on the foam.  You also have to be concerned about water
 absorption and UV and heat affects.
 Rene' Felker
 N423CF
 40322
 801-721-6080
		n8vim(at)arrl.net Guest
				 Posted: Wed Feb 27, 2008 3:39 pm    Post subject: Urethane pourable expanding foam in doors? |
				If the doors catch fire, just open the door handle and the door disappears!
 -Jim 40384
 GRANSCOTT(at)aol.com wrote:
  	  | Quote: | 	 		   CJ,
  P
  Living.
  <http://living.aol.com/video/how-to-please-your-picky-eater/rachel-campos-duffy/2050827?NCID=aolcmp00300000002598>
