larywil(at)comcast.net Guest
Posted: Sun Feb 24, 2008 3:08 pm Post subject: Gas tank repair |
Hi gang,
A few months ago, many of you gave me a lot of help/instruction to
remove my leaky tank. I finally removed it today, with a lot less
problems than I anticipated. BUT, I am finding that the large (6")
access plate is not so obedient. I carefully removed all 12 screws.
Now what? The plate is prosealed in place, and has lots of
additional sealant from previous repairs. I removed most of the added
repair sealant while trying not to gauge away at the plate and rib.
Since I am not the builder, I am not sure what I am now looking at.
Looking at the edge of the access plate, it appears to be two layers
of aluminum resting on the rib material. Is there a reinforcement
ring between the access plate and the rib material? (I am calling the
ends of the tank "ribs" since they in fact are acting as such).
Whatever is there, the access plate is firmly attached with proseal
to the rib or ring below.
Anyway, I do not want to destroy this tank. How do I lift the access
plate away? Do I need to soften up the proseal? Can this be done?
Help!! I love you guys. Help!
Thanks in advance.
Louis I Willig
1640 Oakwood Dr.
Penn Valley, PA 19072
610 668-4964
RV-4, N180PF
190HP IO-360, C/S prop
| - The Matronics RV-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
Larry Bowen
Posted: Sun Feb 24, 2008 5:01 pm Post subject: Gas tank repair |
If all the screws are out, only the proseal is holding it on. Work a blade of some sort between the access cover and the rib, being careful not to score anything.
Some more notes and pictures here:
http://bowenaero.com/mt/2006/11/conditional-inspection-2006.html
Larry Bowen
Larry(at)BowenAero.com (Larry(at)BowenAero.com)
http://BowenAero.com
On Sun, Feb 24, 2008 at 6:05 PM, Louis Willig <larywil(at)comcast.net (larywil(at)comcast.net)> wrote:
Quote: | --> RV-List message posted by: Louis Willig <larywil(at)comcast.net (larywil(at)comcast.net)>
Hi gang,
Thanks in advance.
Louis I Willig
1640 Oakwood Dr.
610 668-4964
RV-4, N180PF
_________________ Larry Bowen
RV-8 SOLD,
RV-7QB in progress... |
Posted: Sun Feb 24, 2008 6:15 pm Post subject: Gas tank repair |
Get a metal putty knife and file the edge to a chisel point, then use that
to cut through the proseal.
KB
mrobert569(at)hotmail.com Guest
Louis,
There may , or may not, be a cork gasket between the tank rib and the panel. My favorite weapon of choice for removing this panel is a slightly sharpened butter knife. Start working the knife between the panels and work it around the panel cutting and prying slowly as you go. I tell everyone to take their time when doing this and you will cause very little damage. Good luck.
Mike Robertson
Repeat offender
Das Fed
> Date: Sun, 24 Feb 2008 18:05:09 -0500
Quote: | To: rv-list(at)matronics.com
Subject: Gas tank repair
--> RV-List message posted by: Louis Willig <larywil(at)comcast.net>
Hi gang,
Thanks in advance.
Louis I Willig
1640 Oakwood Dr.
610 668-4964
RV-4, N180PF
190HP IO-3======
Shed those extra pounds with MSN and The Biggest Loser! Learn more. [quote][b]
dcr(at)fdltownhomes.com Guest
Posted: Sun Feb 24, 2008 6:17 pm Post subject: gas tank repair |
Louis: I used a heat gun to warn and soften the Proseal. I understand the fuel tank is full of vapors and I kept the heat gun away from the tank access plate as possible but still heat the plate sufficiently to soften the Proseal and used a razor knife under the plate, MEK to clean. Hope this helps, Dan.
Doug Gray
Joined: 10 Jan 2006 Posts: 112 Location: Sydney, Australia
Posted: Mon Feb 25, 2008 2:44 am Post subject: Gas tank repair |
Get at it with plastic steak knives. Cheap and effective and doesn't
marr the alclad.
Doug Gray
On Sun, 2008-02-24 at 18:05 -0500, Louis Willig wrote:
Quote: |
Hi gang,
Thanks in advance.
Louis I Willig
1640 Oakwood Dr.
610 668-4964
RV-4, N180PF
Dale Ensing
Posted: Mon Feb 25, 2008 3:05 am Post subject: Gas tank repair |
A method we have used successfully. when doing the SB fix on the pick up
line, is to use a very flexible putty knife sharpened a bit on the end edge.
Work it in between the plate and the ring. It helps if you can warm the
Proseal.(heat lamp or sun) After you have one side loose you can apply some
pressure to the plate by pulling/lifting on the loose side which will help
get the knife in around the remaining edge. A little bending of the plate is
OK when you are pulling on it as it will straighten when you release the
pressure.
Dale Ensing
EAA TC & FA
_________________ Dale Ensing
RV-6A
Aero Plantation
Weddington NC |
Posted: Mon Feb 25, 2008 5:41 am Post subject: gas tank repair |
Hey Guys-
RE: >Louis: I used a heat gun to warn and soften the Proseal. I understand the
Quote: | fuel tank is full of vapors and I kept the heat gun away from the tank
helps, Dan.
If MEK will soften the proseal, how about standing the tank on it's outboard end with MEK on the inbd end. Put some sort of cover over the butt rib to limit evaporation. If you let the tank sit a day ot two, would the access panel come free easily, or would you just cause other problems?
