RV8-Aileron & Flap Neutral Set
japhillipsga(at)aol.com
PostPosted: Wed Feb 27, 2008 8:15 am    Post subject: RV8-Aileron & Flap Neutral Set Reply with quote
Dear RV Builders, thanks to all of you for your prompt responses and assistance. With your help I found the more actuate method for setting neutral on DWG 12A and checked last night. Sure enough the cut out plywood template I laboriously sawed out was wrong. Using the steel rod on the machine bolt holes at the end of the wing method revealed that the tips are in fact correct, but my sawed out template was off near 9/16th at the tip end. So lesson learned. Do not rely on the paper transfer/saw out of plywood template method. It is inaccurate. Thanks again to all you fellows that brought this to light. I owe you and best regards, Bill of Georgia