Glen Matejcek
Terry Watson
Joined: 09 Jan 2006 Posts: 290 Location: Seattle, WA USA
Posted: Mon Feb 25, 2008 8:37 am Post subject: Gas tank repair |
You might try a plastic putty knife. I have a set of three that were very
cheap but seem to be just the right hardness and stiffness to scrape gunk
off of aluminum without damaging the aluminum.
Terry
Posted: Mon Feb 25, 2008 3:14 pm Post subject: Gas tank repair |
At 06:02 AM 2/25/2008, you wrote:
pick up line, is to use a very flexible putty knife sharpened a bit
on the end edge. Work it in between the plate and the ring. It helps
if you can warm the Proseal.(heat lamp or sun) After you have one
side loose you can apply some pressure to the plate by
pulling/lifting on the loose side which will help get the knife in
around the remaining edge. A little bending of the plate is OK when
you are pulling on it as it will straighten when you release the pressure.
Dale Ensing
EAA TC & FA
Dale,
you are the first person to use the word " ring". Is there a ring (
like a reinforcing) between the access plate and the tank wall? I
see what looks like two layers of metal attached to the rib. Is
this an illusion? (or is there actually a ring between the access
plate and the tank wall? I have been unable to decide where to attack
with my sharpened knife.
Several people have suggested heating the area. This is a great idea.
And there are zero fumes left in the tank.
Thanks to all so far. I've been on the "list" for over ten years, and
this is why.
Louis I Willig
1640 Oakwood Dr.
610 668-4964
RV-4, N180PF
khorton01(at)rogers.com Guest
Posted: Mon Feb 25, 2008 5:19 pm Post subject: Gas tank repair |
> <densing(at)carolina.rr.com>
> bit on the end edge. Work it in between the plate and the ring. It
> helps if you can warm the Proseal.(heat lamp or sun) After you
> have one side loose you can apply some pressure to the plate by
> the pressure.
> Dale Ensing
> EAA TC & FA
( like a reinforcing) between the access plate and the tank wall?
I see what looks like two layers of metal attached to the rib. Is
attack with my sharpened knife.
There is a reinforcing ring, but it should have been installed on the
inside of the tank. But, perhaps the builder put it on the outside.
If there truly are two layers of metal outboard of the tank rib, then
the putty knife would need to go between the access cover and the
next layer. The reinforcing ring should be riveted to the tank rib,
so you won't be prying it loose with a putty knife.
Good luck,
Kevin Horton
RV-8 (Finishing Kit)
Ottawa, Canada
http://www.kilohotel.com/rv8
rv6n(at)optonline.net Guest
Posted: Mon Feb 25, 2008 5:21 pm Post subject: Gas tank repair |
Louis C
6nbsp;
It has been years since I closed up my RV6 tanks but from what I remember we had the option of using a cork gasket 6nbsp;and or using the pro-seal 6nbsp;to prevent leaks E 6nbsp; I chose to just use the pro-seal 6nbsp;but I think you are looking at your tank and seeing the outer 6nbsp;plate and the cork and the pro-seal 6nbsp; E 6nbsp; The ribs were stamped to have raised reinforcing areas and I believe that is what the last lister was referring 6nbsp;to as the ring but 6nbsp;I think you took it as a separate 6nbsp;backer plate and I don 7t think that is the case E 6nbsp; If I am wrong maybe 6nbsp;Dale will chime in to clarify 6nbsp;what he is calling the ring E 6nbsp; You have some good advice already and I will most likely use some of it myself since I have not done this SB 6nbsp;either E 6nbsp; What I read that I like is using the flexible puddy 6nbsp;knife sharpened and the heat lamp to warm the pro seal 6nbsp;since it can be some tough stuff E 6nbsp; It is not a job I look forward to either but you can do it C just go at it E 6nbsp; It sounds like you removed your tanks and that should make it easier C I will attack mine through the wing root fairing area E 6nbsp; I also remember using some Allen 6nbsp;head screws to attach the cover plate to make it easier to unscrew C we 7ll see if it actually works E 6nbsp; You may want to consider them when reinstalling yours E 6nbsp; Good luck with yours C you could have it back together by the weekend E 6nbsp; I am in the middle of the second condition inspection E
6nbsp;
6nbsp;
Bob Bales
RV6
71 hours
FOK
Dale Ensing
Posted: Tue Feb 26, 2008 3:14 am Post subject: Gas tank repair |
I do not recall a separate reinforcement ring on my 6A. Only that which is
formed into the rib/tank wall. Could you be seeing a cork gasket? Or other
gasket material? I suggest you start working the tool between the access
plate and what ever is next.
Dale
RV-6A
Aero Plantation
Weddington NC |
mike109g6(at)insideconnec Guest
Posted: Tue Feb 26, 2008 8:30 am Post subject: Gas tank repair |
Dale,
As I recall on my 9A there is a separate reinforcement ring that the
nutplates as flush riveted to and then prosealed to the inside of the outer
most rib. The cover plate is then prosealed on the inside and then attached
to the rib with screws with the cork gasket sandwiched between. This is the
cover plate NOT the sender attach plate. So the screws are through cover
plate-cork gasket-rib-reinforcement ring-platenuts. Check your plans set
but I am almost positive that is how the 9A tanks are assembled. Now for
the disclaimer before anyone jumps my neck-Check you plan set, I may be
wrong since I have not looked at the plans for about 2 years, this is only
my recollection of the sequence.
Mike H 9A/8A
